[PATCH v1] Add steps to test Newlib patch.
Fri Aug 16 14:27:58 UTC 2019
Then this should be sent with -v2.
On Thu, Aug 15, 2019 at 1:33 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> On Thu, Aug 15, 2019 at 8:51 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Is this a duplicate of the other "patch v1 Add steps to test Newlib patch." or this one replaces it?
> This one replaces it. Actually I replaced all the previous ones with mine.
> The commands, steps I have written are based on what worked for me for number of times.
> I build the toolchain twice when RSB got updated, but my changes were not pushed so had to
> use patches in RSB. And these steps worked perfectly both times.
> -Vaibhav
>> On Wed, Aug 14, 2019 at 11:45 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>> Update the checksum to be used for the Newlib patches.
>>> Earlier it was msd5, but it is depreciated for security
>>> reasons. Now RSB accepts sha512.
>>>  user/rsb/project-sets.rst | 41 +++++++++++++++++++++++++++++++++------
>>>  1 file changed, 35 insertions(+), 6 deletions(-)
>>> diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
>>> index 5ffce26..b01857e 100644
>>> --- a/user/rsb/project-sets.rst
>>> +++ b/user/rsb/project-sets.rst
>>> @@ -261,17 +261,46 @@ in the ``source-builder/config`` template configuration files.
>>>  To test a patch simply copy it to your local ``patches`` directory. The RSB
>>>  will see the patch is present and will not attempt to download it. Once you are
>>>  happy with the patch submit it to the project and a core developer will review
>>> -it and add it to the RTEMS Tools git repository.  For example, to test a local
>>> -patch for newlib, add the following two lines to the .cfg file in
>>> -``rtems/config/tools/`` that is included by the bset you use:
>>> +it and add it to the RTEMS Tools git repository.
>>> +Testing a Newlib Patch
>>> +To test a local patch for newlib, you need to add the following
>>> +two lines to the ``.cfg`` file in ``rsb/rtems/config/tools/`` that is included
>>> +by the bset you use:
>>> +.. topic:: Steps:
>>> +  1. Create patches for the changes you want to test. (Note: For RSB, before
>>> +     creating Newlib patch, you must run ``autoreconf -fvi`` in the required
>>> +     directory after you make changes to the code. This is not required when
>>> +     you create patch to send to ``newlib-devel``. But if you want RSB to
>>> +     address your changes, your patch should also include regenerated files.)
>>> +  2. Calculate ``sha512`` of your patch.
>>> +  3. Place the patches in ``rsb/rtems/patches`` directory.
>>> +  4. Open the ``.bset`` file used by your BSP in ``rsb/rtems/config``.
>>> +     For example, for ``rtems5``, ``SPARC``, the file will be
>>> +     ``rsb/rtems/config/5/rtems-sparc.bset``.
>>> +  5. Inside it you will find the name of ``.cfg`` file for Newlib, used by
>>> +     your BSP.
>>> +     For example, I found ``tools/rtems-gcc-7.4.0-newlib-1d35a003f``.
>>> +  6. Edit your ``.cfg`` file. In my case it will be,
>>> +     ``rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg``. And
>>> +     add the information about your patch as mentioned below.
>>>  .. code-block:: spec
>>> -    %patch add newlib file://0001-this-is-a-newlib-patch.patch   <1>
>>> -    %hash md5 0001-this-is-a-newlib-patch.diff 77d070878112783292461bd6e7db17fb <2>
>>> +    %patch add newlib -p1 file://0001-Port-ndbm.patch <1>
>>> +    %hash sha512 0001-Port-ndbm.patch 7d999ceeea4f3dc82e8e0aadc09d983a7a68b44470da8a3d61ab6fc558fdba6f2c2de3acc2f32c0b0b97fcc9ab799c27e87afe046544a69519881f947e7881d1 <2>
>>>  .. topic:: Items:
>>>    1. The diff file prepended with ``file://`` to tell RSB this is a local file.
>>> -  2. The output from md5sum on the diff file.
>>> +  2. The output from sha512sum on the patch file.
>>> 2.21.0
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
