[PATCH v1] Add steps to test Newlib patch.
Fri Aug 16 15:22:12 UTC 2019
Ignoring the v1 vs v2, Jeff Johnson sent me a script to bootstrap newlib
from the top. I updated it for the addition of fenv.
And you need specifically automake 1.11.6 and autoconf 2.68 per him.
--joel
On Fri, Aug 16, 2019 at 10:03 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> On Fri, Aug 16, 2019 at 8:16 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Vaibhav,
>> The use of the -vX is to differentiate patches that are sent to review
>> on the mailing list.
> Yeah, actually I assumed that working on different branch may
> allow us to send patches like this.
>> If this is not clear in our contributing
>> guidelines, we probably need to improve the description...
>> On Fri, Aug 16, 2019 at 8:32 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>> > Sure,
>> > Actually made this patch on different branch so used -v1.
>> > Sending a new one with -v2.
>> > -Vaibhav
>> > On Fri, Aug 16, 2019, 7:58 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> Then this should be sent with -v2.
>> >> On Thu, Aug 15, 2019 at 1:33 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>> >> > On Thu, Aug 15, 2019 at 8:51 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> >> Is this a duplicate of the other "patch v1 Add steps to test Newlib patch." or this one replaces it?
>> >> > This one replaces it. Actually I replaced all the previous ones with mine.
>> >> > The commands, steps I have written are based on what worked for me for number of times.
>> >> > I build the toolchain twice when RSB got updated, but my changes were not pushed so had to
>> >> > use patches in RSB. And these steps worked perfectly both times.
>> >> > -Vaibhav
>> >> >> On Wed, Aug 14, 2019 at 11:45 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>> >> >>> Update the checksum to be used for the Newlib patches.
>> >> >>> Earlier it was msd5, but it is depreciated for security
>> >> >>> reasons. Now RSB accepts sha512.
>> >> >>>  user/rsb/project-sets.rst | 41 +++++++++++++++++++++++++++++++++------
>> >> >>>  1 file changed, 35 insertions(+), 6 deletions(-)
>> >> >>> diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
>> >> >>> index 5ffce26..b01857e 100644
>> >> >>> --- a/user/rsb/project-sets.rst
>> >> >>> +++ b/user/rsb/project-sets.rst
>> >> >>> @@ -261,17 +261,46 @@ in the ``source-builder/config`` template configuration files.
>> >> >>>  To test a patch simply copy it to your local ``patches`` directory. The RSB
>> >> >>>  will see the patch is present and will not attempt to download it. Once you are
>> >> >>>  happy with the patch submit it to the project and a core developer will review
>> >> >>> -it and add it to the RTEMS Tools git repository.  For example, to test a local
>> >> >>> -patch for newlib, add the following two lines to the .cfg file in
>> >> >>> -``rtems/config/tools/`` that is included by the bset you use:
>> >> >>> +it and add it to the RTEMS Tools git repository.
>> >> >>> +Testing a Newlib Patch
>> >> >>> +To test a local patch for newlib, you need to add the following
>> >> >>> +two lines to the ``.cfg`` file in ``rsb/rtems/config/tools/`` that is included
>> >> >>> +by the bset you use:
>> >> >>> +.. topic:: Steps:
>> >> >>> +  1. Create patches for the changes you want to test. (Note: For RSB, before
>> >> >>> +     creating Newlib patch, you must run ``autoreconf -fvi`` in the required
>> >> >>> +     directory after you make changes to the code. This is not required when
>> >> >>> +     you create patch to send to ``newlib-devel``. But if you want RSB to
>> >> >>> +     address your changes, your patch should also include regenerated files.)
>> >> >>> +  2. Calculate ``sha512`` of your patch.
>> >> >>> +  3. Place the patches in ``rsb/rtems/patches`` directory.
>> >> >>> +  4. Open the ``.bset`` file used by your BSP in ``rsb/rtems/config``.
>> >> >>> +     For example, for ``rtems5``, ``SPARC``, the file will be
>> >> >>> +     ``rsb/rtems/config/5/rtems-sparc.bset``.
>> >> >>> +  5. Inside it you will find the name of ``.cfg`` file for Newlib, used by
>> >> >>> +     your BSP.
>> >> >>> +     For example, I found ``tools/rtems-gcc-7.4.0-newlib-1d35a003f``.
>> >> >>> +  6. Edit your ``.cfg`` file. In my case it will be,
>> >> >>> +     ``rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg``. And
>> >> >>> +     add the information about your patch as mentioned below.
>> >> >>>  .. code-block:: spec
>> >> >>> -    %patch add newlib file://0001-this-is-a-newlib-patch.patch   <1>
>> >> >>> -    %hash md5 0001-this-is-a-newlib-patch.diff 77d070878112783292461bd6e7db17fb <2>
>> >> >>> +    %patch add newlib -p1 file://0001-Port-ndbm.patch <1>
>> >> >>> +    %hash sha512 0001-Port-ndbm.patch 7d999ceeea4f3dc82e8e0aadc09d983a7a68b44470da8a3d61ab6fc558fdba6f2c2de3acc2f32c0b0b97fcc9ab799c27e87afe046544a69519881f947e7881d1 <2>
>> >> >>>  .. topic:: Items:
>> >> >>>    1. The diff file prepended with ``file://`` to tell RSB this is a local file.
>> >> >>> -  2. The output from md5sum on the diff file.
>> >> >>> +  2. The output from sha512sum on the patch file.
>> >> >>> 2.21.0
>> >> >>> _______________________________________________
>> >> >>> devel mailing list
>> >> >>> devel at rtems.org
>> >> >>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
