[PATCH] bsps/arm/shared: Add GICv3 implementation
    Kinsey Moore
    kinsey.moore at oarcorp.com
    Fri Aug 16 19:14:33 UTC 2019
This adds support for the GICv3 interrupt controller along with the
redistributor to control SGIs and PPIs which wasn't present in GICv2
implementations. GICv3 implementations only optionally support
memory-mapped GICC interface interaction and require system register
access be implemented, so the GICC interface is accessed only
through system registers.
 bsps/arm/include/bsp/arm-gic-irq.h  |  15 +-
 bsps/arm/include/bsp/arm-gic-regs.h |  76 ++++++++-
 bsps/arm/shared/irq/irq-gic.c       |  16 ++
 bsps/arm/shared/irq/irq-gicv3.c     | 329 ++++++++++++++++++++++++++++++++++++
 4 files changed, 427 insertions(+), 9 deletions(-)
 create mode 100644 bsps/arm/shared/irq/irq-gicv3.c
diff --git a/bsps/arm/include/bsp/arm-gic-irq.h b/bsps/arm/include/bsp/arm-gic-irq.h
index b3e893de72..219c3c7189 100644
--- a/bsps/arm/include/bsp/arm-gic-irq.h
+++ b/bsps/arm/include/bsp/arm-gic-irq.h
@@ -85,6 +85,12 @@ typedef enum {
   ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF
 } arm_gic_irq_software_irq_target_filter;
+void arm_gic_trigger_sgi(
+  rtems_vector_number vector,
+  arm_gic_irq_software_irq_target_filter filter,
+  uint8_t targets
 static inline rtems_status_code arm_gic_irq_generate_software_irq(
@@ -94,14 +100,7 @@ static inline rtems_status_code arm_gic_irq_generate_software_irq(
   rtems_status_code sc = RTEMS_SUCCESSFUL;
   if (vector <= ARM_GIC_IRQ_SGI_15) {
-    volatile gic_dist *dist = ARM_GIC_DIST;
-    dist->icdsgir = GIC_DIST_ICDSGIR_TARGET_LIST_FILTER(filter)
-      | GIC_DIST_ICDSGIR_CPU_TARGET_LIST(targets)
-#ifdef BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
-      | GIC_DIST_ICDSGIR_NSATT
-#endif
-      | GIC_DIST_ICDSGIR_SGIINTID(vector);
+    arm_gic_trigger_sgi(vector, filter, targets);
   } else {
     sc = RTEMS_INVALID_ID;
diff --git a/bsps/arm/include/bsp/arm-gic-regs.h b/bsps/arm/include/bsp/arm-gic-regs.h
index 2915313b71..8a65294b6f 100644
--- a/bsps/arm/include/bsp/arm-gic-regs.h
+++ b/bsps/arm/include/bsp/arm-gic-regs.h
@@ -86,7 +86,18 @@ typedef struct {
 } gic_cpuif;
 typedef struct {
+  /* GICD_CTLR */
   uint32_t icddcr;
+/* GICv3 only */
+#define GIC_DIST_ICDDCR_RWP BSP_BIT32(31)
+#define GIC_DIST_ICDDCR_E1NWF BSP_BIT32(7)
+#define GIC_DIST_ICDDCR_DS BSP_BIT32(6)
+#define GIC_DIST_ICDDCR_ARE_NS BSP_BIT32(5)
+#define GIC_DIST_ICDDCR_ARE_S BSP_BIT32(4)
+#define GIC_DIST_ICDDCR_ENABLE_GRP1S BSP_BIT32(2)
+#define GIC_DIST_ICDDCR_ENABLE_GRP1NS BSP_BIT32(1)
+#define GIC_DIST_ICDDCR_ENABLE_GRP0 BSP_BIT32(0)
+/* GICv1/GICv2 */
 #define GIC_DIST_ICDDCR_ENABLE_GRP_1 BSP_BIT32(1)
 #define GIC_DIST_ICDDCR_ENABLE BSP_BIT32(0)
   uint32_t icdictr;
@@ -126,7 +137,9 @@ typedef struct {
   uint8_t icdiptr[256];
   uint32_t reserved_900[192];
   uint32_t icdicfr[64];
-  uint32_t reserved_d00[128];
+  /* GICD_IGRPMODR GICv3 only, reserved in GICv1/GICv2 */
+  uint32_t icdigmr[32];
+  uint32_t reserved_d80[96];
   uint32_t icdsgir;
 #define GIC_DIST_ICDSGIR_TARGET_LIST_FILTER(val) BSP_FLD32(val, 24, 25)
 #define GIC_DIST_ICDSGIR_TARGET_LIST_FILTER_GET(reg) BSP_FLD32GET(reg, 24, 25)
@@ -140,4 +153,65 @@ typedef struct {
 #define GIC_DIST_ICDSGIR_SGIINTID_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
 } gic_dist;
+/* GICv3 only */
+typedef struct {
+  /* GICR_CTLR */
+  uint32_t icrrcr;
+#define GIC_REDIST_ICRRCR_UWP BSP_BIT32(31)
+#define GIC_REDIST_ICRRCR_DPG1S BSP_BIT32(26)
+#define GIC_REDIST_ICRRCR_DPG1NS BSP_BIT32(25)
+#define GIC_REDIST_ICRRCR_DPG0 BSP_BIT32(24)
+#define GIC_REDIST_ICRRCR_RWP BSP_BIT32(4)
+#define GIC_REDIST_ICRRCR_ENABLE_LPI BSP_BIT32(0)
+  uint32_t icriidr;
+  uint64_t icrtyper;
+#define GIC_REDIST_ICRTYPER_AFFINITY_VALUE(val) BSP_FLD64(val, 32, 63)
+#define GIC_REDIST_ICRTYPER_AFFINITY_VALUE_GET(reg) BSP_FLD64GET(reg, 32, 63)
+#define GIC_REDIST_ICRTYPER_AFFINITY_VALUE_SET(reg, val) BSP_FLD64SET(reg, val, 32, 63)
+#define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY(val) BSP_FLD64(val, 24, 25)
+#define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY_GET(reg) BSP_FLD64GET(reg, 24, 25)
+#define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY_SET(reg, val) BSP_FLD64SET(reg, val, 24, 25)
+#define GIC_REDIST_ICRTYPER_CPU_NUMBER(val) BSP_FLD64(val, 8, 23)
+#define GIC_REDIST_ICRTYPER_CPU_NUMBER_GET(reg) BSP_FLD64GET(reg, 8, 23)
+#define GIC_REDIST_ICRTYPER_CPU_NUMBER_SET(reg, val) BSP_FLD64SET(reg, val, 8, 23)
+#define GIC_REDIST_ICRTYPER_DPGS BSP_BIT64(5)
+#define GIC_REDIST_ICRTYPER_LAST BSP_BIT64(4)
+#define GIC_REDIST_ICRTYPER_DIRECT_LPI BSP_BIT64(3)
+#define GIC_REDIST_ICRTYPER_VLPIS BSP_BIT64(1)
+#define GIC_REDIST_ICRTYPER_PLPIS BSP_BIT64(0)
+  uint32_t unused_10;
+  uint32_t icrwaker;
+#define GIC_REDIST_ICRWAKER_CHILDREN_ASLEEP BSP_BIT32(2)
+#define GIC_REDIST_ICRWAKER_PROCESSOR_SLEEP BSP_BIT32(1)
+} gic_redist;
+/* GICv3 only */
+typedef struct {
+  uint32_t reserved_0_80[32];
+  /* GICR_IGROUPR0 */
+  uint32_t icspigrpr[32];
+  /* GICR_ISENABLER0 */
+  uint32_t icspiser[32];
+  /* GICR_ICENABLER0 */
+  uint32_t icspicer[32];
+  /* GICR_ISPENDR0 */
+  uint32_t icspispendr[32];
+  /* GICR_ICPENDR0 */
+  uint32_t icspicpendr[32];
+  /* GICR_ISACTIVER0 */
+  uint32_t icspisar[32];
+  /* GICR_ICACTIVER0 */
+  uint32_t icspicar[32];
+  /* GICR_IPRIORITYR */
+  uint8_t icspiprior[32];
+  uint32_t reserved_420_bfc[504];
+  /* GICR_ICFGR0 */
+  uint32_t icspicfgr0;
+  /* GICR_ICFGR1 */
+  uint32_t icspicfgr1;
+  uint32_t reserved_c08_cfc[62];
+  /* GICR_IGRPMODR0 */
+  uint32_t icspigrpmodr[64];
+} gic_sgi_ppi;
 #endif /* LIBBSP_ARM_SHARED_ARM_GIC_REGS_H */
diff --git a/bsps/arm/shared/irq/irq-gic.c b/bsps/arm/shared/irq/irq-gic.c
index 65a7e6f653..7cf469d0f7 100644
--- a/bsps/arm/shared/irq/irq-gic.c
+++ b/bsps/arm/shared/irq/irq-gic.c
@@ -262,3 +262,19 @@ void bsp_interrupt_get_affinity(
   _Processor_mask_From_uint32_t(affinity, targets, 0);
+  uint8_t targets
+  volatile gic_dist *dist = ARM_GIC_DIST;
+  dist->icdsgir = GIC_DIST_ICDSGIR_TARGET_LIST_FILTER(filter)
+    | GIC_DIST_ICDSGIR_CPU_TARGET_LIST(targets)
+#ifdef BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
+    | GIC_DIST_ICDSGIR_NSATT
+#endif
+    | GIC_DIST_ICDSGIR_SGIINTID(vector);
diff --git a/bsps/arm/shared/irq/irq-gicv3.c b/bsps/arm/shared/irq/irq-gicv3.c
new file mode 100644
index 0000000000..138b565b9b
--- /dev/null
+++ b/bsps/arm/shared/irq/irq-gicv3.c
@@ -0,0 +1,329 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 On-Line Applications Research Corporation (OAR)
+ * are met:
+#include <bsp/arm-gic.h>
+#include <rtems/score/armv4.h>
+#include <libcpu/arm-cp15.h>
+#include <bsp/irq.h>
+#include <bsp/irq-generic.h>
+#include <bsp/start.h>
+#define PRIORITY_DEFAULT 127
+/* cpuif->iccicr */
+#define ICC_CTLR    "p15, 0, %0, c12, c12, 4"
+/* cpuif->iccpmr */
+#define ICC_PMR     "p15, 0, %0,  c4,  c6, 0"
+/* cpuif->iccbpr */
+#define ICC_BPR0    "p15, 0, %0, c12,  c8, 3"
+#define ICC_BPR1    "p15, 0, %0, c12, c12, 3"
+/* cpuif->icciar */
+#define ICC_IAR0    "p15, 0, %0, c12,  c8, 0"
+#define ICC_IAR1    "p15, 0, %0, c12, c12, 0"
+/* cpuif->icceoir */
+#define ICC_EOIR0   "p15, 0, %0, c12,  c8, 1"
+#define ICC_EOIR1   "p15, 0, %0, c12, c12, 1"
+#define ICC_SRE     "p15, 0, %0, c12, c12, 5"
+#define ICC_IGRPEN0 "p15, 0, %0, c12, c12, 6"
+#define ICC_IGRPEN1 "p15, 0, %0, c12, c12, 7"
+#define ICC_SGI1    "p15, 0, %Q0, %R0, c12"
+#define ICC_SGIR_AFFINITY3(val) BSP_FLD64(val, 48, 55)
+#define ICC_SGIR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 48, 55)
+#define ICC_SGIR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 48, 55)
+#define ICC_SGIR_IRM BSP_BIT32(40)
+#define ICC_SGIR_AFFINITY2(val) BSP_FLD64(val, 32, 39)
+#define ICC_SGIR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 32, 39)
+#define ICC_SGIR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39)
+#define ICC_SGIR_INTID(val) BSP_FLD64(val, 24, 27)
+#define ICC_SGIR_INTID_GET(reg) BSP_FLD64GET(reg, 24, 27)
+#define ICC_SGIR_INTID_SET(reg, val) BSP_FLD64SET(reg, val, 24, 27)
+#define ICC_SGIR_AFFINITY1(val) BSP_FLD64(val, 16, 23)
+#define ICC_SGIR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 16, 23)
+#define ICC_SGIR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23)
+#define ICC_SGIR_CPU_TARGET_LIST(val) BSP_FLD64(val, 0, 15)
+#define ICC_SGIR_CPU_TARGET_LIST_GET(reg) BSP_FLD64GET(reg, 0, 15)
+#define ICC_SGIR_CPU_TARGET_LIST_SET(reg, val) BSP_FLD64SET(reg, val, 0, 15)
+#define MPIDR       "p15, 0, %0, c0, c0, 5"
+#define MPIDR_AFFINITY3(val) BSP_FLD64(val, 25, 29)
+#define MPIDR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 25, 29)
+#define MPIDR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 25, 29)
+#define MPIDR_AFFINITY2(val) BSP_FLD64(val, 16, 23)
+#define MPIDR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 16, 23)
+#define MPIDR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23)
+#define MPIDR_AFFINITY1(val) BSP_FLD64(val, 8, 15)
+#define MPIDR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 8, 15)
+#define MPIDR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 8, 15)
+#define MPIDR_AFFINITY0(val) BSP_FLD64(val, 0, 7)
+#define MPIDR_AFFINITY0_GET(reg) BSP_FLD64GET(reg, 0, 7)
+#define MPIDR_AFFINITY0_SET(reg, val) BSP_FLD64SET(reg, val, 0, 7)
+#define READ_SR(SR_NAME) \
+  uint32_t value; \
+  __asm__ volatile("mrc    " SR_NAME : "=r" (value) ); \
+  value; \
+#define WRITE_SR(SR_NAME, VALUE) \
+    __asm__ volatile("mcr    " SR_NAME "  \n" : : "r" (VALUE) );
+#define WRITE64_SR(SR_NAME, VALUE) \
+    __asm__ volatile("mcrr    " SR_NAME "  \n" : : "r" (VALUE) );
+#define ARM_GIC_REDIST ((volatile gic_redist *) BSP_ARM_GIC_REDIST_BASE)
+#define ARM_GIC_SGI_PPI (((volatile gic_sgi_ppi *) ((char*)BSP_ARM_GIC_REDIST_BASE + (1 << 16))))
+void bsp_interrupt_dispatch(void)
+  uint32_t icciar = READ_SR(ICC_IAR1);
+  rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
+  rtems_vector_number spurious = 1023;
+  if (vector != spurious) {
+    uint32_t psr = _ARMV4_Status_irq_enable();
+    bsp_interrupt_handler_dispatch(vector);
+    _ARMV4_Status_restore(psr);
+    WRITE_SR(ICC_EOIR1, icciar);
+void bsp_interrupt_vector_enable(rtems_vector_number vector)
+  volatile gic_sgi_ppi *sgi_ppi = ARM_GIC_SGI_PPI;
+  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
+  /* TODO(kmoore) This could use some cleanup and integration
+   * Vectors below 32 are currently routed through the redistributor */
+  if (vector >= 32) {
+    gic_id_enable(dist, vector);
+  } else {
+    sgi_ppi->icspiser[0] = 1 << (vector % 32);
+void bsp_interrupt_vector_disable(rtems_vector_number vector)
+    gic_id_disable(dist, vector);
+  } else {
+    sgi_ppi->icspicer[0] = 1 << (vector % 32);
+static inline uint32_t get_id_count(volatile gic_dist *dist)
+  uint32_t id_count = GIC_DIST_ICDICTR_IT_LINES_NUMBER_GET(dist->icdictr);
+  id_count = 32 * (id_count + 1);
+  id_count = id_count <= 1020 ? id_count : 1020;
+  return id_count;
+static void init_cpu_interface(void)
+  uint32_t sre_value = 0x7;
+  WRITE_SR(ICC_SRE, sre_value);
+  WRITE_SR(ICC_PMR, GIC_CPUIF_ICCPMR_PRIORITY(0xff));
+  WRITE_SR(ICC_BPR0, GIC_CPUIF_ICCBPR_BINARY_POINT(0x0));
+  volatile gic_redist *redist = ARM_GIC_REDIST;
+  uint32_t waker = redist->icrwaker;
+  uint32_t waker_mask = GIC_REDIST_ICRWAKER_PROCESSOR_SLEEP;
+  waker &= ~waker_mask;
+  redist->icrwaker = waker;
+  /* Set interrupt group to 1NS for SGI/PPI interrupts routed through the redistributor */
+  sgi_ppi->icspigrpr[0] = 0xffffffff;
+  sgi_ppi->icspigrpmodr[0] = 0;
+  for (int id = 0; id < 32; id++) {
+    sgi_ppi->icspiprior[id] = PRIORITY_DEFAULT;
+  /* Enable interrupt groups 0 and 1 */
+  WRITE_SR(ICC_IGRPEN0, 0x1);
+  WRITE_SR(ICC_IGRPEN1, 0x1);
+  WRITE_SR(ICC_CTLR, 0x0);
+rtems_status_code bsp_interrupt_facility_initialize(void)
+  uint32_t id_count = get_id_count(dist);
+  uint32_t id;
+  arm_cp15_set_exception_handler(
+    ARM_EXCEPTION_IRQ,
+    _ARMV4_Exception_interrupt
+  dist->icddcr = GIC_DIST_ICDDCR_ARE_NS | GIC_DIST_ICDDCR_ARE_S
+               | GIC_DIST_ICDDCR_ENABLE_GRP1S | GIC_DIST_ICDDCR_ENABLE_GRP1NS
+               | GIC_DIST_ICDDCR_ENABLE_GRP0;
+  for (id = 0; id < id_count; id += 32) {
+    /* Disable all interrupts */
+    dist->icdicer[id / 32] = 0xffffffff;
+    /* Set interrupt group to 1NS for all interrupts */
+    dist->icdigr[id / 32] = 0xffffffff;
+    dist->icdigmr[id / 32] = 0;
+  for (id = 0; id < id_count; ++id) {
+    gic_id_set_priority(dist, id, PRIORITY_DEFAULT);
+  for (id = 32; id < id_count; ++id) {
+    gic_id_set_targets(dist, id, 0x01);
+  init_cpu_interface();
+  return RTEMS_SUCCESSFUL;
+#ifdef RTEMS_SMP
+BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
+  while ((dist->icddcr & GIC_DIST_ICDDCR_ENABLE) == 0) {
+    /* Wait */
+#error modify init_cpu_interface to use correct offsets for each CPU
+#endif
+rtems_status_code arm_gic_irq_set_priority(
+  uint8_t priority
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  if (bsp_interrupt_is_valid_vector(vector)) {
+    if (vector < 32) {
+      sgi_ppi->icspiprior[vector] = priority;
+    } else {
+      gic_id_set_priority(dist, vector, priority);
+  } else {
+    sc = RTEMS_INVALID_ID;
+  return sc;
+rtems_status_code arm_gic_irq_get_priority(
+  uint8_t *priority
+      *priority = sgi_ppi->icspiprior[vector];
+    } else {
+      *priority = gic_id_get_priority(dist, vector);
+  } else {
+  return sc;
+void bsp_interrupt_set_affinity(
+  const Processor_mask *affinity
+  uint8_t targets = (uint8_t) _Processor_mask_To_uint32_t(affinity, 0);
+  gic_id_set_targets(dist, vector, targets);
+void bsp_interrupt_get_affinity(
+  Processor_mask *affinity
+  uint8_t targets = gic_id_get_targets(dist, vector);
+  _Processor_mask_From_uint32_t(affinity, targets, 0);
+  uint8_t targets
+  /* TODO(kmoore) Handle filter:
+   * ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
+   * ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_EXCEPT_SELF,
+   * ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF */
+  uint32_t mpidr = READ_SR(MPIDR);
+  uint64_t value = ICC_SGIR_AFFINITY3(MPIDR_AFFINITY3_GET(mpidr))
+                 | ICC_SGIR_AFFINITY2(MPIDR_AFFINITY2_GET(mpidr))
+                 | ICC_SGIR_INTID(vector)
+                 | ICC_SGIR_AFFINITY1(MPIDR_AFFINITY1_GET(mpidr))
+                 | ICC_SGIR_CPU_TARGET_LIST(1);
+  WRITE64_SR(ICC_SGI1, value);
2.11.0
