[PATCH] Add JSON log generation
Sat Aug 17 01:31:55 UTC 2019
On 17/8/19 12:49 am, Kinsey Moore wrote:
> This adds JSON log generation to the test infrastructure for consumption
> by automated processes or report generators.
Awesome change!! Thanks.
>  tester/rt/test.py | 66 +++++++++++++++++++++++++++++++++++++++++++++++++++++++
>  1 file changed, 66 insertions(+)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index da0a11e..1be8fca 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -38,6 +38,7 @@ import re
>  import sys
>  import threading
>  import time
> +import json
>  from rtemstoolkit import configuration
>  from rtemstoolkit import error
> @@ -227,6 +228,7 @@ def run(args, command_path = None):
>          optargs = { '--rtems-tools':    'The path to the RTEMS tools',
>                      '--rtems-bsp':      'The RTEMS BSP to run the test on',
>                      '--user-config':    'Path to your local user configuration INI file',
> +                    '--json-log':       'Path to JSON test output file',
Should this be format and a comma delimited list that defaults to 'txt'?
I am not sure a txt report can be or should be conditional so a
`--report-format` could default to nothing and then we can more format types, ie
XML.
>                      '--report-mode':    'Reporting modes, failures (default),all,none',
>                      '--list-bsps':      'List the supported BSPs',
>                      '--debug-trace':    'Debug trace based on specific flags (console,gdb,output,cov)',
> @@ -251,6 +253,17 @@ def run(args, command_path = None):
>              else:
>                  to_addr = 'build at rtems.org'
>              output = log_capture()
> +        json_log = None
> +        json_file = opts.find_arg('--json-log')
> +        if json_file is not None:
> +            if len(json_file) != 2:
> +                raise error.general('invalid RTEMS JSON log option')
> +            json_file = json_file[1]
> +            json_log = {}
> +            json_log['Command Line'] = " ".join(args)
> +            json_log['Python'] = sys.version.replace('\n', '')
> +            json_log['test_groups'] = []
> +            json_log['Host'] = host.label(mode = 'all')
Can the above fragment ...
>          log.notice('RTEMS Testing - Tester, %s' % (version.string()))
>          if opts.find_arg('--list-bsps'):
>              bsps.list(opts)
> @@ -360,6 +373,59 @@ def run(args, command_path = None):
>          total_time = 'Testing time     : %s' % (str(end_time - start_time))
>          log.notice(average_time)
>          log.notice(total_time)
> +        if json_log is not None:
> +            json_log['summary'] = {}
> +            json_log['summary']['passed_count'] = reports.passed
> +            json_log['summary']['failed_count'] = reports.failed
> +            json_log['summary']['user-input_count'] = reports.user_input
> +            json_log['summary']['expected-fail_count'] = reports.expected_fail
> +            json_log['summary']['indeterminate_count'] = reports.indeterminate
> +            json_log['summary']['benchmark_count'] = reports.benchmark
> +            json_log['summary']['timeout_count'] = reports.timeouts
> +            json_log['summary']['invalid_count'] = reports.invalids
> +            json_log['summary']['wrong-version_count'] = reports.wrong_version
> +            json_log['summary']['wrong-build_count'] = reports.wrong_build
> +            json_log['summary']['wrong-tools_count'] = reports.wrong_tools
> +            json_log['summary']['total_count'] = reports.total
> +            json_log['summary']['average_test_time'] = str((end_time - start_time) / total)
> +            json_log['summary']['testing_time'] = str(end_time - start_time)
> +            result_types = ['failed', 'user-input', 'expected-fail', 'indeterminate', 'benchmark', 'timeout', 'invalid', 'wrong-version', 'wrong-build', 'wrong-tools']
> +            json_results = {}
> +            for result_type in result_types:
> +                json_log['summary'][result_type] = []
> +            # collate results for JSON log
> +            for name in reports.results:
> +                result_type = reports.results[name]['result']
> +                test_parts = name.split("/")
> +                test_category = test_parts[-2]
> +                test_name = test_parts[-1]
> +                if result_type != 'passed':
> +                    json_log['summary'][result_type].append(test_name)
> +                if test_category not in json_results:
> +                    json_results[test_category] = []
> +                json_result = {}
> +                # remove the file extension
> +                json_result["name"] = test_name.split('.')[0]
> +                json_result["result"] = result_type
> +                if result_type == "failed" or result_type == "timeout":
> +                    json_result["output"] = reports.results[name]["output"]
> +                json_results[test_category].append(json_result)
> +            # convert results to a better format for report generation
> +            sorted_keys = sorted(json_results.keys())
> +            for i in range(len(sorted_keys)):
> +                results_log = {}
> +                results_log["index"] = i + 1
> +                results_log["name"] = sorted_keys[i]
> +                results_log["results"] = json_results[sorted_keys[i]]
> +                json_log["test_groups"].append(results_log)
> +            # write out JSON log
> +            with open(json_file, 'w') as outfile:
> +                json.dump(json_log, outfile, sort_keys=True, indent=4)
... and this be moved into a couple of functions to separate the logic? In time
they could become a format class and we have instances of them. I am not asking
for this now but it would make that sort of change a bit simpler.
>          if mail is not None and output is not None:
>              m_arch = opts.defaults.expand('%{arch}')
>              m_bsp = opts.defaults.expand('%{bsp}')
