Mounting/Accessing SD-Card on BBB
Christian Mauderer list at c-mauderer.de
Sat Aug 17 11:34:50 UTC 2019
Hello Nils,
"sometimes" sounds odd. That needs a difference on each run. Do you use
a shell command to open the file (so that there is a timing difference)?
Some guesses for typical "sometimes" problems:
- Do you have some pointer problem (use of an uninitialized one,
unhandled error cases for functions that return pointers, ...)?
Initialize all local pointer variables with NULL to get reproduceable
results.
- Are there some big stack variables (local arrays with sizes > 100
Byte)? Maybe your stack is too small and overflows.
Best regards
Christian
On 17/08/2019 12:11, Nils Hölscher wrote:
> Hi,
> I have a new BBB now, but the problem still persists.
> So my guess about the broken SD Card slot, causing the problem, was wrong.
> The other thing is that I am not always able to recreate the problem.
> Sometimes rtems freezes on the open call for the file on the SD.
> And when it passes that line, my program fails using mmap on the
> returned file descriptor.
> Best,
> Nils
> On Fri, 16 Aug 2019 at 16:28, Nils Hölscher <nilhoel1 at gmail.com
> <mailto:nilhoel1 at gmail.com>> wrote:
>     Hi Gerade,
>     Yes I checked with two cards and both are working fine on Linux.
>     Best,
>     Nils
>     Gedare Bloom <gedare at rtems.org <mailto:gedare at rtems.org>> schrieb am
>     Fr., 16. Aug. 2019, 16:25:
>         On Fri, Aug 16, 2019 at 6:04 AM Christian Mauderer
>         <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>         > Hello Nils,
>         > you are right that system freezes are not a wanted behaviour. But
>         > hot-plugging a disk isn't that common in embedded systems
>         (except maybe
>         > for USB drives). It's a case that isn't tested that often. So most
>         > likely no one noticed that bug. I wouldn't see it critical as
>         long as I
>         > don't have a project where I need that (either hobby or funded).
>         +1
>         > Is this a blocking problem for your project? If not you might
>         want to
>         > fill a bug report for this. But I suspect that no one will
>         work on that
>         > too fast as long as there is no urgent necessity.
>         > Note that if it would have been a FAT bug the situation would
>         have been
>         > quite different. FAT bugs are bad for all targets and for
>         quite some
>         > funded projects too. So I would have tried to fix that as soon
>         as possible.
>         > Best regards
>         > Christian
>         > On 16/08/2019 12:08, Nils Hölscher wrote:
>         > > Ok.
>         > > But back to the bug.
>         > > The behaviour I described should be reproducible by removing
>         SD-Card
>         > > after it was mounted.
>         > > And then the System should freeze when open is called on
>         some file on
>         > > SD-Card.
>         > > System freezes can't be wanted behaviour.
>         We have occasionally received bug reports like this. It is better to
>         avoid unplugging something that is being accessed. Even in commodity
>         systems that can cause data corruption on the device. In fact,
>         did you
>         confirm with a new SDcard that it is the BBB that is broken, and not
>         the SDCard that has gone bad?
>         > > Best,
>         > > Nils
>         > > On Fri, 16 Aug 2019 at 11:40, Christian Mauderer
>         > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>         > >     PS: If neither the SD nor the eMMC has a bootable image
>         your BBB falls
>         > >     back to serial and then USB boot anyway. So no need to
>         change any
>         > >     boot pins.
>         > >     On 16/08/2019 11:38, Christian Mauderer wrote:
>         > >     > Hello Nils,
>         > >     > if the U-Boot doesn't start from eMMC any more it
>         won't be easy.
>         > >     > Theoretically it is possible to boot via serial. See
>         for example
>          http://linuxkernel51.blogspot.com/2015/08/booting-beagle-bone-black-over-uart.html
>         > >     > With that you could load an U-Boot (via X-Modem) that
>         could start a
>         > >     > system from USB (image from Beagle home page maybe
>         could work if
>         > >     it can
>         > >     > boot from USB) that could re-write the eMMC. Most
>         likely it would
>         > >     need a
>         > >     > few hours to a day to figure out the details. So you
>         should
>         > >     definitively
>         > >     > order a replacement as a backup solution.
>         > >     > Best regards
>         > >     > Christian
>         > >     > On 16/08/2019 11:13, Nils Hölscher wrote:
>         > >     >> Hi Christin,
>         > >     >> Thanks for the hint.
>         > >     >> But how can I alter the U- Boot on eMMC?
>         > >     >> Problem is I have a Linux version with an U-Boot that
>         disables
>         > >     emmc on
>         > >     >> the emmc...
>         > >     >> And I guess I cant flash emmc without SD.
>         > >     >> Best,
>         > >     >> Nils
>         > >     >> On Fri, 16 Aug 2019 at 11:03, Christian Mauderer
>         > >     >> <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de>>>> wrote:
>         > >     >>     On 16/08/2019 10:55, Nils Hölscher wrote:
>         > >     >>     > Hi,
>         > >     >>     > It seems the problem was hardware related.
>         > >     >>     > My SD-Card connector just died.
>         > >     >>     > I hope I can get a new BBB oin a timely manner.
>         > >     >>     > Best,
>         > >     >>     > Nils
>         > >     >>     Hello Nils,
>         > >     >>     thanks for the information. That's annoying. Good
>         luck finding a
>         > >     >>     replacement.
>         > >     >>     For a quick workaround: I haven't tried that yet
>         but if your
>         > >     on-board
>         > >     >>     eMMC is still intact, you might can use that
>         U-Boot to boot
>         > >     from USB.
>         > >     >>     Best regards
>         > >     >>     Christian
>         > >     >>     > On Fri, 16 Aug 2019 at 10:48, Christian Mauderer
>         > >     >>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>         > >     >>     > <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>         > >     >>     >     Hello Nils,
>         > >     >>     >     thanks for the file list. I can't reproduce
>         your
>         > >     problem with it.
>         > >     >>     >     On 16/08/2019 10:01, Nils Hölscher wrote:
>         > >     >>     >     > Hi,
>         > >     >>     >     > Short update.
>         > >     >>     >     > It seems the device only hangs while I am
>         connected
>         > >     with the
>         > >     >>     debugger.
>         > >     >>     >     Is that true for the original file system
>         tree? You are
>         > >     >>     debugging via
>         > >     >>     >     Ethernet, right? In that case I would lean
>         more toward a
>         > >     >>     problem with
>         > >     >>     >     the debugger support than the file system.
>         Do you have
>         > >     enough file
>         > >     >>     >     descriptors configured?
>         > >     >>     >     Best regards
>         > >     >>     >     Christian
>         > >     >>     >     > looks like a Heisenberg bug.
>         > >     >>     >     > Best,
>         > >     >>     >     > Nils
>         > >     >>     >     > On Fri, 16 Aug 2019 at 09:50, Nils Hölscher
>         > >     >>     <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>
>         > >     >>     >     <mailto:nilhoel1 at gmail.com
>         <mailto:nilhoel1 at gmail.com> <mailto:nilhoel1 at gmail.com
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>
>         > >     >>     >     > <mailto:nilhoel1 at gmail.com
>         > >     >>     <mailto:nilhoel1 at gmail.com
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>> wrote:
>         > >     >>     >     >     On Thu, 15 Aug 2019 at 19:51,
>         Christian Mauderer
>         > >     >>     >     <list at c-mauderer.de
>         > >     >>     >     >     <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>         > >     >>     >     >         Hello Nils,
>         > >     >>     >     >         maybe another bug in our FAT file
>         system...
>         > >     >>     >     >         Please do three things:
>         > >     >>     >     >         1. Create an image of your
>         current card (with
>         > >     dd or
>         > >     >>     a similar
>         > >     >>     >     >         tool). FAT
>         > >     >>     >     >         bugs are sometimes hard to
>         reproduce but it's
>         > >     really
>         > >     >>     >     urgent that
>         > >     >>     >     >         we fix
>         > >     >>     >     >         them. So maybe I'll ask for that
>         image later.
>         > >     >>     >     >     I did that.
>         > >     >>     >     >     Let me know if you need the image.
>         > >     >>     >     >         2. Create a complete list of the
>         files on
>         > >     your card (for
>         > >     >>     >     example the
>         > >     >>     >     >         Linux `tree -h` command), post it
>         here and
>         > >     tell me
>         > >     >>     what you
>         > >     >>     >     >         tried to open.
>         > >     >>     >     >     ├── [ 50K]  am335x-boneblack.dtb
>         > >     >>     >     >     ├── [ 49K]  am335x-boneblack+pruss.dtb
>         > >     >>     >     >     ├── [ 883]  AM335X-PRU-UIO-00A0.dtbo
>         > >     >>     >     >     ├── [ 649]  AM335X-PRU-UIO-BSD-00A0.dtbo
>         > >     >>     >     >     ├── [162K]  Linux-with-UIO.dtb
>         > >     >>     >     >     ├── [  44]  loob.bin
>         > >     >>     >     >     ├── [108K]  MLO
>         > >     >>     >     >     ├── [2.1M]  pru.exe.img
>         > >     >>     >     >     ├── [  12]  test.bin
>         > >     >>     >     >     ├── [471K]  u-boot.img
>         > >     >>     >     >     ├── [ 390]  uEnvLinuxfdt.txt
>         > >     >>     >     >     └── [ 560]  uEnv.txt
>         > >     >>     >     >          3. Try another name / folder for
>         the file
>         > >     you wanted to
>         > >     >>     >     open.\
>         > >     >>     >     >     I moved the file in another folder
>         and renamed it.
>         > >     >>     >     >     It now works but I got en error, I am
>         currently
>         > >     >>     investigating if
>         > >     >>     >     >     this is on the pru driver side or not.
>         > >     >>     >     >     The tree while doing this was:
>         > >     >>     >     >     ├── [2.0K]  test
>         > >     >>     >     >     │   └── [  12]  test2.bin
>         > >     >>     >     >     ├── [  12]  test2.bin
>         > >     >>     >     >     Thanks,
>         > >     >>     >     >     Nils
>         > >     >>     >     >         Best regards
>         > >     >>     >     >         Christian
>         > >     >>     >     >         On 15/08/2019 19:32, Nils
>         Hölscher wrote:
>         > >     >>     >     >         > Hi Christian,
>         > >     >>     >     >         > The commands ls and cat work.
>         > >     >>     >     >         > I just tested them, this seems
>         kinda awkward.
>         > >     >>     >     >         > Best,
>         > >     >>     >     >         > Nils
>         > >     >>     >     >         > On Thu, 15 Aug 2019 at 19:27,
>         Christian
>         > >     Mauderer
>         > >     >>     >     >         <list at c-mauderer.de
>         > >     >>     >     >         > <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
>         > >     >>     >     >         >     Hello Nils,
>         > >     >>     >     >         >     does some other access to
>         the file system
>         > >     >>     work? Like
>         > >     >>     >     a ls
>         > >     >>     >     >         on the console
>         > >     >>     >     >         >     or creating a file. Can you
>         do a `cat`
>         > >     on some
>         > >     >>     text file
>         > >     >>     >     >         on the file
>         > >     >>     >     >         >     system? If not: Does it
>         work for a file
>         > >     in the
>         > >     >>     root file
>         > >     >>     >     >         system (should
>         > >     >>     >     >         >     be a IMFS)?
>         > >     >>     >     >         >     Best regards
>         > >     >>     >     >         >     Christian
>         > >     >>     >     >         >     On 15/08/2019 15:54, Nils
>         Hölscher wrote:
>         > >     >>     >     >         >     > Hi,
>         > >     >>     >     >         >     > I when my app wants to
>         open a file on
>         > >     the SD
>         > >     >>     card
>         > >     >>     >     >         dev=mmcsd-0-0 rtems
>         > >     >>     >     >         >     > freezes.
>         > >     >>     >     >         >     > Exact call is:
>         > >     >>     >     >         >     > fd = open(file, O_RDONLY);
>         > >     >>     >     >         >     > With file being the pru
>         binary I want
>         > >     to upload.
>         > >     >>     >     >         >     > Thanks,
>         > >     >>     >     >         >     > Nils
>         > >     >>     >     >         >     > On Tue, 13 Aug 2019 at 17:56,
>         > >     Christian Mauderer
>         > >     <christian.mauderer at embedded-brains.de
>         <mailto:christian.mauderer at embedded-brains.de>
>         <mailto:christian.mauderer at embedded-brains.de>>
>         > >     >>     <mailto:christian.mauderer at embedded-brains.de
>         <mailto:christian.mauderer at embedded-brains.de>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>>>> wrote:
>         > >     >>     >     >         >     >     Hello Nils,
>         > >     >>     >     >         >     >     a third possibility:
>         You could
>         > >     start a
>         > >     >>     FTP server
>         > >     >>     >     >         and push the
>         > >     >>     >     >         >     file
>         > >     >>     >     >         >     >     via network.
>         > >     >>     >     >         >     >     Best regards
>         > >     >>     >     >         >     >     Christian
>         > >     >>     >     >         >     >     Am Dienstag, 13.
>         August 2019
>         > >     schrieb Nils
>         > >     >>     >     Hölscher:
>         > >     >>     >     >         >     >     > Hi,
>         > >     >>     >     >         >     >     > Thanks for the
>         input I will try
>         > >     the SD
>         > >     >>     card
>         > >     >>     >     first.
>         > >     >>     >     >         >     >     > That way I won't
>         have to alter the
>         > >     >>     code when I
>         > >     >>     >     >         want to run other
>         > >     >>     >     >         >     >     stuff on the pru.
>         > >     >>     >     >         >     >     > Best,
>         > >     >>     >     >         >     >     > Nils
>         > >     >>     >     >         >     >     > On Tue, 13 Aug 2019
>         at 17:32,
>         > >     Gedare Bloom
>         > >     >>     >     >         <gedare at rtems.org
>         <mailto:gedare at rtems.org> <mailto:gedare at rtems.org
>         > >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>
>         > >     >>     <mailto:gedare at rtems.org
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>
>         > >     >>     >     <mailto:gedare at rtems.org
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>
>         > >     >>     >     >         >     <mailto:gedare at rtems.org
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>
>         > >     >>     >     >         <mailto:gedare at rtems.org
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>> wrote:
>         > >     >>     >     >         >     >     > You can also build
>         the PRU
>         > >     image into
>         > >     >>     the RTEMS
>         > >     >>     >     >         binary. See
>         examples-v2.git/file_io/crc/init.c
>         > >     >>     >     >         >     >     > On Tue, Aug 13,
>         2019 at 8:46 AM
>         > >     Christian
>         > >     >>     >     Mauderer
>         > >     >>     >     >         >     >     <list at c-mauderer.de
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>> wrote:
>         > >     >>     >     >         >     >     > > Hello Nils,
>         > >     >>     >     >         >     >     > > that's a bit odd.
>         I attached
>         > >     an expected
>         > >     >>     >     output
>         > >     >>     >     >         below.
>         > >     >>     >     >         >     Some guesses:
>         > >     >>     >     >         >     >     > > - Did you add FAT
>         file system
>         > >     to your
>         > >     >>     >     application?
>         > >     >>     >     >         >     >     > > - Is there some
>         odd formatting on
>         > >     >>     the SD?
>         > >     >>     >     >         Normally at
>         > >     >>     >     >         >     least the FAT
>         > >     >>     >     >         >     >     > > partition used by
>         U-Boot
>         > >     should be
>         > >     >>     visible.
>         > >     >>     >     >         >     >     > > - Is your BDBUF
>         configuration OK?
>         > >     >>     >     >         >     >     > > - Do you have
>         enough file
>         > >     descriptors?
>         > >     >>     >     >         >     >     > > Beneath that: If
>         you only need
>         > >     >>     something where
>         > >     >>     >     >         you can put
>         > >     >>     >     >         >     some
>         > >     >>     >     >         >     >     files,
>         > >     >>     >     >         >     >     > > you can try to
>         connect a USB
>         > >     stick
>         > >     >>     instead.
>         > >     >>     >     >         Maybe that
>         > >     >>     >     >         >     works better.
>         > >     >>     >     >         >     >     > > Best regards
>         > >     >>     >     >         >     >     > > Christian
>         > >     >>     >     >         >     >     > > media listener:
>         event = DISK
>         > >     ATTACH,
>         > >     >>     state =
>         > >     >>     >     >         INQUIRY, src
>         > >     >>     >     >         >     = mmcsd
>         event = DISK
>         > >     ATTACH,
>         > >     >>     state =
>         > >     >>     >     >         SUCCESS, src =
>         > >     >>     >     >         >     >     mmcsd, dest
>         > >     >>     >     >         >     >     > > = /dev/mmcsd-0
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     INQUIRY,
>         > >     >>     >     >         src =
>         > >     >>     >     >         >     /dev/mmcsd-0
>         > >     >>     >     >         >     >     > > mmcsd0: 4GB <SDHC
>         TO 15.15 SN
>         > >     >>     000002F6 MFG
>         > >     >>     >     >         02/2017 by 25
>         > >     >>     >     >         >     DY> at mmc0
>         24.0MHz/4bit/65535-block
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     FAILED, src =
>         event = PARTITION
>         > >     >>     INQUIRY,
>         > >     >>     >     state =
>         > >     >>     >     >         >     INQUIRY, src =
>         > >     >>     >     >         >     >     > > /dev/mmcsd-0
>         event = PARTITION
>         > >     >>     INQUIRY,
>         > >     >>     >     state =
>         > >     >>     >     >         >     SUCCESS, src =
>         event = PARTITION
>         > >     >>     ATTACH,
>         > >     >>     >     state
>         > >     >>     >     >         = INQUIRY,
>         > >     >>     >     >         >     src =
>         event = PARTITION
>         > >     >>     ATTACH,
>         > >     >>     >     state
>         > >     >>     >     >         = SUCCESS,
>         > >     >>     >     >         >     src =
>         > >     >>     >     >         >     >     > > /dev/mmcsd-0, dest =
>         > >     /dev/mmcsd-0-0
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     INQUIRY,
>         > >     >>     >     >         src =
>         > >     >>     >     >         >     /dev/mmcsd-0-0
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     SUCCESS,
>         > >     >>     >     >         src =
>         > >     >>     >     >         >     >     /dev/mmcsd-0-0,
>         > >     >>     >     >         >     >     > > dest =
>         /media/mmcsd-0-0
>         event = DISK
>         > >     ATTACH,
>         > >     >>     state =
>         > >     >>     >     >         INQUIRY, src
>         > >     >>     >     >         >     = mmcsd
>         event = DISK
>         > >     ATTACH,
>         > >     >>     state =
>         > >     >>     >     >         >     >     > > = /dev/mmcsd-1
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     INQUIRY,
>         > >     >>     >     >         src =
>         > >     >>     >     >         >     /dev/mmcsd-1
>         > >     >>     >     >         >     >     > > mmcsd1: 4GB
>         <MMCHC MMC04G 5.8 SN
>         > >     >>     160D224B MFG
>         > >     >>     >     >         09/2014 by 112
>         > >     >>     >     >         >     >     0x0000> at
>         > >     >>     >     >         >     >     > > mmc1
>         48.0MHz/8bit/65535-block
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     FAILED, src =
>         event = PARTITION
>         > >     >>     INQUIRY,
>         > >     >>     >     state =
>         > >     >>     >     >         >     >     > > /dev/mmcsd-1
>         event = PARTITION
>         > >     >>     INQUIRY,
>         > >     >>     >     state
>         > >     >>     >     >         = FAILED,
>         > >     >>     >     >         >     src =
>         event = DISK
>         > >     ATTACH,
>         > >     >>     state =
>         > >     >>     >     >         INQUIRY, src =
>         > >     >>     >     >         >     >     mmcsd1boot
>         > >     >>     >     >         >     >     > > mmcsd1boot0: 2MB
>         partion 1 at
>         > >     mmcsd1
>         > >     >>     >     >         >     >     > > mmcsd1boot1: 2MB
>         partion 2 at
>         > >     mmcsd1
>         > >     >>     >     >         >     >     > > mmcsd1rpmb: 131kB
>         partion 3
>         > >     at mmcsd1
>         > >     >>     >     >         >     >     > > On 13/08/2019
>         13:30, Nils
>         > >     Hölscher
>         > >     >>     wrote:
>         > >     >>     >     >         >     >     > > > Hi,
>         > >     >>     >     >         >     >     > > > Thanks for the
>         help.
>         > >     >>     >     >         >     >     > > > I tried to use
>         your code, but I
>         > >     >>     always get
>         > >     >>     >     >         "ERROR: SD
>         > >     >>     >     >         >     could not be
>         > >     >>     >     >         >     >     > > > mounted after
>         timeout".
>         > >     >>     >     >         >     >     > > > Even after
>         raising the
>         > >     waiting time.
>         > >     >>     >     >         >     >     > > > The sources I
>         use start here:
>          https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
>         > >     >>     >     >         >     >     > > > And my uart
>         output is:
>         > >     >>     >     >         >     >     > > > waiting for SD...
>         > >     >>     >     >         >     >     > > > usbus0: 480Mbps
>         High Speed
>         > >     USB v2.0
>         > >     >>     >     >         >     >     > > > usbus1: 480Mbps
>         High Speed
>         > >     USB v2.0
>         > >     >>     >     >         >     >     > > > media listener:
>         event = DISK
>         > >     >>     ATTACH, state =
>         > >     >>     >     >         INQUIRY,
>         > >     >>     >     >         >     src = mmcsd
>         event = DISK
>         > >     >>     ATTACH, state =
>         > >     >>     >     >         >     >     > > > = /dev/mmcsd-0
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     >         >     >     > > > ugen0.1:
>         <Mentor Graphics
>         > >     OTG Root
>         > >     >>     HUB>
>         > >     >>     >     at usbus0
>         > >     >>     >     >         >     >     > > > ugen1.1:
>         <Mentor Graphics
>         > >     OTG Root
>         > >     >>     HUB>
>         > >     >>     >     at usbus1
>         > >     >>     >     >         >     >     > > > uhub0: <Mentor
>         Graphics OTG
>         > >     Root
>         > >     >>     HUB, class
>         > >     >>     >     >         9/0, rev
>         > >     >>     >     >         >     >     2.00/1.00, addr 1>
>         > >     >>     >     >         >     >     > > > on usbus0
>         > >     >>     >     >         >     >     > > > uhub1: <Mentor
>         Graphics OTG
>         > >     Root
>         > >     >>     HUB, class
>         > >     >>     >     >         9/0, rev
>         > >     >>     >     >         >     >     > > > on usbus1
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     FAILED,
>         > >     >>     >     >         src =
>         event =
>         > >     PARTITION
>         > >     >>     >     INQUIRY, state =
>         > >     >>     >     >         >     >     > > > /dev/mmcsd-0
>         event =
>         > >     PARTITION
>         event =
>         > >     PARTITION
>         > >     >>     >     ATTACH, state =
>         event =
>         > >     PARTITION
>         > >     >>     >     >         >     >     > > > /dev/mmcsd-0,
>         dest =
>         > >     /dev/mmcsd-0-0
>         event =
>         > >     MOUNT, state =
>         event =
>         > >     MOUNT, state =
>         > >     >>     >     FAILED,
>         > >     >>     >     >         src =
>         event = DISK
>         > >     >>     ATTACH, state =
>         > >     >>     >     >         INQUIRY,
>         event = DISK
>         > >     >>     ATTACH, state =
>         > >     >>     >     >         >     >     > > > = /dev/mmcsd-1
