Checksum Error on Leon3 Qemu patches
Jiri Gaisler
jiri at gaisler.se
Sat Aug 17 18:07:18 UTC 2019
On 8/16/19 11:03 PM, Juan Rafael García Blanco wrote:
> Hi,
> AFAIK, the last qemu major version includes support for leon3. But I
> dont't know if that work was based on these patches.
Indeed. Qemu git head now includes leon3 plug&play and should be able to
run RTEMS images unpatched. Is there a reason why the qemu version built
by RSB is from June 2015 ..?
Jiri.
> Regards,
> Juan.
> On Fri, Aug 16, 2019, 11:00 PM Jiri Gaisler <jiri at gaisler.se
> <mailto:jiri at gaisler.se>> wrote:
> On 8/15/19 12:09 AM, Joel Sherrill wrote:
> > On Wed, Aug 14, 2019 at 4:42 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> >> On 15/8/19 12:46 am, Joel Sherrill wrote:
> >>> Qemu isn't building due to a checksum error.
> >>> These patches are at gaisler.org <http://gaisler.org>. I don't
> know where to move them but
> >>> eventually they should be moved.
> >> You can post them to qemu's patchworks and then get them from
> there. The RSB
> >> supports fetching from patchworks.
> > Jiri: Are these already on patchworks by any chance?
> Not that I am aware of. The checksum probably changed because the
> original patches were lost during a server rehost, and I recovered
> some earlier version from a backup disk. The patches do not apply
> cleanly to the latest version of qemu:
> + /bin/cat
> /home/jiri/ibm/src/rtems/rtems-source-builder/bare/patches/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
> + /usr/bin/patch -p1
> patching file hw/sparc/Makefile.objs
> patching file hw/sparc/grlib_ambapnp.c
> patching file hw/sparc/leon3.c
> Hunk #1 succeeded at 207 (offset -7 lines).
> patching file include/hw/sparc/grlib.h
> Hunk #1 FAILED at 117.
> 1 out of 1 hunk FAILED -- saving rejects to file
> include/hw/sparc/grlib.h.rej
> Could be that qemu has moved since the patches were make, I will
> try to take a look ...
> Jiri.
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190817/17f0c082/attachment.html>
