Mounting/Accessing SD-Card on BBB
Christian Mauderer list at c-mauderer.de
Sun Aug 18 12:45:51 UTC 2019
Hello Nils,
please note: I re-added the devel list (wasn't this thread originally on
users?). I hope that is OK.
On 18/08/2019 13:23, Nils Hölscher wrote:
> Hello Christian,
> On Sat, 17 Aug 2019 at 15:30, Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     On 17/08/2019 15:11, Nils Hölscher wrote:
>     > HI Christian,
>     > This was very helpful as always.
>     > But I think I didn't explain enough.
>     > The PRU driver runs just fine I was able to load code onto pru and
>     wait
>     > for its return via interrupt.
>     > I could also show that it runs the exact expected amount of time.
>     > So no problem there.
>     Great if that works.
>     > The other thing I am trying and where I fail is:
>     > First I route interrupts to a file.
>     > With these four commands:
>     > sysctl dev.ti_pruss.0.irq.2.channel=2 # mapping channel 2 to irq2
>     > sysctl dev.ti_pruss.0.irq.2.event=16 # mapping event 16 to irq2
>     > sysctl dev.ti_pruss.0.irq.2.enable=1 # enable the irq2
>     > sysctl dev.ti_pruss.0.global_interrupt_enable=1 # enable PRU global
>     > interrupts
>     > After that I get the device /dev/pruss0.irq2.
>     > And I want to read the interrupts from this file with the code you
>     saw.
>     If i understood the interface correctly you should get a read that is
>     blocking till the next interrupt?
>     I had a quick look at the ti_pruss_irq_read in the FreeBSD version that
>     is used as base for our current libbsd. There is a case for O_NONBLOCK:
>     https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L254
>     You might try that one to make sure nothing odd happens with the
>     blocking version. Maybe libbsd handles something different compared to
>     FreeBSD and the driver doesn't expect it.
> The thing is this function gets mapped to the device that is created
> with the sysctl command.
> The ti_pruss_irq_read function is part of this struct.
> https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L116
> And is mapped to the Pruss0.irqN device with ti_pruss_interrupts_enable:
> https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L313
> And this function is called by sysctl and get registered here:
> https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L573
Yes. That looks OK. You get the file so the device is added correctly.
> But when I wanted to debug with a breakpoint set to ti_pruss_irq_read,
> rtems crashed before calling this function, that should be mapped to the
> device.
> With this Backtrace:
> (gdb) backtrace
> #0  strcmp ()
>     at
> ../../../../../../gnu-mirror-gcc-fb371a33fa6/newlib/libc/machine/arm/strcmp-armv4.S:70
> #1  0x802a94d4 in rtems_shell_lookup_cmd (
>     cmd=0x20 <error: Cannot access memory at address 0x20>)
At this point it seems that there is already a problem with your shell
command. The function should get a `const char *` pointer. Your pointer
currently points to 0x20 which is definitively no memory location. Most
likely you'll get an exception as soon as this pointer is passed to the
strcmp.
>     at
> /home/nils/development/src/rtems/c/src/../../cpukit/libmisc/shell/shell_cmdset.c:99
> #2  0x802a9740 in rtems_shell_execute_cmd (
>     cmd=0x802f3a5c "cat", argc=2, argv=0x80920001)
>     at
> /home/nils/development/src/rtems/c/src/../../cpukit/libmisc/shell/shell_cmdset.c:252
> #3  0x8000069c in testirq (argc=<optimized out>,
>     argv=<optimized out>) at ../../main.c:247
> --Type <RET> for more, q to quit, c to continue without paging--
What is this `testirq` function? From the name I would expect that it is
your shell command. But why does it call rtems_shell_execute_cmd as it's
next function?
If it is correct for some reason: Please check the argv that you pass to
rtems_shell_execute_cmd(). The 0x20 in #1 looks suspiciously like a
ASCII space character. Maybe you passed argv[1] instead of &argv[1] or
*argv instead of argv to the cat function?
> #4  0x802a8a80 in rtems_shell_main_loop (
>     shell_env_arg=<optimized out>)
>     at
> /home/nils/development/src/rtems/c/src/../../cpukit/libmisc/shell/shell.c:921
> #5  0x802a932c in rtems_shell_task (
>     task_argument=<optimized out>)
>     at
> /home/nils/development/src/rtems/c/src/../../cpukit/libmisc/shell/shell.c:678
> #6  0x8029e0fc in _Thread_Handler ()
>     at
> /home/nils/development/src/rtems/c/src/../../cpukit/score/src/threadhandler.c:135
> #7  0x8029deec in _Thread_Do_dispatch (
>     cpu_self=<optimized out>, level=<optimized out>)
>     at
> /home/nils/development/src/rtems/c/src/../../cpukit/score/src/threaddispatch.c:302
> #8  0x00000000 in ?? ()
>  I think rtems crashed before interacting with the device driver at all.
> Have a nice Sunday,
> Nils
>     Regarding the mmap for the non-interrupt files: It's a quite simple
>     function and it should work:
>     https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L701
>     > Obviously the interrupts are triggered by code on the PRU.
>     > This is the proof of concept FreeBSD used.
>     > https://reviews.freebsd.org/D11959
>     > But maybe the test I already ran is proof enough.
>     Please discuss that with your mentor.
>     > And this could also be a problem with the sysctl command.
>     As far as I understood it you get the file after you run a bunch of
>     sysctl commands? So it seems that this works.
>     > Best,
>     > Nils
>     > On Sat, 17 Aug 2019 at 14:59, Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >     Hello Nils,
>     >     On 17/08/2019 14:04, Nils Hölscher wrote:
>     >     > On Sat, 17 Aug 2019 at 13:34, Christian Mauderer
>     >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>     >     >     Hello Nils,
>     >     >     "sometimes" sounds odd. That needs a difference on each run.
>     >     Do you use
>     >     >     a shell command to open the file (so that there is a timing
>     >     difference)?
>     >     > Yes I do.
>     >     > I was able to load the code to the pru as arrays, cause the pru
>     >     > assembler "pasm" can output header files.
>     >     > So I am no longer working with SD-Card.
>     >     So you have a workaround. That's good.
>     >     >     Some guesses for typical "sometimes" problems:
>     >     >     - Do you have some pointer problem (use of an
>     uninitialized one,
>     >     >     unhandled error cases for functions that return
>     pointers, ...)?
>     >     >     Initialize all local pointer variables with NULL to get
>     >     reproduceable
>     >     >     results.
>     >     > I am just using these few lines of code to show the IRQ
>     interrupts of
>     >     > the PRU test programm.
>     >     > I dont' know what I shall set to NULL.
>     >     > int testirq( int argc, char* argv[] )
>     >     >     int fd = 0;
>     >     There's a check missing whether argc is >= 2. But that
>     shouldn't be the
>     >     problem as long as you pass a parameter.
>     >     >     printf("opening of %s ", argv[1]);
>     >     >     fd = open( argv[1], O_RDONLY);
>     >     >     if (fd == -1)
>     >     >         perror("open");
>     >     >     for(;;)
>     >     >         uint64_t time;
>     >     >         //printk("=== read file\n");
>     >     >         while( read(fd, &time, sizeof(time)) > 0 )
>     >     Although not your problem. But is this a blocking read till
>     you get
>     >     something? Otherwise you'll get a lot of prints with random
>     values.
>     >     >             printk("=> %llu.%09llu \n",
>     >     time/1000000000,time%1000000000);
>     >     >     close(fd);
>     >     >     return EXIT_SUCCESS;
>     >     >     - Are there some big stack variables (local arrays with
>     sizes
>     >     > 100
>     >     >     Byte)? Maybe your stack is too small and overflows.
>     >     > I thought that too and I don't use big objects and even
>     doubled my
>     >     Stack
>     >     > size just to be sure.
>     >     > The mention Arrays containing PRUcode are also just in the
>     length
>     >     of 10.
>     >     OK. Was just a guess.
>     >     You say something of an interrupt that you expect. Maybe a
>     priority
>     >     problem? I'm still guessing a bit about the application but I
>     would
>     >     expect something like the following:
>     >     - You load some code into your PRUs.
>     >     - The PRU causes an interrupt.
>     >     - That is processed via the libbsd PRU driver?
>     >     - In that case: An interrupt server with high priority will
>     process the
>     >     interrupt.
>     >     If the interrupt flags are not handled correctly, the
>     interrupt maybe is
>     >     triggered again after the interrupt routine finishes. In that
>     case you
>     >     jump between interrupt and interrupt server which both have a
>     higher
>     >     priority than your shell. Your system wouldn't react to any
>     user input
>     >     any more. It would "hang".
>     >     That mmap fails can have different reasons. We can only do
>     very simple
>     >     mmaps in RTEMS. Basically if the driver tries to do anything
>     more but
>     >     passing an pointer it won't work. So check whether your driver
>     tries
>     >     something like mapping memory to some new location.
>     >     Best regards
>     >     Christian
>     >     > Thanks,
>     >     > Nils
>     >     >     Best regards
>     >     >     Christian
>     >     >     On 17/08/2019 12:11, Nils Hölscher wrote:
>     >     >     > Hi,
>     >     >     > I have a new BBB now, but the problem still persists.
>     >     >     > So my guess about the broken SD Card slot, causing the
>     problem,
>     >     >     was wrong.
>     >     >     > The other thing is that I am not always able to
>     recreate the
>     >     problem.
>     >     >     > Sometimes rtems freezes on the open call for the file
>     on the SD.
>     >     >     > And when it passes that line, my program fails using
>     mmap on the
>     >     >     > returned file descriptor.
>     >     >     > Best,
>     >     >     > Nils
>     >     >     > On Fri, 16 Aug 2019 at 16:28, Nils Hölscher
>     >     <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>
>     >     >     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>
>     >     >     > <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>> wrote:
>     >     >     >     Hi Gerade,
>     >     >     >     Yes I checked with two cards and both are working fine
>     >     on Linux.
>     >     >     >     Best,
>     >     >     >     Nils
>     >     >     >     Gedare Bloom <gedare at rtems.org
>     <mailto:gedare at rtems.org> <mailto:gedare at rtems.org
>     <mailto:gedare at rtems.org>>
>     >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>
>     >     >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>> schrieb am
>     >     >     >     Fr., 16. Aug. 2019, 16:25:
>     >     >     >         On Fri, Aug 16, 2019 at 6:04 AM Christian Mauderer
>     >     >     >         <list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>     >     >     >         > Hello Nils,
>     >     >     >         > you are right that system freezes are not a
>     wanted
>     >     >     behaviour. But
>     >     >     >         > hot-plugging a disk isn't that common in
>     embedded
>     >     systems
>     >     >     >         (except maybe
>     >     >     >         > for USB drives). It's a case that isn't
>     tested that
>     >     >     often. So most
>     >     >     >         > likely no one noticed that bug. I wouldn't
>     see it
>     >     >     critical as
>     >     >     >         long as I
>     >     >     >         > don't have a project where I need that (either
>     >     hobby or
>     >     >     funded).
>     >     >     >         +1
>     >     >     >         > Is this a blocking problem for your project? If
>     >     not you
>     >     >     might
>     >     >     >         want to
>     >     >     >         > fill a bug report for this. But I suspect
>     that no
>     >     one will
>     >     >     >         work on that
>     >     >     >         > too fast as long as there is no urgent
>     necessity.
>     >     >     >         > Note that if it would have been a FAT bug the
>     >     situation
>     >     >     would
>     >     >     >         have been
>     >     >     >         > quite different. FAT bugs are bad for all
>     targets
>     >     and for
>     >     >     >         quite some
>     >     >     >         > funded projects too. So I would have tried
>     to fix that
>     >     >     as soon
>     >     >     >         as possible.
>     >     >     >         > Best regards
>     >     >     >         > Christian
>     >     >     >         > On 16/08/2019 12:08, Nils Hölscher wrote:
>     >     >     >         > > Ok.
>     >     >     >         > > But back to the bug.
>     >     >     >         > > The behaviour I described should be
>     reproducible by
>     >     >     removing
>     >     >     >         SD-Card
>     >     >     >         > > after it was mounted.
>     >     >     >         > > And then the System should freeze when open is
>     >     called on
>     >     >     >         some file on
>     >     >     >         > > SD-Card.
>     >     >     >         > > System freezes can't be wanted behaviour.
>     >     >     >         We have occasionally received bug reports like
>     this.
>     >     It is
>     >     >     better to
>     >     >     >         avoid unplugging something that is being accessed.
>     >     Even in
>     >     >     commodity
>     >     >     >         systems that can cause data corruption on the
>     >     device. In fact,
>     >     >     >         did you
>     >     >     >         confirm with a new SDcard that it is the BBB
>     that is
>     >     >     broken, and not
>     >     >     >         the SDCard that has gone bad?
>     >     >     >         > > Best,
>     >     >     >         > > Nils
>     >     >     >         > > On Fri, 16 Aug 2019 at 11:40, Christian
>     Mauderer
>     >     >     >         > > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>     >     >     >         > >     PS: If neither the SD nor the eMMC has a
>     >     bootable
>     >     >     image
>     >     >     >         your BBB falls
>     >     >     >         > >     back to serial and then USB boot
>     anyway. So
>     >     no need to
>     >     >     >         change any
>     >     >     >         > >     boot pins.
>     >     >     >         > >     On 16/08/2019 11:38, Christian
>     Mauderer wrote:
>     >     >     >         > >     > Hello Nils,
>     >     >     >         > >     > if the U-Boot doesn't start from
>     eMMC any
>     >     more it
>     >     >     >         won't be easy.
>     >     >     >         > >     > Theoretically it is possible to boot via
>     >     serial. See
>     >     >     >         for example
>         http://linuxkernel51.blogspot.com/2015/08/booting-beagle-bone-black-over-uart.html
>     >     >     >         > >     > With that you could load an U-Boot (via
>     >     X-Modem)
>     >     >     that
>     >     >     >         could start a
>     >     >     >         > >     > system from USB (image from Beagle home
>     >     page maybe
>     >     >     >         could work if
>     >     >     >         > >     it can
>     >     >     >         > >     > boot from USB) that could re-write the
>     >     eMMC. Most
>     >     >     >         likely it would
>     >     >     >         > >     need a
>     >     >     >         > >     > few hours to a day to figure out the
>     >     details. So you
>     >     >     >         should
>     >     >     >         > >     definitively
>     >     >     >         > >     > order a replacement as a backup
>     solution.
>     >     >     >         > >     > Best regards
>     >     >     >         > >     > Christian
>     >     >     >         > >     > On 16/08/2019 11:13, Nils Hölscher
>     wrote:
>     >     >     >         > >     >> Hi Christin,
>     >     >     >         > >     >> Thanks for the hint.
>     >     >     >         > >     >> But how can I alter the U- Boot on
>     eMMC?
>     >     >     >         > >     >> Problem is I have a Linux version
>     with an
>     >     >     U-Boot that
>     >     >     >         disables
>     >     >     >         > >     emmc on
>     >     >     >         > >     >> the emmc...
>     >     >     >         > >     >> And I guess I cant flash emmc
>     without SD.
>     >     >     >         > >     >> Best,
>     >     >     >         > >     >> Nils
>     >     >     >         > >     >> On Fri, 16 Aug 2019 at 11:03, Christian
>     >     Mauderer
>     >     >     >         > >     <list at c-mauderer.de
>     >     >     >         > >     >> <mailto:list at c-mauderer.de
>     >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>
>     >     >     wrote:
>     >     >     >         > >     >>     On 16/08/2019 10:55, Nils
>     Hölscher wrote:
>     >     >     >         > >     >>     > Hi,
>     >     >     >         > >     >>     > It seems the problem was hardware
>     >     related.
>     >     >     >         > >     >>     > My SD-Card connector just died.
>     >     >     >         > >     >>     > I hope I can get a new BBB
>     oin a timely
>     >     >     manner.
>     >     >     >         > >     >>     > Best,
>     >     >     >         > >     >>     > Nils
>     >     >     >         > >     >>     Hello Nils,
>     >     >     >         > >     >>     thanks for the information. That's
>     >     >     annoying. Good
>     >     >     >         luck finding a
>     >     >     >         > >     >>     replacement.
>     >     >     >         > >     >>     For a quick workaround: I
>     haven't tried
>     >     >     that yet
>     >     >     >         but if your
>     >     >     >         > >     on-board
>     >     >     >         > >     >>     eMMC is still intact, you might can
>     >     use that
>     >     >     >         U-Boot to boot
>     >     >     >         > >     from USB.
>     >     >     >         > >     >>     Best regards
>     >     >     >         > >     >>     Christian
>     >     >     >         > >     >>     > On Fri, 16 Aug 2019 at 10:48,
>     Christian
>     >     >     Mauderer
>     >     >     >         > >     >>     <list at c-mauderer.de
>     >     >     >         > >     >>     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>> wrote:
>     >     >     >         > >     >>     >     Hello Nils,
>     >     >     >         > >     >>     >     thanks for the file list.
>     I can't
>     >     >     reproduce
>     >     >     >         your
>     >     >     >         > >     problem with it.
>     >     >     >         > >     >>     >     On 16/08/2019 10:01, Nils
>     >     Hölscher wrote:
>     >     >     >         > >     >>     >     > Hi,
>     >     >     >         > >     >>     >     > Short update.
>     >     >     >         > >     >>     >     > It seems the device
>     only hangs
>     >     >     while I am
>     >     >     >         connected
>     >     >     >         > >     with the
>     >     >     >         > >     >>     debugger.
>     >     >     >         > >     >>     >     Is that true for the original
>     >     file system
>     >     >     >         tree? You are
>     >     >     >         > >     >>     debugging via
>     >     >     >         > >     >>     >     Ethernet, right? In that
>     case I
>     >     would
>     >     >     lean
>     >     >     >         more toward a
>     >     >     >         > >     >>     problem with
>     >     >     >         > >     >>     >     the debugger support than
>     the file
>     >     >     system.
>     >     >     >         Do you have
>     >     >     >         > >     enough file
>     >     >     >         > >     >>     >     descriptors configured?
>     >     >     >         > >     >>     >     Best regards
>     >     >     >         > >     >>     >     Christian
>     >     >     >         > >     >>     >     > looks like a Heisenberg
>     bug.
>     >     >     >         > >     >>     >     > Best,
>     >     >     >         > >     >>     >     > Nils
>     >     >     >         > >     >>     >     > On Fri, 16 Aug 2019 at
>     09:50,
>     >     Nils
>     >     >     Hölscher
>     >     >     >         > >     >>     <nilhoel1 at gmail.com
>     >     >     >         > >     <mailto:nilhoel1 at gmail.com
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>>
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>>>
>     >     >     >         > >     >>     <mailto:nilhoel1 at gmail.com
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>>>>> wrote:
>     >     >     >         > >     >>     >     >     On Thu, 15 Aug 2019
>     at 19:51,
>     >     >     >         Christian Mauderer
>     >     >     >         > >     >>     >     <list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>>> wrote:
>     >     >     >         > >     >>     >     >         Hello Nils,
>     >     >     >         > >     >>     >     >         maybe another
>     bug in our
>     >     >     FAT file
>     >     >     >         system...
>     >     >     >         > >     >>     >     >         Please do three
>     things:
>     >     >     >         > >     >>     >     >         1. Create an
>     image of
>     >     your
>     >     >     >         current card (with
>     >     >     >         > >     dd or
>     >     >     >         > >     >>     a similar
>     >     >     >         > >     >>     >     >         tool). FAT
>     >     >     >         > >     >>     >     >         bugs are sometimes
>     >     hard to
>     >     >     >         reproduce but it's
>     >     >     >         > >     really
>     >     >     >         > >     >>     >     urgent that
>     >     >     >         > >     >>     >     >         we fix
>     >     >     >         > >     >>     >     >         them. So maybe I'll
>     >     ask for
>     >     >     that
>     >     >     >         image later.
>     >     >     >         > >     >>     >     >     I did that.
>     >     >     >         > >     >>     >     >     Let me know if you need
>     >     the image.
>     >     >     >         > >     >>     >     >         2. Create a
>     complete list
>     >     >     of the
>     >     >     >         files on
>     >     >     >         > >     your card (for
>     >     >     >         > >     >>     >     example the
>     >     >     >         > >     >>     >     >         Linux `tree -h`
>     command),
>     >     >     post it
>     >     >     >         here and
>     >     >     >         > >     tell me
>     >     >     >         > >     >>     what you
>     >     >     >         > >     >>     >     >         tried to open.
>     >     >     >         > >     >>     >     >     ├── [ 50K]
>     >     am335x-boneblack.dtb
>     >     >     >         > >     >>     >     >     ├── [ 49K]
>     >     >     am335x-boneblack+pruss.dtb
>     >     >     >         > >     >>     >     >     ├── [ 883]
>     >     >     AM335X-PRU-UIO-00A0.dtbo
>     >     >     >         > >     >>     >     >     ├── [ 649]
>     >     >     AM335X-PRU-UIO-BSD-00A0.dtbo
>     >     >     >         > >     >>     >     >     ├── [162K]
>     >     Linux-with-UIO.dtb
>     >     >     >         > >     >>     >     >     ├── [  44]  loob.bin
>     >     >     >         > >     >>     >     >     ├── [108K]  MLO
>     >     >     >         > >     >>     >     >     ├── [2.1M]  pru.exe.img
>     >     >     >         > >     >>     >     >     ├── [  12]  test.bin
>     >     >     >         > >     >>     >     >     ├── [471K]  u-boot.img
>     >     >     >         > >     >>     >     >     ├── [ 390]
>     uEnvLinuxfdt.txt
>     >     >     >         > >     >>     >     >     └── [ 560]  uEnv.txt
>     >     >     >         > >     >>     >     >          3. Try another
>     name /
>     >     >     folder for
>     >     >     >         the file
>     >     >     >         > >     you wanted to
>     >     >     >         > >     >>     >     open.\
>     >     >     >         > >     >>     >     >     I moved the file in
>     >     another folder
>     >     >     >         and renamed it.
>     >     >     >         > >     >>     >     >     It now works but I
>     got en
>     >     >     error, I am
>     >     >     >         currently
>     >     >     >         > >     >>     investigating if
>     >     >     >         > >     >>     >     >     this is on the pru
>     driver
>     >     side
>     >     >     or not.
>     >     >     >         > >     >>     >     >     The tree while
>     doing this
>     >     was:
>     >     Linux-with-UIO.dtb
>     >     >     >         > >     >>     >     >     ├── [2.0K]  test
>     >     >     >         > >     >>     >     >     │   └── [  12]
>     test2.bin
>     >     >     >         > >     >>     >     >     ├── [  12]  test2.bin
>     uEnvLinuxfdt.txt
>     >     >     >         > >     >>     >     >     Thanks,
>     >     >     >         > >     >>     >     >     Nils
>     >     >     >         > >     >>     >     >         Best regards
>     >     >     >         > >     >>     >     >         Christian
>     >     >     >         > >     >>     >     >         On 15/08/2019
>     19:32, Nils
>     >     >     >         Hölscher wrote:
>     >     >     >         > >     >>     >     >         > Hi Christian,
>     >     >     >         > >     >>     >     >         > The commands
>     ls and
>     >     cat work.
>     >     >     >         > >     >>     >     >         > I just tested
>     them,
>     >     this
>     >     >     seems
>     >     >     >         kinda awkward.
>     >     >     >         > >     >>     >     >         > Best,
>     >     >     >         > >     >>     >     >         > Nils
>     >     >     >         > >     >>     >     >         > On Thu, 15
>     Aug 2019
>     >     at 19:27,
>     >     >     >         Christian
>     >     >     >         > >     Mauderer
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>>>> wrote:
>     >     >     >         > >     >>     >     >         >     Hello Nils,
>     >     >     >         > >     >>     >     >         >     does some
>     other
>     >     access to
>     >     >     >         the file system
>     >     >     >         > >     >>     work? Like
>     >     >     >         > >     >>     >     a ls
>     >     >     >         > >     >>     >     >         on the console
>     >     >     >         > >     >>     >     >         >     or
>     creating a file.
>     >     >     Can you
>     >     >     >         do a `cat`
>     >     >     >         > >     on some
>     >     >     >         > >     >>     text file
>     >     >     >         > >     >>     >     >         on the file
>     >     >     >         > >     >>     >     >         >     system?
>     If not:
>     >     Does it
>     >     >     >         work for a file
>     >     >     >         > >     in the
>     >     >     >         > >     >>     root file
>     >     >     >         > >     >>     >     >         system (should
>     >     >     >         > >     >>     >     >         >     be a IMFS)?
>     >     >     >         > >     >>     >     >         >     Best regards
>     >     >     >         > >     >>     >     >         >     Christian
>     >     >     >         > >     >>     >     >         >     On 15/08/2019
>     >     15:54, Nils
>     >     >     >         Hölscher wrote:
>     >     >     >         > >     >>     >     >         >     > Hi,
>     >     >     >         > >     >>     >     >         >     > I when
>     my app
>     >     wants to
>     >     >     >         open a file on
>     >     >     >         > >     the SD
>     >     >     >         > >     >>     card
>     >     >     >         > >     >>     >     >         dev=mmcsd-0-0 rtems
>     >     >     >         > >     >>     >     >         >     > freezes.
>     >     >     >         > >     >>     >     >         >     > Exact
>     call is:
>     >     >     >         > >     >>     >     >         >     > fd =
>     open(file,
>     >     >     O_RDONLY);
>     >     >     >         > >     >>     >     >         >     > With file
>     >     being the pru
>     >     >     >         binary I want
>     >     >     >         > >     to upload.
>     >     >     >         > >     >>     >     >         >     > Thanks,
>     >     >     >         > >     >>     >     >         >     > Nils
>     >     >     >         > >     >>     >     >         >     > On Tue, 13
>     >     Aug 2019
>     >     >     at 17:56,
>     >     >     >         > >     Christian Mauderer
>     >     >     >         > >     <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>
>     <mailto:christian.mauderer at embedded-brains.de>>
>     >     >     <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>
>     >     >     >         <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>>
>     <mailto:christian.mauderer at embedded-brains.de>>>>>
>     <mailto:christian.mauderer at embedded-brains.de>>>>>>
>     <mailto:christian.mauderer at embedded-brains.de>>>>>>>
>     <mailto:christian.mauderer at embedded-brains.de>>>>>>>>
>     <mailto:christian.mauderer at embedded-brains.de>>>>>>>>>
>     <mailto:christian.mauderer at embedded-brains.de>>>>>>>>>>> wrote:
>      Hello Nils,
>     >     >     >         > >     >>     >     >         >     >     a third
>     >     >     possibility:
>     >     >     >         You could
>     >     >     >         > >     start a
>     >     >     >         > >     >>     FTP server
>     >     >     >         > >     >>     >     >         and push the
>     >     >     >         > >     >>     >     >         >     file
>     >     >     >         > >     >>     >     >         >     >     via
>     network.
>      Best regards
>      Christian
>     >     >     >         > >     >>     >     >         >     >     Am
>     >     Dienstag, 13.
>     >     >     >         August 2019
>     >     >     >         > >     schrieb Nils
>     >     >     >         > >     >>     >     Hölscher:
>     >     >     >         > >     >>     >     >         >     >     > Hi,
>     Thanks
>     >     for the
>     >     >     >         input I will try
>     >     >     >         > >     the SD
>     >     >     >         > >     >>     card
>     >     >     >         > >     >>     >     first.
>     >     >     >         > >     >>     >     >         >     >     > That
>     >     way I won't
>     >     >     >         have to alter the
>     >     >     >         > >     >>     code when I
>     >     >     >         > >     >>     >     >         want to run other
>      stuff on
>     >     the pru.
>     >     >     >         > >     >>     >     >         >     >     > Best,
>     >     >     >         > >     >>     >     >         >     >     > Nils
>     On Tue, 13
>     >     >     Aug 2019
>     >     >     >         at 17:32,
>     >     >     >         > >     Gedare Bloom
>      <gedare at rtems.org <mailto:gedare at rtems.org>
>     >     >     >         <mailto:gedare at rtems.org
>     >     >     >         > >     <mailto:gedare at rtems.org
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>
>     >     >     >         > >     >>     <mailto:gedare at rtems.org
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>
>     >     >     >         > >     >>     >     <mailto:gedare at rtems.org
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>>
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>>>
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>>>>> wrote:
>     You can
>     >     also
>     >     >     build
>     >     >     >         the PRU
>     >     >     >         > >     image into
>     >     >     >         > >     >>     the RTEMS
>     >     >     >         > >     >>     >     >         binary. See
>     >     >     >         examples-v2.git/file_io/crc/init.c
>     On Tue,
>     >     Aug 13,
>     >     >     >         2019 at 8:46 AM
>     >     >     >         > >     Christian
>     >     >     >         > >     >>     >     Mauderer
>     >     >      <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>>>>> wrote:
>     Hello
>     >     Nils,
>     that's a
>     >     >     bit odd.
>     >     >     >         I attached
>     >     >     >         > >     an expected
>     >     >     >         > >     >>     >     output
>     >     >     >         > >     >>     >     >         below.
>     >     >     >         > >     >>     >     >         >     Some guesses:
>     - Did you
>     >     >     add FAT
>     >     >     >         file system
>     >     >     >         > >     to your
>     >     >     >         > >     >>     >     application?
>     - Is
>     >     there some
>     >     >     >         odd formatting on
>     >     >     >         > >     >>     the SD?
>     >     >     >         > >     >>     >     >         Normally at
>     >     >     >         > >     >>     >     >         >     least the FAT
>     partition
>     >     >     used by
>     >     >     >         U-Boot
>     >     >     >         > >     should be
>     >     >     >         > >     >>     visible.
>     - Is
>     >     your BDBUF
>     >     >     >         configuration OK?
>     - Do
>     >     you have
>     >     >     >         enough file
>     >     >     >         > >     descriptors?
>     Beneath
>     >     >     that: If
>     >     >     >         you only need
>     >     >     >         > >     >>     something where
>     >     >     >         > >     >>     >     >         you can put
>     >     >     >         > >     >>     >     >         >     some
>     >     >     >         > >     >>     >     >         >     >     files,
>     >     >     >         > >     >>     >     >         >     >     > > you
>     >     can try to
>     >     >     >         connect a USB
>     >     >     >         > >     stick
>     >     >     >         > >     >>     instead.
>     >     >     >         > >     >>     >     >         Maybe that
>     >     >     >         > >     >>     >     >         >     works better.
>     Best
>     >     regards
>     Christian
>     media
>     >     listener:
>     >     >     >         event = DISK
>     >     >     >         > >     ATTACH,
>     >     >     >         > >     >>     state =
>     >     >     >         > >     >>     >     >         INQUIRY, src
>     >     >     >         > >     >>     >     >         >     = mmcsd
>     media
>     >     listener:
>     >     >     >         event = DISK
>     >     >     >         > >     ATTACH,
>     >     >     >         > >     >>     state =
>     >     >     >         > >     >>     >     >         SUCCESS, src =
>      mmcsd, dest
>     >     /dev/mmcsd-0
>     media
>     >     listener:
>     >     >     >         event =
>     >     >     >         > >     MOUNT, state =
>     >     >     >         > >     >>     >     INQUIRY,
>     >     >     >         > >     >>     >     >         src =
>     >     >     >         > >     >>     >     >         >     /dev/mmcsd-0
>     >     mmcsd0: 4GB
>     >     >     <SDHC
>     >     >     >         TO 15.15 SN
>     >     >     >         > >     >>     000002F6 MFG
>     >     >     >         > >     >>     >     >         02/2017 by 25
>     >     >     >         > >     >>     >     >         >     DY> at mmc0
>     >     >     >         24.0MHz/4bit/65535-block
>     media
>     >     listener:
>     >     >     >         event =
>     >     >     >         > >     >>     >     FAILED, src =
>     media
>     >     listener:
>     >     >     >         event = PARTITION
>     >     >     >         > >     >>     INQUIRY,
>     >     >     >         > >     >>     >     state =
>     >     >     >         > >     >>     >     >         >     INQUIRY,
>     src =
>     >     /dev/mmcsd-0
>     media
>     >     listener:
>     >     >     >         > >     >>     INQUIRY,
>     >     >     >         > >     >>     >     >         >     SUCCESS,
>     src =
>     >     /dev/mmcsd-0
>     media
>     >     listener:
>     >     >     >         > >     >>     ATTACH,
>     >     >     >         > >     >>     >     state
>     >     >     >         > >     >>     >     >         = INQUIRY,
>     >     >     >         > >     >>     >     >         >     src =
>     >     /dev/mmcsd-0
>     media
>     >     listener:
>     >     >     >         > >     >>     ATTACH,
>     >     >     >         > >     >>     >     state
>     >     >     >         > >     >>     >     >         = SUCCESS,
>     >     >     /dev/mmcsd-0, dest =
>     >     >     >         > >     /dev/mmcsd-0-0
>     media
>     >     listener:
>     >     >     >         event =
>      /dev/mmcsd-0-0
>     media
>     >     listener:
>     >     >     >         event =
>     >     >     >         > >     >>     >     SUCCESS,
>     >      /dev/mmcsd-0-0,
>     dest =
>     >     >     >         /media/mmcsd-0-0
>     media
>     >     listener:
>     >     >     >         event = DISK
>     >     >     >         > >     ATTACH,
>     >     >     >         > >     >>     state =
>     media
>     >     listener:
>     >     >     >         event = DISK
>     >     >     >         > >     ATTACH,
>     >     >     >         > >     >>     state =
>      mmcsd, dest
>     >     /dev/mmcsd-1
>     media
>     >     listener:
>     >     >     >         event =
>     >     >     >         > >     >>     >     >         >     /dev/mmcsd-1
>     >     mmcsd1: 4GB
>     >     >     >         <MMCHC MMC04G 5.8 SN
>     >     >     >         > >     >>     160D224B MFG
>     >     >     >         > >     >>     >     >         09/2014 by 112
>      0x0000> at
>     mmc1
>     >     >     >         48.0MHz/8bit/65535-block
>     media
>     >     listener:
>     >     >     >         event =
>     media
>     >     listener:
>     >     >     >         > >     >>     INQUIRY,
>     src =
>     >     /dev/mmcsd-1
>     media
>     >     listener:
>     >     >     >         > >     >>     INQUIRY,
>     >     >     >         > >     >>     >     state
>     >     >     >         > >     >>     >     >         = FAILED,
>     >     /dev/mmcsd-1
>     media
>     >     listener:
>     >     >     >         event = DISK
>     >     >     >         > >     ATTACH,
>     >     >     >         > >     >>     state =
>     >     >     >         > >     >>     >     >         INQUIRY, src =
>      mmcsd1boot
>     >     >     mmcsd1boot0: 2MB
>     >     >     >         partion 1 at
>     >     >     >         > >     mmcsd1
>     >     >     mmcsd1boot1: 2MB
>     >     >     >         partion 2 at
>     >     >     >         > >     mmcsd1
>     >     mmcsd1rpmb:
>     >     >     131kB
>     >     >     >         partion 3
>     >     >     >         > >     at mmcsd1
>     >     >     >         > >     >>     >     >         >     >     > > On
>     >     13/08/2019
>     >     >     >         13:30, Nils
>     >     >     >         > >     Hölscher
>     >     >     >         > >     >>     wrote:
>     > Hi,
>     > Thanks
>     >     >     for the
>     >     >     >         help.
>     > I tried
>     >     >     to use
>     >     >     >         your code, but I
>     >     >     >         > >     >>     always get
>     >     >     >         > >     >>     >     >         "ERROR: SD
>     >     >     >         > >     >>     >     >         >     could not be
>     >     mounted after
>     >     >     >         timeout".
>     >     Even after
>     >     >     >         raising the
>     >     >     >         > >     waiting time.
>     > The
>     >     sources I
>     >     >     >         use start here:
>         https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
>     > And
>     >     my uart
>     >     >     >         output is:
>     > waiting
>     >     >     for SD...
>     > usbus0:
>     >     >     480Mbps
>     >     >     >         High Speed
>     >     >     >         > >     USB v2.0
>     > usbus1:
>     >     >     480Mbps
>     >     >     >         High Speed
>     >     >     >         > >     USB v2.0
>     > media
>     >     >     listener:
>     >     >     >         event = DISK
>     >     >     >         > >     >>     ATTACH, state =
>     >     >     >         > >     >>     >     >         >     src = mmcsd
>     > media
>     >     >     listener:
>     >     >     >         event = DISK
>      mmcsd, dest
>     >     >     /dev/mmcsd-0
>     > media
>     >     >     listener:
>     >     >     >         event =
>     >     ugen0.1:
>     >     >     >         <Mentor Graphics
>     >     >     >         > >     OTG Root
>     >     >     >         > >     >>     HUB>
>     >     >     >         > >     >>     >     at usbus0
>     >     ugen1.1:
>     >     >     >         > >     OTG Root
>     >     >     >         > >     >>     HUB>
>     >     >     >         > >     >>     >     at usbus1
>     > uhub0:
>     >     >     <Mentor
>     >     >     >         Graphics OTG
>     >     >     >         > >     Root
>     >     >     >         > >     >>     HUB, class
>     >     >     >         > >     >>     >     >         9/0, rev
>     >      2.00/1.00, addr 1>
>     > on
>     >     usbus0
>     > uhub1:
>     >     >     <Mentor
>     >     >     >         Graphics OTG
>     >     >     >         > >     Root
>     >      2.00/1.00, addr 1>
>     > on
>     >     usbus1
>     > media
>     >     >     listener:
>     >     >     >         event =
>     > media
>     >     >     listener:
>     >     >     >         event =
>     >     >     >         > >     PARTITION
>     >     >     >         > >     >>     >     INQUIRY, state =
>     src =
>     >     /dev/mmcsd-0
>     > media
>     >     >     listener:
>     >     >     >         event =
>     >     >     >         > >     PARTITION
>     src =
>     >     /dev/mmcsd-0
>     > media
>     >     >     listener:
>     >     >     >         event =
>     >     >     >         > >     PARTITION
>     >     >     >         > >     >>     >     ATTACH, state =
>     src =
>     >     /dev/mmcsd-0
>     > media
>     >     >     listener:
>     >     >     >         event =
>     >     >     >         > >     PARTITION
>     src =
>     >     /dev/mmcsd-0,
>     >     >     >         dest =
>     > media
>     >     >     listener:
>     >     >     >         event =
>     >      /dev/mmcsd-0-0
>     > media
>     >     >     listener:
>     >     >     >         event =
>     >      /dev/mmcsd-0-0
>     > media
>     >     >     listener:
>     >     >     >         event = DISK
>     > media
>     >     >     listener:
>     >     >     >         event = DISK
>      mmcsd, dest
>     >     >     /dev/mmcsd-1
