Checksum Error on Leon3 Qemu patches
Jiri Gaisler
jiri at gaisler.se
Sun Aug 18 22:33:38 UTC 2019
On 8/18/19 10:30 PM, Jiri Gaisler wrote:
> On 8/17/19 8:23 PM, Joel Sherrill wrote:
>> On Sat, Aug 17, 2019, 1:07 PM Jiri Gaisler <jiri at gaisler.se <mailto:jiri at gaisler.se>> wrote:
>> On 8/16/19 11:03 PM, Juan Rafael García Blanco wrote:
>>> Hi,
>>> AFAIK, the last qemu major version includes support for leon3. But I dont't know if that work was based on these patches.
>> Indeed. Qemu git head now includes leon3 plug&play and should be able to run RTEMS images unpatched. Is there a reason why the qemu version built by RSB is from June 2015 ..?
>> Sadly no one has updated it. Beyond Leon, Zynq and PC, what should be tested?
>> Riscv status in head?
>> Beagle?
>> Any other bsps we use with Qemu?
>> I'd love to see it updated. It's a pain to test across all the hosts and get working.
> Unfortunately, qemu HEAD cannot execute RTEMS leon3 images unpatched. The startup code needs a (simple) tweak, and the implementation of the plug&play is not quite correct. An RTEMS binary fails to detect the interrupt controller and subsequently terminates. I have spent a few hours on it but the bug is rather elusive and
OK, the problem was that qemu did not implement byte access to the plug&play. With the attached patch, most tests for leon3 run:
Passed: 506
Failed: 4
User Input: 6
Expected Fail: 0
Indeterminate: 0
Benchmark: 3
Timeout: 9
Invalid: 2
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Total: 530
Average test time: 0:00:00.539755
Testing time : 0:04:46.070129
Maybe we can add it to RSB as qemu4.1, which was released this week. It could make it easier to test other targets ...?
Jiri.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190819/99a5c85e/attachment-0001.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190819/99a5c85e/attachment-0001.bin>
