[PATCH] misc/tftpproxy: Add a proxy TFTP server.
chrisj at rtems.org chrisj at rtems.org
Mon Aug 19 06:50:01 UTC 2019
- Uses a config INI file to map clients to servers
- Handle a number of requests to a single server's TFTP port (69)
  and multiplex to a non-su ports or different servers.
- Supports running rtems-test to more than one hardware device using
  TFTP at once.
 misc/rtems-tftp-proxy         |  42 +++
 misc/tools/cmd-tftpproxy.py   |  44 +++
 misc/tools/getmac/LICENSE     |  21 ++
 misc/tools/getmac/__init__.py |   2 +
 misc/tools/getmac/__main__.py |  67 ++++
 misc/tools/getmac/getmac.py   | 603 ++++++++++++++++++++++++++++++++++
 misc/tools/tftpproxy.py       | 423 ++++++++++++++++++++++++
 misc/wscript                  |   9 +-
 8 files changed, 1209 insertions(+), 2 deletions(-)
 create mode 100755 misc/rtems-tftp-proxy
 create mode 100755 misc/tools/cmd-tftpproxy.py
 create mode 100644 misc/tools/getmac/LICENSE
 create mode 100644 misc/tools/getmac/__init__.py
 create mode 100644 misc/tools/getmac/__main__.py
 create mode 100644 misc/tools/getmac/getmac.py
 create mode 100644 misc/tools/tftpproxy.py
diff --git a/misc/rtems-tftp-proxy b/misc/rtems-tftp-proxy
new file mode 100755
index 0000000..213311d
--- /dev/null
+++ b/misc/rtems-tftp-proxy
@@ -0,0 +1,42 @@
+#! /bin/sh
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2019 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+set -e
+base=$(dirname $(dirname $0))
+cmd=misc/tools/cmd-tftpproxy.py
+PYTHON_WRAPPER=rtemstoolkit/python-wrapper.sh
+if test -f ${base}/${PYTHON_WRAPPER}; then
+  PYTHON_CMD=${base}/${cmd}
+  . ${base}/${PYTHON_WRAPPER}
+elif test -f ${base}/share/rtems/${PYTHON_WRAPPER}; then
+  PYTHON_CMD=${base}/share/rtems/${cmd}
+  . ${base}/share/rtems/${PYTHON_WRAPPER}
+fi
+echo "error: RTEMS Toolkit python wrapper not found, please report"
diff --git a/misc/tools/cmd-tftpproxy.py b/misc/tools/cmd-tftpproxy.py
index 0000000..9f66a76
--- /dev/null
+++ b/misc/tools/cmd-tftpproxy.py
@@ -0,0 +1,44 @@
+from __future__ import print_function
+import sys, os
+base = os.path.dirname(os.path.dirname(os.path.abspath(sys.argv[0])))
+rtems = os.path.dirname(base)
+sys.path = [rtems] + sys.path
+try:
+    import tftpproxy
+    tftpproxy.run(sys.argv[1:], command_path = base)
+except ImportError:
+    print("Incorrect RTEMS Tools installation", file = sys.stderr)
+    sys.exit(1)
diff --git a/misc/tools/getmac/LICENSE b/misc/tools/getmac/LICENSE
new file mode 100644
index 0000000..1a71c0f
--- /dev/null
+++ b/misc/tools/getmac/LICENSE
@@ -0,0 +1,21 @@
+MIT License
+Copyright (c) 2019 Christopher Goes
+Permission is hereby granted, free of charge, to any person obtaining a copy
+of this software and associated documentation files (the "Software"), to deal
+in the Software without restriction, including without limitation the rights
+to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
+copies of the Software, and to permit persons to whom the Software is
+furnished to do so, subject to the following conditions:
+The above copyright notice and this permission notice shall be included in all
+copies or substantial portions of the Software.
+THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
+SOFTWARE.
diff --git a/misc/tools/getmac/__init__.py b/misc/tools/getmac/__init__.py
index 0000000..fec68bc
--- /dev/null
+++ b/misc/tools/getmac/__init__.py
@@ -0,0 +1,2 @@
+from .getmac import __version__, get_mac_address
+__all__ = ['get_mac_address']
diff --git a/misc/tools/getmac/__main__.py b/misc/tools/getmac/__main__.py
index 0000000..5fbe0f7
--- /dev/null
+++ b/misc/tools/getmac/__main__.py
@@ -0,0 +1,67 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+import argparse
+import logging
+import sys
+from . import getmac
+def main():
+    parser = argparse.ArgumentParser(
+        'getmac', description='Get the MAC address of system network '
+                              'interfaces or remote hosts on the LAN')
+    parser.add_argument(
+        '--version', action='version',
+        version='getmac %s' % getmac.__version__)
+        '-v', '--verbose', action='store_true',
+        help='Enable output messages')
+        '-d', '--debug', action='count',
+        help='Enable debugging output. Add characters to '
+             'increase verbosity of output, e.g. \'-dd\'.')
+        '-N', '--no-net', '--no-network-requests',
+        action='store_true', dest='NO_NET',
+        help='Do not send a UDP packet to refresh the ARP table')
+    group = parser.add_mutually_exclusive_group(required=False)
+    group.add_argument(
+        '-i', '--interface', type=str, default=None,
+        help='Name of a network interface on the system')
+        '-4', '--ip', type=str, default=None,
+        help='IPv4 address of a remote host')
+        '-6', '--ip6', type=str, default=None,
+        help='IPv6 address of a remote host')
+        '-n', '--hostname', type=str, default=None,
+        help='Hostname of a remote host')
+    args = parser.parse_args()
+    if args.debug or args.verbose:
+        logging.basicConfig(format='%(levelname)-8s %(message)s',
+                            level=logging.DEBUG, stream=sys.stderr)
+    if args.debug:
+        getmac.DEBUG = args.debug
+    mac = getmac.get_mac_address(
+        interface=args.interface, ip=args.ip,
+        ip6=args.ip6, hostname=args.hostname,
+        network_request=not args.NO_NET)
+    if mac is not None:
+        print(mac)  # noqa: T001
+        sys.exit(0)  # Exit success!
+    else:
+        sys.exit(1)  # Exit with error since it failed to find a MAC
+if __name__ == '__main__':
+    main()
diff --git a/misc/tools/getmac/getmac.py b/misc/tools/getmac/getmac.py
index 0000000..d5555fb
--- /dev/null
+++ b/misc/tools/getmac/getmac.py
@@ -0,0 +1,603 @@
+# http://multivax.com/last_question.html
+"""Get the MAC address of remote hosts or network interfaces.
+It provides a platform-independent interface to get the MAC addresses of:
+* System network interfaces (by interface name)
+* Remote hosts on the local network (by IPv4/IPv6 address or hostname)
+It provides one function: `get_mac_address()`
+Examples:
+    from getmac import get_mac_address
+    eth_mac = get_mac_address(interface="eth0")
+    win_mac = get_mac_address(interface="Ethernet 3")
+    ip_mac = get_mac_address(ip="192.168.0.1")
+    ip6_mac = get_mac_address(ip6="::1")
+    host_mac = get_mac_address(hostname="localhost")
+    updated_mac = get_mac_address(ip="10.0.0.1", network_request=True)
+import ctypes
+import logging
+import os
+import platform
+import re
+import shlex
+import socket
+import struct
+import sys
+import traceback
+from subprocess import check_output
+try:  # Python 3
+    from subprocess import DEVNULL  # type: ignore
+except ImportError:  # Python 2
+    DEVNULL = open(os.devnull, 'wb')  # type: ignore
+# Configure logging
+log = logging.getLogger('getmac')
+log.addHandler(logging.NullHandler())
+__version__ = '0.8.1'
+PY2 = sys.version_info[0] == 2
+# Configurable settings
+DEBUG = 0
+PORT = 55555
+# Platform identifiers
+_SYST = platform.system()
+if _SYST == 'Java':
+    try:
+        import java.lang
+        _SYST = str(java.lang.System.getProperty("os.name"))
+    except ImportError:
+        log.critical("Can't determine OS: couldn't import java.lang on Jython")
+WINDOWS = _SYST == 'Windows'
+DARWIN = _SYST == 'Darwin'
+OPENBSD = _SYST == 'OpenBSD'
+FREEBSD = _SYST == 'FreeBSD'
+BSD = OPENBSD or FREEBSD  # Not including Darwin for now
+WSL = False  # Windows Subsystem for Linux (WSL)
+LINUX = False
+if _SYST == 'Linux':
+    if 'Microsoft' in platform.version():
+        WSL = True
+    else:
+        LINUX = True
+PATH = os.environ.get('PATH', os.defpath).split(os.pathsep)
+if not WINDOWS:
+    PATH.extend(('/sbin', '/usr/sbin'))
+# Use a copy of the environment so we don't
+# modify the process's current environment.
+ENV = dict(os.environ)
+ENV['LC_ALL'] = 'C'  # Ensure ASCII output so we parse correctly
+# Constants
+IP4 = 0
+IP6 = 1
+INTERFACE = 2
+HOSTNAME = 3
+MAC_RE_COLON = r'([0-9a-fA-F]{2}(?::[0-9a-fA-F]{2}){5})'
+MAC_RE_DASH = r'([0-9a-fA-F]{2}(?:-[0-9a-fA-F]{2}){5})'
+MAC_RE_DARWIN = r'([0-9a-fA-F]{1,2}(?::[0-9a-fA-F]{1,2}){5})'
+# Used for mypy (a data type analysis tool)
+# If you're copying the code, this section can be safely removed
+try:
+    from typing import TYPE_CHECKING
+    if TYPE_CHECKING:
+        from typing import Optional
+    pass
+def get_mac_address(
+        interface=None, ip=None, ip6=None,
+        hostname=None, network_request=True
+    # type: (Optional[str], Optional[str], Optional[str], Optional[str], bool) -> Optional[str]
+    """Get a Unicast IEEE 802 MAC-48 address from a local interface or remote host.
+    You must only use one of the first four arguments. If none of the arguments
+    are selected, the default network interface for the system will be used.
+    Exceptions will be handled silently and returned as a None.
+    For the time being, it assumes you are using Ethernet.
+    NOTES:
+    * You MUST provide str-typed arguments, REGARDLESS of Python version.
+    * localhost/127.0.0.1 will always return '00:00:00:00:00:00'
+    Args:
+        interface (str): Name of a local network interface (e.g "Ethernet 3", "eth0", "ens32")
+        ip (str): Canonical dotted decimal IPv4 address of a remote host (e.g 192.168.0.1)
+        ip6 (str): Canonical shortened IPv6 address of a remote host (e.g ff02::1:ffe7:7f19)
+        hostname (str): DNS hostname of a remote host (e.g "router1.mycorp.com", "localhost")
+        network_request (bool): Send a UDP packet to a remote host to populate
+        the ARP/NDP tables for IPv4/IPv6. The port this packet is sent to can
+        be configured using the module variable `getmac.PORT`.
+    Returns:
+        Lowercase colon-separated MAC address, or None if one could not be
+        found or there was an error.
+    if (hostname and hostname == 'localhost') or (ip and ip == '127.0.0.1'):
+        return '00:00:00:00:00:00'
+    # Resolve hostname to an IP address
+    if hostname:
+        ip = socket.gethostbyname(hostname)
+    # Populate the ARP table by sending a empty UDP packet to a high port
+    if network_request and (ip or ip6):
+        if ip:
+            s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
+        else:
+            s = socket.socket(socket.AF_INET6, socket.SOCK_DGRAM)
+        try:
+            if ip:
+                s.sendto(b'', (ip, PORT))
+            else:
+                s.sendto(b'', (ip6, PORT))
+        except Exception:
+            log.error("Failed to send ARP table population packet")
+            if DEBUG:
+                log.debug(traceback.format_exc())
+        finally:
+            s.close()
+    # Setup the address hunt based on the arguments specified
+    if ip6:
+        if not socket.has_ipv6:
+            log.error("Cannot get the MAC address of a IPv6 host: "
+                      "IPv6 is not supported on this system")
+            return None
+        elif ':' not in ip6:
+            log.error("Invalid IPv6 address: %s", ip6)
+            return None
+        to_find = ip6
+        typ = IP6
+    elif ip:
+        to_find = ip
+        typ = IP4
+    else:  # Default to searching for interface
+        typ = INTERFACE
+        if interface:
+            to_find = interface
+        else:
+            # Default to finding MAC of the interface with the default route
+            if WINDOWS and network_request:
+                to_find = _fetch_ip_using_dns()
+                typ = IP4
+            elif WINDOWS:
+                to_find = 'Ethernet'
+            elif BSD:
+                if OPENBSD:
+                    to_find = _get_default_iface_openbsd()  # type: ignore
+                else:
+                    to_find = _get_default_iface_freebsd()  # type: ignore
+                if not to_find:
+                    to_find = 'em0'
+            else:
+                to_find = _hunt_linux_default_iface()  # type: ignore
+                if not to_find:
+                    to_find = 'en0'
+    mac = _hunt_for_mac(to_find, typ, network_request)
+    log.debug("Raw MAC found: %s", mac)
+    # Check and format the result to be lowercase, colon-separated
+        mac = str(mac)
+        if not PY2:  # Strip bytestring conversion artifacts
+            mac = mac.replace("b'", '').replace("'", '')\
+                     .replace('\\n', '').replace('\\r', '')
+        mac = mac.strip().lower().replace(' ', '').replace('-', ':')
+        # Fix cases where there are no colons
+        if ':' not in mac and len(mac) == 12:
+            log.debug("Adding colons to MAC %s", mac)
+            mac = ':'.join(mac[i:i + 2] for i in range(0, len(mac), 2))
+        # Pad single-character octets with a leading zero (e.g Darwin's ARP output)
+        elif len(mac) < 17:
+            log.debug("Length of MAC %s is %d, padding single-character "
+                      "octets with zeros", mac, len(mac))
+            parts = mac.split(':')
+            new_mac = []
+            for part in parts:
+                if len(part) == 1:
+                    new_mac.append('0' + part)
+                else:
+                    new_mac.append(part)
+            mac = ':'.join(new_mac)
+        # MAC address should ALWAYS be 17 characters before being returned
+        if len(mac) != 17:
+            log.warning("MAC address %s is not 17 characters long!", mac)
+            mac = None
+        elif mac.count(':') != 5:
+            log.warning("MAC address %s is missing ':' characters", mac)
+            mac = None
+    return mac
+def _search(regex, text, group_index=0):
+    # type: (str, str, int) -> Optional[str]
+    match = re.search(regex, text)
+    if match:
+        return match.groups()[group_index]
+    return None
+def _popen(command, args):
+    # type: (str, str) -> str
+    for directory in PATH:
+        executable = os.path.join(directory, command)
+        if (os.path.exists(executable)
+            and os.access(executable, os.F_OK | os.X_OK)
+                and not os.path.isdir(executable)):
+            break
+    else:
+        executable = command
+    if DEBUG >= 3:
+        log.debug("Running: '%s %s'", executable, args)
+    return _call_proc(executable, args)
+def _call_proc(executable, args):
+    if WINDOWS:
+        cmd = executable + ' ' + args  # type: ignore
+    else:
+        cmd = [executable] + shlex.split(args)  # type: ignore
+    output = check_output(cmd, stderr=DEVNULL, env=ENV)
+    if DEBUG >= 4:
+        log.debug("Output from '%s' command: %s", executable, str(output))
+    if not PY2 and isinstance(output, bytes):
+        return str(output, 'utf-8')
+    else:
+        return str(output)
+def _windows_ctypes_host(host):
+    # type: (str) -> Optional[str]
+    if not PY2:  # Convert to bytes on Python 3+ (Fixes GitHub issue #7)
+        host = host.encode()  # type: ignore
+    try:
+        inetaddr = ctypes.windll.wsock32.inet_addr(host)  # type: ignore
+        if inetaddr in (0, -1):
+            raise Exception
+    except Exception:
+        hostip = socket.gethostbyname(host)
+        inetaddr = ctypes.windll.wsock32.inet_addr(hostip)  # type: ignore
+    buffer = ctypes.c_buffer(6)
+    addlen = ctypes.c_ulong(ctypes.sizeof(buffer))
+    send_arp = ctypes.windll.Iphlpapi.SendARP  # type: ignore
+    if send_arp(inetaddr, 0, ctypes.byref(buffer), ctypes.byref(addlen)) != 0:
+        return None
+    # Convert binary data into a string.
+    macaddr = ''
+    for intval in struct.unpack('BBBBBB', buffer):  # type: ignore
+        if intval > 15:
+            replacestr = '0x'
+        else:
+            replacestr = 'x'
+        macaddr = ''.join([macaddr, hex(intval).replace(replacestr, '')])
+    return macaddr
+def _fcntl_iface(iface):
+    # type: (str) -> str
+    import fcntl
+    if not PY2:
+        iface = iface.encode()  # type: ignore
+    # 0x8927 = SIOCGIFADDR
+    info = fcntl.ioctl(s.fileno(), 0x8927, struct.pack('256s', iface[:15]))
+    if PY2:
+        return ':'.join(['%02x' % ord(char) for char in info[18:24]])
+    else:
+        return ':'.join(['%02x' % ord(chr(char)) for char in info[18:24]])
+def _uuid_ip(ip):
+    from uuid import _arp_getnode  # type: ignore
+    backup = socket.gethostbyname
+    try:
+        socket.gethostbyname = lambda x: ip
+        mac1 = _arp_getnode()
+        if mac1 is not None:
+            mac1 = _uuid_convert(mac1)
+            mac2 = _arp_getnode()
+            mac2 = _uuid_convert(mac2)
+            if mac1 == mac2:
+                return mac1
+    except Exception:
+        raise
+    finally:
+        socket.gethostbyname = backup
+    return None
+def _uuid_lanscan_iface(iface):
+    from uuid import _find_mac  # type: ignore
+    if not PY2:
+        iface = bytes(iface, 'utf-8')  # type: ignore
+    mac = _find_mac('lanscan', '-ai', [iface], lambda i: 0)
+    if mac:
+        return _uuid_convert(mac)
+    return None
+def _uuid_convert(mac):
+    # type: (int) -> str
+    return ':'.join(('%012X' % mac)[i:i+2] for i in range(0, 12, 2))
+def _read_sys_iface_file(iface):
+    data = _read_file('/sys/class/net/' + iface + '/address')
+    # Sometimes this can be empty or a single newline character
+    return None if data is not None and len(data) < 17 else data
+def _read_arp_file(host):
+    data = _read_file('/proc/net/arp')
+    if data is not None and len(data) > 1:
+        # Need a space, otherwise a search for 192.168.16.2
+        # will match 192.168.16.254 if it comes first!
+        return _search(re.escape(host) + r' .+' + MAC_RE_COLON, data)
+    return None
+def _read_file(filepath):
+    try:
+        with open(filepath) as f:
+            return f.read()
+    except (OSError, IOError):  # This is IOError on Python 2.7
+        log.debug("Could not find file: '%s'", filepath)
+        return None
+def _hunt_for_mac(to_find, type_of_thing, net_ok=True):
+    # type: (Optional[str], int, bool) -> Optional[str]
+    """Tries a variety of methods to get a MAC address.
+    Format of method lists:
+    Tuple:  (regex, regex index, command, command args)
+            Command args is a list of strings to attempt to use as arguments
+    lambda: Function to call
+    if to_find is None:
+        log.warning("_hunt_for_mac() failed: to_find is None")
+        return None
+    if not PY2 and isinstance(to_find, bytes):
+        to_find = str(to_find, 'utf-8')
+    if WINDOWS and type_of_thing == INTERFACE:
+        methods = [
+            # getmac - Connection Name
+            (r'\r\n' + to_find + r'.*' + MAC_RE_DASH + r'.*\r\n',
+             0, 'getmac.exe', ['/NH /V']),
+            # ipconfig
+            (to_find + r'(?:\n?[^\n]*){1,8}Physical Address[ .:]+' + MAC_RE_DASH + r'\r\n',
+             0, 'ipconfig.exe', ['/all']),
+            # getmac - Network Adapter (the human-readable name)
+            (r'\r\n.*' + to_find + r'.*' + MAC_RE_DASH + r'.*\r\n',
+            # wmic - WMI command line utility
+            lambda x: _popen('wmic.exe', 'nic where "NetConnectionID = \'%s\'" get '
+                                         'MACAddress /value' % x).strip().partition('=')[2],
+    elif (WINDOWS or WSL) and type_of_thing in [IP4, IP6, HOSTNAME]:
+        methods = [
+            # arp -a - Parsing result with a regex
+            (MAC_RE_DASH, 0, 'arp.exe', ['-a %s' % to_find]),
+        # Add methods that make network requests
+        # Insert it *after* arp.exe since that's probably faster.
+        if net_ok and type_of_thing != IP6 and not WSL:
+            methods.insert(1, _windows_ctypes_host)
+    elif (DARWIN or FREEBSD) and type_of_thing == INTERFACE:
+        methods = [
+            (r'ether ' + MAC_RE_COLON,
+             0, 'ifconfig', [to_find]),
+            # Alternative match for ifconfig if it fails
+            (to_find + r'.*ether ' + MAC_RE_COLON,
+             0, 'ifconfig', ['']),
+            (MAC_RE_COLON,
+             0, 'networksetup', ['-getmacaddress %s' % to_find]),
+    elif FREEBSD and type_of_thing in [IP4, IP6, HOSTNAME]:
+        methods = [
+            (r'\(' + re.escape(to_find) + r'\)\s+at\s+' + MAC_RE_COLON,
+             0, 'arp', [to_find])
+    elif OPENBSD and type_of_thing == INTERFACE:
+        methods = [
+            (r'lladdr ' + MAC_RE_COLON,
+    elif OPENBSD and type_of_thing in [IP4, IP6, HOSTNAME]:
+        methods = [
+            (re.escape(to_find) + r'[ ]+' + MAC_RE_COLON,
+             0, 'arp', ['-an']),
+    elif type_of_thing == INTERFACE:
+        methods = [
+            _read_sys_iface_file,
+            _fcntl_iface,
+            # Fast modern Ubuntu ifconfig
+            # Fast ifconfig
+            (r'HWaddr ' + MAC_RE_COLON,
+            # ip link (Don't use 'list' due to SELinux [Android 24+])
+            (to_find + r'.*\n.*link/ether ' + MAC_RE_COLON,
+             0, 'ip', ['link %s' % to_find, 'link']),
+            # netstat
+            (to_find + r'.*HWaddr ' + MAC_RE_COLON,
+             0, 'netstat', ['-iae']),
+            # More variations of ifconfig
+             0, 'ifconfig', ['', '-a', '-v']),
+            # Tru64 ('-av')
+            (to_find + r'.*Ether ' + MAC_RE_COLON,
+             0, 'ifconfig', ['-av']),
+            _uuid_lanscan_iface,
+    elif type_of_thing in [IP4, IP6, HOSTNAME]:
+        esc = re.escape(to_find)
+        methods = [
+            _read_arp_file,
+            lambda x: _popen('ip', 'neighbor show %s' % x)
+            .partition(x)[2].partition('lladdr')[2].strip().split()[0],
+            (r'\(' + esc + r'\)\s+at\s+' + MAC_RE_COLON,
+             0, 'arp', [to_find, '-an', '-an %s' % to_find]),
+            # Darwin oddness
+            (r'\(' + esc + r'\)\s+at\s+' + MAC_RE_DARWIN,
+             0, 'arp', [to_find, '-a', '-a %s' % to_find]),
+            _uuid_ip,
+    else:
+        log.critical("Reached end of _hunt_for_mac() if-else chain!")
+        return None
+    return _try_methods(methods, to_find)
+def _try_methods(methods, to_find=None):
+    # type: (list, Optional[str]) -> Optional[str]
+    """Runs the methods specified by _hunt_for_mac().
+    We try every method and see if it returned a MAC address. If it returns
+    None or raises an exception, we continue and try the next method.
+    found = None
+    for m in methods:
+        try:
+            if isinstance(m, tuple):
+                for arg in m[3]:  # list(str)
+                    if DEBUG:
+                        log.debug("Trying: '%s %s'", m[2], arg)
+                    # Arguments: (regex, _popen(command, arg), regex index)
+                    found = _search(m[0], _popen(m[2], arg), m[1])
+                    if DEBUG:
+                        log.debug("Result: %s\n", found)
+                    if found:  # Skip remaining args AND remaining methods
+                        break
+            elif callable(m):
+                if DEBUG:
+                    log.debug("Trying: '%s' (to_find: '%s')", m.__name__, str(to_find))
+                if to_find is not None:
+                    found = m(to_find)
+                else:
+                    found = m()
+                if DEBUG:
+            else:
+                log.critical("Invalid type '%s' for method '%s'", type(m), str(m))
+        except Exception as ex:
+            if DEBUG:
+                log.debug("Exception: %s", str(ex))
+            if DEBUG >= 2:
+            continue
+        if found:  # Skip remaining methods
+            break
+    return found
+def _get_default_iface_linux():
+    # type: () -> Optional[str]
+    """Get the default interface by reading /proc/net/route.
+    This is the same source as the `route` command, however it's much
+    faster to read this file than to call `route`. If it fails for whatever
+    reason, we can fall back on the system commands (e.g for a platform
+    that has a route command, but maybe doesn't use /proc?).
+    data = _read_file('/proc/net/route')
+        for line in data.split('\n')[1:-1]:
+            iface_name, dest = line.split('\t')[:2]
+            if dest == '00000000':
+                return iface_name
+    return None
+def _hunt_linux_default_iface():
+    # NOTE: for now, we check the default interface for WSL using the
+    # same methods as POSIX, since those parts of the net stack work fine.
+    methods = [
+        _get_default_iface_linux,
+        lambda: _popen('route', '-n').partition('0.0.0.0')[2].partition('\n')[0].split()[-1],
+        lambda: _popen('ip', 'route list 0/0').partition('dev')[2].partition('proto')[0].strip(),
+    return _try_methods(methods)
+def _get_default_iface_openbsd():
+    methods = [
+        lambda: _popen('route', '-nq show -inet -gateway -priority 1')
+        .partition('127.0.0.1')[0].strip().rpartition(' ')[2],
+def _get_default_iface_freebsd():
+    methods = [
+        (r'default[ ]+\S+[ ]+\S+[ ]+(\S+)\n',
+         0, 'netstat', ['-r']),
+def _fetch_ip_using_dns():
+    # type: () -> str
+    """Determines the IP address of the default network interface.
+    Sends a UDP packet to Cloudflare's DNS (1.1.1.1), which should go through
+    the default interface. This populates the source address of the socket,
+    which we then inspect and return.
+    s.connect(('1.1.1.1', 53))
+    ip = s.getsockname()[0]
+    s.close()  # NOTE: sockets don't have context manager in 2.7 :(
+    return ip
diff --git a/misc/tools/tftpproxy.py b/misc/tools/tftpproxy.py
index 0000000..a815584
--- /dev/null
+++ b/misc/tools/tftpproxy.py
@@ -0,0 +1,423 @@
+# Copyright 2019 Chris Johns (chris at contemporary.software)
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# The TFTP proxy redirects a TFTP session to another host. If you have a
+# farm of boards you can configure them to point to this proxy and it will
+# redirect the requests to another machine that is testing it.
+import argparse
+import os
+import socket
+import sys
+import time
+import threading
+try:
+    import socketserver
+except:
+    import SocketServer as socketserver
+from rtemstoolkit import configuration
+from rtemstoolkit import error
+from rtemstoolkit import log
+from rtemstoolkit import version
+import getmac
+def host_port_split(ip_port):
+    ips = ip_port.split(':')
+    port = 0
+    if len(ips) >= 1:
+        ip = ips[0]
+        if len(ips) == 2:
+            port = int(ips[1])
+        else:
+            raise error.general('invalid host:port: %s' % (ip_port))
+    return ip, port
+class tftp_session(object):
+    opcodes = ['nul', 'RRQ', 'WRQ', 'DATA', 'ACK', 'ERROR', 'OACK']
+    def __init__(self):
+        self.packets = []
+        self.block = 0
+        self.block_size = 512
+        self.timeout = 0
+        self.finished = True
+    def __str__(self):
+        return os.linesep.join([self.decode(p[0], p[1], p[2]) for p in self.packets])
+    def data(self, host, port, data):
+        finished = False
+        self.packets += [(host, port, data)]
+        opcode = (data[0] << 8) | data[1]
+        if opcode == 1 or opcode == 2:
+            self.block = 0
+            self.finished = False
+            value = self.get_option('timeout', data)
+            if value is not None:
+                self.timeout = int(value)
+            value = self.get_option('blksize', data)
+                self.block_size = int(value)
+            else:
+        elif opcode == 3:
+            self.block = (data[2] << 8) | data[3]
+            if len(data) - 4 < self.block_size:
+        elif opcode == 4:
+            if self.finished:
+                finished = True
+        return finished
+    def decode(self, host, port, data):
+        s = ''
+        dlen = len(data)
+        if dlen > 2:
+            if opcode < len(self.opcodes):
+                    s += '  ' + self.opcodes[opcode] + ', '
+                    i = 2
+                    while data[i] != 0:
+                        s += chr(data[i])
+                        i += 1
+                    while i < dlen - 1:
+                        s += ', '
+                        i += 1
+                            s += chr(data[i])
+                            i += 1
+                elif opcode == 3:
+                    block = (data[2] << 8) | data[3]
+                    s += '#' + str(block) + ', '
+                    if dlen > 4:
+                        s += '%02x%02x..%02x%02x' % (data[4], data[5], data[-2], data[-1])
+                    else:
+                        s += '%02x%02x%02x%02x' % (data[4], data[5], data[6], data[6])
+                    s += ',' + str(dlen - 4)
+                elif opcode == 4:
+                    s += '  ' + self.opcodes[opcode] + ' ' + str(block)
+                elif opcode == 5:
+                    s += 'E ' + self.opcodes[opcode] + ', '
+                    s += str((data[2] << 8) | (data[3]))
+                    i = 2
+                        s += chr(data[i])
+                        i += 1
+                elif opcode == 6:
+                    i = 1
+                        s += ', '
+                        i += 1
+                            s += chr(data[i])
+                            i += 1
+            else:
+                s += 'E INV(%d)' % (opcode)
+        else:
+            s += 'E INVALID LENGTH'
+        return s[:2] + '[%s:%d] ' % (host, port) + s[2:]
+    def get_option(self, option, data):
+        dlen = len(data)
+        next_option = False
+            i = 1
+                o = ''
+                i += 1
+                    o += chr(data[i])
+                    i += 1
+                if o == option:
+                    next_option = True
+                elif next_option:
+                    return o
+        return None
+    def get_timeout(self, default_timeout, timeout_guard):
+        if self.timeout == 0:
+            return self.timeout + timeout_guard
+        return default_timeout
+    def get_block_size(self):
+        return self.block_size
+class udp_handler(socketserver.BaseRequestHandler):
+    def handle(self):
+        client_ip = self.client_address[0]
+        client_port = self.client_address[1]
+        client = '%s:%i' % (client_ip, client_port)
+        session = tftp_session()
+        finished = session.data(client_ip, client_port, self.request[0])
+        if not finished:
+            timeout = session.get_timeout(self.server.proxy.session_timeout, 1)
+            host = self.server.proxy.get_host(client_ip)
+            if host is not None:
+                session_count = self.server.proxy.get_session_count()
+                log.notice(' ] %6d: session: %s -> %s: start' % (session_count,
+        client,
+        host))
+                host_ip, host_server_port = host_port_split(host)
+                host_port = host_server_port
+                sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
+                sock.settimeout(timeout)
+                log.trace('  > ' + session.decode(client_ip,
+                                                  client_port,
+                                                  self.request[0]))
+                sock.sendto(self.request[0], (host_ip, host_port))
+                while not finished:
+                    try:
+                        data, address = sock.recvfrom(16 * 1024)
+                    except socket.error as se:
+                        log.notice(' ] session: %s -> %s: error: %s' % (client,
+        host,
+        se))
+                        return
+                    except socket.gaierror as se:
+        host,
+        se))
+                        return
+                    except:
+                        return
+                    finished = session.data(address[0], address[1], data)
+                    if address[0] == host_ip:
+                        if host_port == host_server_port:
+                            host_port = address[1]
+                        if  address[1] == host_port:
+                            log.trace('  < ' + session.decode(address[0],
+                                                              address[1],
+                                                              data))
+                            sock.sendto(data, (client_ip, client_port))
+                    elif address[0] == client_ip and address[1] == client_port:
+                        log.trace('  > ' + session.decode(address[0],
+                                                          address[1],
+                                                          data))
+                        sock.sendto(data, (host_ip, host_port))
+                log.notice(' ] %6d: session: %s -> %s: end' % (session_count,
+                                                               client,
+                                                               host))
+            else:
+                mac = getmac.get_mac_address(ip = client_ip)
+                log.trace(' . request: host not found: %s (%s)' % (client, mac))
+class udp_server(socketserver.ThreadingMixIn, socketserver.UDPServer):
+    pass
+class proxy_server(object):
+    def __init__(self, config, host, port):
+        self.lock = threading.Lock()
+        self.session_timeout = 10
+        self.host = host
+        self.port = port
+        self.server = None
+        self.clients = { }
+        self.config = configuration.configuration()
+        self._load(config)
+        self.session_counter = 0
+    def __del__(self):
+        self.stop()
+    def _lock(self):
+        self.lock.acquire()
+    def _unlock(self):
+        self.lock.release()
+    def _load_client(self, client, depth = 0):
+        if depth > 32:
+            raise error.general('\'clients\'" nesting too deep; circular?')
+        if not self.config.has_section(client):
+            raise error.general('client not found: %s' % (client))
+        for c in self.config.comma_list(client, 'clients', err = False):
+            self._load_client(c, depth + 1)
+        if client in self.clients:
+            raise error.general('repeated client: %s' % (client))
+        host = self.config.get_item(client, 'host', err = False)
+            ips = self.config.comma_list(client, 'ip', err = False)
+            macs = self.config.comma_list(client, 'mac', err = False)
+            if len(ips) != 0 and len(macs) != 0:
+                raise error.general('client has ip and mac: %s' % (client))
+            if len(ips) != 0:
+                keys = ips
+            elif len(macs) != 0:
+                keys = macs
+            else:
+                raise error.general('not client ip or mac: %s' % (client))
+            for key in keys:
+                self.clients[key] = host
+    def _load(self, config):
+        self.config.load(config)
+        clients = self.config.comma_list('default', 'clients', err = False)
+        if len(clients) == 0:
+            raise error.general('\'clients\'" entry not found in config [defaults]')
+        for client in clients:
+            self._load_client(client)
+    def start(self):
+        log.notice('Proxy: %s:%i' % (self.host, self.port))
+        if self.host == 'all':
+            host = ''
+        else:
+            host = self.host
+        try:
+            self.server = udp_server((host, self.port), udp_handler)
+        except Exception as e:
+            raise error.general('proxy create: %s' % (e))
+        self.server.proxy = self
+        self._lock()
+        try:
+            self.server_thread = threading.Thread(target = self.server.serve_forever)
+            self.server_thread.daemon = True
+            self.server_thread.start()
+        finally:
+            self._unlock()
+    def stop(self):
+        self._lock()
+        try:
+            if self.server is not None:
+                self.server.shutdown()
+                self.server.server_close()
+        finally:
+            self._unlock()
+    def run(self):
+        while True:
+            time.sleep(1)
+    def get_host(self, client):
+        host = None
+        self._lock()
+        try:
+                host = self.clients[client]
+            else:
+                mac = getmac.get_mac_address(ip = client)
+                if mac in self.clients:
+                    host = self.clients[mac]
+        finally:
+            self._unlock()
+        return host
+    def get_session_count(self):
+        count = 0
+        self._lock()
+        try:
+            self.session_counter += 1
+            count = self.session_counter
+        finally:
+            self._unlock()
+        return count
+def load_log(logfile):
+    if logfile is None:
+        log.default = log.log(streams = ['stdout'])
+    else:
+        log.default = log.log(streams = [logfile])
+def run(args = sys.argv, command_path = None):
+    ec = 0
+    notice = None
+    proxy = None
+    try:
+        description  = 'Proxy TFTP sessions from the host running this proxy'
+        description += 'to hosts and ports defined in the configuration file. '
+        description += 'The tool lets you create a farm of hardware and to run '
+        description += 'more than one TFTP test session on a host or multiple '
+        description += 'hosts at once. This proxy service is not considered secure'
+        description += 'and is for use in a secure environment.'
+        argsp = argparse.ArgumentParser(prog = 'rtems-tftp-proxy',
+                                        description = description)
+        argsp.add_argument('-l', '--log',
+                           help = 'log file.',
+                           type = str, default = None)
+        argsp.add_argument('-v', '--trace',
+                           help = 'enable trace logging for debugging.',
+                           action = 'store_true', default = False)
+        argsp.add_argument('-c', '--config',
+                           help = 'proxy configuation (default: %(default)s).',
+        argsp.add_argument('-B', '--bind',
+                           help = 'address to bind the proxy too (default: %(default)s).',
+                           type = str, default = 'all')
+        argsp.add_argument('-P', '--port',
+                           help = 'port to bind the proxy too(default: %(default)s).',
+                           type = int, default = '69')
+        argopts = argsp.parse_args(args[1:])
+        load_log(argopts.log)
+        log.notice('RTEMS Tools - TFTP Proxy, %s' % (version.string()))
+        log.output(log.info(args))
+        log.tracing = argopts.trace
+        if argopts.config is None:
+            raise error.general('no config file, see -h')
+        proxy = proxy_server(argopts.config, argopts.bind, argopts.port)
+        try:
+            proxy.start()
+            proxy.run()
+        except:
+            proxy.stop()
+            raise
+    except error.general as gerr:
+        notice = str(gerr)
+        ec = 1
+    except error.internal as ierr:
+        notice = str(ierr)
+        ec = 1
+    except error.exit as eerr:
+        pass
+    except KeyboardInterrupt:
+        notice = 'abort: user terminated'
+        ec = 1
+    except:
+        raise
+        notice = 'abort: unknown error'
+        ec = 1
+    if proxy is not None:
+        del proxy
+    if notice is not None:
+        log.stderr(notice)
+    sys.exit(ec)
+if __name__ == "__main__":
+    run()
diff --git a/misc/wscript b/misc/wscript
index f83c74b..7d90968 100644
--- a/misc/wscript
+++ b/misc/wscript
@@ -75,11 +75,16 @@ def build(bld):
     bld(features = 'py',
         source = ['tools/boot.py',
-                  'tools/cmd-boot-image.py'],
+                  'tools/cmd-boot-image.py',
+                  'tools/cmd-tftpproxy.py',
+                  'tools/tftpproxy.py',
+                  'tools/getmac/__init__.py',
+                  'tools/getmac/getmac.py'],
         install_from = '.',
         install_path = '${PREFIX}/share/rtems/misc')
     bld.install_files('${PREFIX}/bin',
-                      ['rtems-boot-image'],
+                      ['rtems-boot-image',
+                       'rtems-tftp-proxy'],
                       chmod = 0o755)
     bld.install_files('${PREFIX}/share/rtems/tools/config',
                       'tools/config/rtems-boot.ini')
2.19.1
