[PATCH v2] Add JSON log generation
Kinsey Moore kinsey.moore at oarcorp.com
Mon Aug 19 16:13:17 UTC 2019
Add log formatter hooks and JSON log formatter to the test infrastructure
for consumption by automated processes or report generators.
 tester/rt/test.py | 84 +++++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 84 insertions(+)
diff --git a/tester/rt/test.py b/tester/rt/test.py
index da0a11e..0ed799a 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -38,6 +38,7 @@ import re
 import sys
 import threading
 import time
+import json
 from rtemstoolkit import configuration
 from rtemstoolkit import error
@@ -217,6 +218,69 @@ def killall(tests):
     for test in tests:
         test.kill()
+def generate_json_report(args, reports, start_time, end_time, total, json_file):
+    import sys
+    json_log = {}
+    json_log['Command Line'] = " ".join(args)
+    json_log['Python'] = sys.version.replace('\n', '')
+    json_log['test_groups'] = []
+    json_log['Host'] = host.label(mode = 'all')
+    json_log['summary'] = {}
+    json_log['summary']['passed_count'] = reports.passed
+    json_log['summary']['failed_count'] = reports.failed
+    json_log['summary']['user-input_count'] = reports.user_input
+    json_log['summary']['expected-fail_count'] = reports.expected_fail
+    json_log['summary']['indeterminate_count'] = reports.indeterminate
+    json_log['summary']['benchmark_count'] = reports.benchmark
+    json_log['summary']['timeout_count'] = reports.timeouts
+    json_log['summary']['invalid_count'] = reports.invalids
+    json_log['summary']['wrong-version_count'] = reports.wrong_version
+    json_log['summary']['wrong-build_count'] = reports.wrong_build
+    json_log['summary']['wrong-tools_count'] = reports.wrong_tools
+    json_log['summary']['total_count'] = reports.total
+    json_log['summary']['average_test_time'] = str((end_time - start_time) / total)
+    json_log['summary']['testing_time'] = str(end_time - start_time)
+    result_types = ['failed', 'user-input', 'expected-fail', 'indeterminate', 'benchmark', 'timeout', 'invalid', 'wrong-version', 'wrong-build', 'wrong-tools']
+    json_results = {}
+    for result_type in result_types:
+        json_log['summary'][result_type] = []
+    # collate results for JSON log
+    for name in reports.results:
+        result_type = reports.results[name]['result']
+        test_parts = name.split("/")
+        test_category = test_parts[-2]
+        test_name = test_parts[-1]
+        if result_type != 'passed':
+            json_log['summary'][result_type].append(test_name)
+        if test_category not in json_results:
+            json_results[test_category] = []
+        json_result = {}
+        # remove the file extension
+        json_result["name"] = test_name.split('.')[0]
+        json_result["result"] = result_type
+        if result_type == "failed" or result_type == "timeout":
+            json_result["output"] = reports.results[name]["output"]
+        json_results[test_category].append(json_result)
+    # convert results to a better format for report generation
+    sorted_keys = sorted(json_results.keys())
+    for i in range(len(sorted_keys)):
+        results_log = {}
+        results_log["index"] = i + 1
+        results_log["name"] = sorted_keys[i]
+        results_log["results"] = json_results[sorted_keys[i]]
+        json_log["test_groups"].append(results_log)
+    # write out JSON log
+    with open(json_file, 'w') as outfile:
+        json.dump(json_log, outfile, sort_keys=True, indent=4)
+report_formatters = {
+        'json': generate_json_report
 def run(args, command_path = None):
     import sys
     tests = []
@@ -227,6 +291,8 @@ def run(args, command_path = None):
         optargs = { '--rtems-tools':    'The path to the RTEMS tools',
                     '--rtems-bsp':      'The RTEMS BSP to run the test on',
                     '--user-config':    'Path to your local user configuration INI file',
+                    '--report-format':  'Formats in which to report test results in addition to txt: json',
+                    '--log':            'Log output location',
                     '--report-mode':    'Reporting modes, failures (default),all,none',
                     '--list-bsps':      'List the supported BSPs',
                     '--debug-trace':    'Debug trace based on specific flags (console,gdb,output,cov)',
@@ -251,6 +317,20 @@ def run(args, command_path = None):
             else:
                 to_addr = 'build at rtems.org'
             output = log_capture()
+        log_location = opts.find_arg('--log')
+        if log_location is not None:
+            log_location = log_location[1]
+        report_formats = opts.find_arg('--report-format')
+        if report_formats is not None:
+            if len(report_formats) != 2:
+                raise error.general('invalid RTEMS report formats option')
+            if log_location is None:
+                raise error.general('log location not provided for alternate output format(s)')
+            report_formats = report_formats[1].split(',')
+            for report_format in report_formats:
+                if report_format not in report_formatters:
+                    raise error.general('invalid RTEMS report formatter specified "%s"' % report_format)
         log.notice('RTEMS Testing - Tester, %s' % (version.string()))
         if opts.find_arg('--list-bsps'):
             bsps.list(opts)
@@ -360,6 +440,10 @@ def run(args, command_path = None):
         total_time = 'Testing time     : %s' % (str(end_time - start_time))
         log.notice(average_time)
         log.notice(total_time)
+            report_formatters[report_format](args, reports, start_time,
+                    end_time, total, '.'.join([log_location, report_format]))
         if mail is not None and output is not None:
             m_arch = opts.defaults.expand('%{arch}')
             m_bsp = opts.defaults.expand('%{bsp}')
2.11.0
