Mounting/Accessing SD-Card on BBB
Christian Mauderer list at c-mauderer.de
Mon Aug 19 19:33:06 UTC 2019
Hello Nils,
I don't know why -1 instead of NULL (which would be the normal error
case for a pointer) has been chosen for mmap. But: 0xFFFFFFFF is the
same as -1. It's just how basically any controller represents a negative
number. See https://en.wikipedia.org/wiki/Two%27s_complement
So you get an error case. Try to check errno what went wrong. Note that
errno is a bit hard to read with a debugger. It's a thread local
variable and therefore somewhere in the thread information. Simplest way
to get it is to just print it with functions like err(...) or perror(...).
Note that mmap on a file (like on a SD) is working a bit odd in RTEMS. I
think the current implementation just allocates a big enough space,
reads the entire file and returns the pointer. The file is written back
on munmap. So more of a compatibility implementation for porting some
applications than a really useful one.
For a libbsd driver the file system should pass the call to the drivers
mmap. Note that this only works if you have the commit that has been
added by Vijay a few weeks back:
https://git.rtems.org/rtems-libbsd/commit/?id=b68ca55c964cac5a6940e27f2880ee740cb1618a
PS: If you did a check like
    if (myreturnvalue == -1) {
        /* error handling */
please check your warnings. I'm not sure whether that check would work
in that form or not. But the compiler will throw a warning like
"comparison of signed and unsigned" or similar if it doesn't. I would
always suggest to enable all warnings (-Wall) and then fix all of them.
An application with warnings often has hidden bugs in some edge cases.
Some projects even enforce fixing warnings with enabling -Werror which
isn't a bad idea.
Best regards
Christian
On 19/08/2019 16:43, Nils Hölscher wrote:
> Sorry I forgot to add devel again.
> On Mon, 19 Aug 2019 at 16:33, Nils Hölscher <nilhoel1 at gmail.com
> <mailto:nilhoel1 at gmail.com>> wrote:
>     Hi,
>     Sorry that was an old example I didn't want to send that.
>     I looked more into the problem and the files do open.
>     But mmap always returns 0xffffffff as pointer.
>     And this holds for all files, whether I want to open an object on
>     SD-Card or the /dev/pruss0.irq2 device.
>     It seems my problem is not PRU driver related.
>     And I don't know what is causing this behaviour.
>     Cause if mmap fails it should actually return -1.
>     Best,
>     Nils
>     On Sun, 18 Aug 2019 at 14:45, Christian Mauderer <list at c-mauderer.de
>     <mailto:list at c-mauderer.de>> wrote:
>         Hello Nils,
>         please note: I re-added the devel list (wasn't this thread
>         originally on
>         users?). I hope that is OK.
>         On 18/08/2019 13:23, Nils Hölscher wrote:
>         > Hello Christian,
>         > On Sat, 17 Aug 2019 at 15:30, Christian Mauderer
>         <list at c-mauderer.de <mailto:list at c-mauderer.de>
>         > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>         >     On 17/08/2019 15:11, Nils Hölscher wrote:
>         >     > HI Christian,
>         >     > This was very helpful as always.
>         >     > But I think I didn't explain enough.
>         >     > The PRU driver runs just fine I was able to load code
>         onto pru and
>         >     wait
>         >     > for its return via interrupt.
>         >     > I could also show that it runs the exact expected amount
>         of time.
>         >     > So no problem there.
>         >     Great if that works.
>         >     > The other thing I am trying and where I fail is:
>         >     > First I route interrupts to a file.
>         >     > With these four commands:
>         >     > sysctl dev.ti_pruss.0.irq.2.channel=2 # mapping channel
>         2 to irq2
>         >     > sysctl dev.ti_pruss.0.irq.2.event=16 # mapping event 16
>         to irq2
>         >     > sysctl dev.ti_pruss.0.irq.2.enable=1 # enable the irq2
>         >     > sysctl dev.ti_pruss.0.global_interrupt_enable=1 # enable
>         PRU global
>         >     > interrupts
>         >     > After that I get the device /dev/pruss0.irq2.
>         >     > And I want to read the interrupts from this file with
>         the code you
>         >     saw.
>         >     If i understood the interface correctly you should get a
>         read that is
>         >     blocking till the next interrupt?
>         >     I had a quick look at the ti_pruss_irq_read in the FreeBSD
>         version that
>         >     is used as base for our current libbsd. There is a case
>         for O_NONBLOCK:
>          https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L254
>         >     You might try that one to make sure nothing odd happens
>         with the
>         >     blocking version. Maybe libbsd handles something different
>         compared to
>         >     FreeBSD and the driver doesn't expect it.
>         > The thing is this function gets mapped to the device that is
>         created
>         > with the sysctl command.
>         > The ti_pruss_irq_read function is part of this struct.
>         https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L116
>         > And is mapped to the Pruss0.irqN device with
>         ti_pruss_interrupts_enable:
>         https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L313
>         > And this function is called by sysctl and get registered here:
>         https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L573
>         Yes. That looks OK. You get the file so the device is added
>         correctly.
>         > But when I wanted to debug with a breakpoint set to
>         ti_pruss_irq_read,
>         > rtems crashed before calling this function, that should be
>         mapped to the
>         > device.
>         > With this Backtrace:
>         > (gdb) backtrace
>         > #0  strcmp ()
>         >     at
>         ../../../../../../gnu-mirror-gcc-fb371a33fa6/newlib/libc/machine/arm/strcmp-armv4.S:70
>         > #1  0x802a94d4 in rtems_shell_lookup_cmd (
>         >     cmd=0x20 <error: Cannot access memory at address 0x20>)
>         At this point it seems that there is already a problem with your
>         shell
>         command. The function should get a `const char *` pointer. Your
>         pointer
>         currently points to 0x20 which is definitively no memory
>         location. Most
>         likely you'll get an exception as soon as this pointer is passed
>         to the
>         strcmp.
>         >     at
>         /home/nils/development/src/rtems/c/src/../../cpukit/libmisc/shell/shell_cmdset.c:99
>         > #2  0x802a9740 in rtems_shell_execute_cmd (
>         >     cmd=0x802f3a5c "cat", argc=2, argv=0x80920001)
>         >     at
>         /home/nils/development/src/rtems/c/src/../../cpukit/libmisc/shell/shell_cmdset.c:252
>         > #3  0x8000069c in testirq (argc=<optimized out>,
>         >     argv=<optimized out>) at ../../main.c:247
>         > --Type <RET> for more, q to quit, c to continue without paging--
>         What is this `testirq` function? From the name I would expect
>         that it is
>         your shell command. But why does it call rtems_shell_execute_cmd
>         as it's
>         next function?
>         If it is correct for some reason: Please check the argv that you
>         pass to
>         rtems_shell_execute_cmd(). The 0x20 in #1 looks suspiciously like a
>         ASCII space character. Maybe you passed argv[1] instead of
>         &argv[1] or
>         *argv instead of argv to the cat function?
>         > #4  0x802a8a80 in rtems_shell_main_loop (
>         >     shell_env_arg=<optimized out>)
>         >     at
>         /home/nils/development/src/rtems/c/src/../../cpukit/libmisc/shell/shell.c:921
>         > #5  0x802a932c in rtems_shell_task (
>         >     task_argument=<optimized out>)
>         >     at
>         /home/nils/development/src/rtems/c/src/../../cpukit/libmisc/shell/shell.c:678
>         > #6  0x8029e0fc in _Thread_Handler ()
>         >     at
>         /home/nils/development/src/rtems/c/src/../../cpukit/score/src/threadhandler.c:135
>         > #7  0x8029deec in _Thread_Do_dispatch (
>         >     cpu_self=<optimized out>, level=<optimized out>)
>         >     at
>         /home/nils/development/src/rtems/c/src/../../cpukit/score/src/threaddispatch.c:302
>         > #8  0x00000000 in ?? ()
>         >  I think rtems crashed before interacting with the device
>         driver at all.
>         > Have a nice Sunday,
>         > Nils
>         >     Regarding the mmap for the non-interrupt files: It's a
>         quite simple
>         >     function and it should work:
>          https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/arm/ti/ti_pruss.c#L701
>         >     > Obviously the interrupts are triggered by code on the PRU.
>         >     > This is the proof of concept FreeBSD used.
>         >     > https://reviews.freebsd.org/D11959
>         >     > But maybe the test I already ran is proof enough.
>         >     Please discuss that with your mentor.
>         >     > And this could also be a problem with the sysctl command.
>         >     As far as I understood it you get the file after you run a
>         bunch of
>         >     sysctl commands? So it seems that this works.
>         >     > Best,
>         >     > Nils
>         >     > On Sat, 17 Aug 2019 at 14:59, Christian Mauderer
>         >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>         >     >     Hello Nils,
>         >     >     On 17/08/2019 14:04, Nils Hölscher wrote:
>         >     >     > On Sat, 17 Aug 2019 at 13:34, Christian Mauderer
>         >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>         >     >     > <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>         >     >     >     Hello Nils,
>         >     >     >     "sometimes" sounds odd. That needs a
>         difference on each run.
>         >     >     Do you use
>         >     >     >     a shell command to open the file (so that
>         there is a timing
>         >     >     difference)?
>         >     >     > Yes I do.
>         >     >     > I was able to load the code to the pru as arrays,
>         cause the pru
>         >     >     > assembler "pasm" can output header files.
>         >     >     > So I am no longer working with SD-Card.
>         >     >     So you have a workaround. That's good.
>         >     >     >     Some guesses for typical "sometimes" problems:
>         >     >     >     - Do you have some pointer problem (use of an
>         >     uninitialized one,
>         >     >     >     unhandled error cases for functions that return
>         >     pointers, ...)?
>         >     >     >     Initialize all local pointer variables with
>         NULL to get
>         >     >     reproduceable
>         >     >     >     results.
>         >     >     > I am just using these few lines of code to show
>         the IRQ
>         >     interrupts of
>         >     >     > the PRU test programm.
>         >     >     > I dont' know what I shall set to NULL.
>         >     >     > int testirq( int argc, char* argv[] )
>         >     >     >     int fd = 0;
>         >     >     There's a check missing whether argc is >= 2. But that
>         >     shouldn't be the
>         >     >     problem as long as you pass a parameter.
>         >     >     >     printf("opening of %s ", argv[1]);
>         >     >     >     fd = open( argv[1], O_RDONLY);
>         >     >     >     if (fd == -1)
>         >     >     >         perror("open");
>         >     >     >     for(;;)
>         >     >     >         uint64_t time;
>         >     >     >         //printk("=== read file\n");
>         >     >     >         while( read(fd, &time, sizeof(time)) > 0 )
>         >     >     Although not your problem. But is this a blocking
>         read till
>         >     you get
>         >     >     something? Otherwise you'll get a lot of prints with
>         random
>         >     values.
>         >     >     >             printk("=> %llu.%09llu \n",
>         >     >     time/1000000000,time%1000000000);
>         >     >     >     close(fd);
>         >     >     >     return EXIT_SUCCESS;
>         >     >     >     - Are there some big stack variables (local
>         arrays with
>         >     sizes
>         >     >     > 100
>         >     >     >     Byte)? Maybe your stack is too small and
>         overflows.
>         >     >     > I thought that too and I don't use big objects and
>         even
>         >     doubled my
>         >     >     Stack
>         >     >     > size just to be sure.
>         >     >     > The mention Arrays containing PRUcode are also
>         just in the
>         >     length
>         >     >     of 10.
>         >     >     OK. Was just a guess.
>         >     >     You say something of an interrupt that you expect.
>         Maybe a
>         >     priority
>         >     >     problem? I'm still guessing a bit about the
>         application but I
>         >     would
>         >     >     expect something like the following:
>         >     >     - You load some code into your PRUs.
>         >     >     - The PRU causes an interrupt.
>         >     >     - That is processed via the libbsd PRU driver?
>         >     >     - In that case: An interrupt server with high
>         priority will
>         >     process the
>         >     >     interrupt.
>         >     >     If the interrupt flags are not handled correctly, the
>         >     interrupt maybe is
>         >     >     triggered again after the interrupt routine
>         finishes. In that
>         >     case you
>         >     >     jump between interrupt and interrupt server which
>         both have a
>         >     higher
>         >     >     priority than your shell. Your system wouldn't react
>         to any
>         >     user input
>         >     >     any more. It would "hang".
>         >     >     That mmap fails can have different reasons. We can
>         only do
>         >     very simple
>         >     >     mmaps in RTEMS. Basically if the driver tries to do
>         anything
>         >     more but
>         >     >     passing an pointer it won't work. So check whether
>         your driver
>         >     tries
>         >     >     something like mapping memory to some new location.
>         >     >     Best regards
>         >     >     Christian
>         >     >     > Thanks,
>         >     >     > Nils
>         >     >     >     Best regards
>         >     >     >     Christian
>         >     >     >     On 17/08/2019 12:11, Nils Hölscher wrote:
>         >     >     >     > Hi,
>         >     >     >     > I have a new BBB now, but the problem still
>         persists.
>         >     >     >     > So my guess about the broken SD Card slot,
>         causing the
>         >     problem,
>         >     >     >     was wrong.
>         >     >     >     > The other thing is that I am not always able to
>         >     recreate the
>         >     >     problem.
>         >     >     >     > Sometimes rtems freezes on the open call for
>         the file
>         >     on the SD.
>         >     >     >     > And when it passes that line, my program
>         fails using
>         >     mmap on the
>         >     >     >     > returned file descriptor.
>         >     >     >     > Best,
>         >     >     >     > Nils
>         >     >     >     > On Fri, 16 Aug 2019 at 16:28, Nils Hölscher
>         >     >     <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>
>         >     >     >     <mailto:nilhoel1 at gmail.com
>         <mailto:nilhoel1 at gmail.com> <mailto:nilhoel1 at gmail.com
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>
>         >     >     >     > <mailto:nilhoel1 at gmail.com
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>> wrote:
>         >     >     >     >     Hi Gerade,
>         >     >     >     >     Yes I checked with two cards and both
>         are working fine
>         >     >     on Linux.
>         >     >     >     >     Best,
>         >     >     >     >     Nils
>         >     >     >     >     Gedare Bloom <gedare at rtems.org
>         <mailto:gedare at rtems.org>
>         >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
>         >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>
>         >     >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>
>         >     >     >     <mailto:gedare at rtems.org
>         <mailto:gedare at rtems.org> <mailto:gedare at rtems.org
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>> schrieb am
>         >     >     >     >     Fr., 16. Aug. 2019, 16:25:
>         >     >     >     >         On Fri, Aug 16, 2019 at 6:04 AM
>         Christian Mauderer
>         >     >     >     >         <list at c-mauderer.de
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>         >     >     >     >         > Hello Nils,
>         >     >     >     >         > you are right that system freezes
>         are not a
>         >     wanted
>         >     >     >     behaviour. But
>         >     >     >     >         > hot-plugging a disk isn't that
>         common in
>         >     embedded
>         >     >     systems
>         >     >     >     >         (except maybe
>         >     >     >     >         > for USB drives). It's a case that
>         isn't
>         >     tested that
>         >     >     >     often. So most
>         >     >     >     >         > likely no one noticed that bug. I
>         wouldn't
>         >     see it
>         >     >     >     critical as
>         >     >     >     >         long as I
>         >     >     >     >         > don't have a project where I need
>         that (either
>         >     >     hobby or
>         >     >     >     funded).
>         >     >     >     >         +1
>         >     >     >     >         > Is this a blocking problem for
>         your project? If
>         >     >     not you
>         >     >     >     might
>         >     >     >     >         want to
>         >     >     >     >         > fill a bug report for this. But I
>         suspect
>         >     that no
>         >     >     one will
>         >     >     >     >         work on that
>         >     >     >     >         > too fast as long as there is no urgent
>         >     necessity.
>         >     >     >     >         > Note that if it would have been a
>         FAT bug the
>         >     >     situation
>         >     >     >     would
>         >     >     >     >         have been
>         >     >     >     >         > quite different. FAT bugs are bad
>         for all
>         >     targets
>         >     >     and for
>         >     >     >     >         quite some
>         >     >     >     >         > funded projects too. So I would
>         have tried
>         >     to fix that
>         >     >     >     as soon
>         >     >     >     >         as possible.
>         >     >     >     >         > Best regards
>         >     >     >     >         > Christian
>         >     >     >     >         > On 16/08/2019 12:08, Nils Hölscher
>         wrote:
>         >     >     >     >         > > Ok.
>         >     >     >     >         > > But back to the bug.
>         >     >     >     >         > > The behaviour I described should be
>         >     reproducible by
>         >     >     >     removing
>         >     >     >     >         SD-Card
>         >     >     >     >         > > after it was mounted.
>         >     >     >     >         > > And then the System should
>         freeze when open is
>         >     >     called on
>         >     >     >     >         some file on
>         >     >     >     >         > > SD-Card.
>         >     >     >     >         > > System freezes can't be wanted
>         behaviour.
>         >     >     >     >         We have occasionally received bug
>         reports like
>         >     this.
>         >     >     It is
>         >     >     >     better to
>         >     >     >     >         avoid unplugging something that is
>         being accessed.
>         >     >     Even in
>         >     >     >     commodity
>         >     >     >     >         systems that can cause data
>         corruption on the
>         >     >     device. In fact,
>         >     >     >     >         did you
>         >     >     >     >         confirm with a new SDcard that it is
>         the BBB
>         >     that is
>         >     >     >     broken, and not
>         >     >     >     >         the SDCard that has gone bad?
>         >     >     >     >         > > Best,
>         >     >     >     >         > > Nils
>         >     >     >     >         > > On Fri, 16 Aug 2019 at 11:40,
>         Christian
>         >     Mauderer
>         >     >     >     >         > > <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
>         >     >     >     >         > >     PS: If neither the SD nor
>         the eMMC has a
>         >     >     bootable
>         >     >     >     image
>         >     >     >     >         your BBB falls
>         >     >     >     >         > >     back to serial and then USB boot
>         >     anyway. So
>         >     >     no need to
>         >     >     >     >         change any
>         >     >     >     >         > >     boot pins.
>         >     >     >     >         > >     On 16/08/2019 11:38, Christian
>         >     Mauderer wrote:
>         >     >     >     >         > >     > Hello Nils,
>         >     >     >     >         > >     > if the U-Boot doesn't
>         start from
>         >     eMMC any
>         >     >     more it
>         >     >     >     >         won't be easy.
>         >     >     >     >         > >     > Theoretically it is
>         possible to boot via
>         >     >     serial. See
>         >     >     >     >         for example
>              http://linuxkernel51.blogspot.com/2015/08/booting-beagle-bone-black-over-uart.html
>         >     >     >     >         > >     > With that you could load
>         an U-Boot (via
>         >     >     X-Modem)
>         >     >     >     that
>         >     >     >     >         could start a
>         >     >     >     >         > >     > system from USB (image
>         from Beagle home
>         >     >     page maybe
>         >     >     >     >         could work if
>         >     >     >     >         > >     it can
>         >     >     >     >         > >     > boot from USB) that could
>         re-write the
>         >     >     eMMC. Most
>         >     >     >     >         likely it would
>         >     >     >     >         > >     need a
>         >     >     >     >         > >     > few hours to a day to
>         figure out the
>         >     >     details. So you
>         >     >     >     >         should
>         >     >     >     >         > >     definitively
>         >     >     >     >         > >     > order a replacement as a
>         backup
>         >     solution.
>         >     >     >     >         > >     > Best regards
>         >     >     >     >         > >     > Christian
>         >     >     >     >         > >     > On 16/08/2019 11:13, Nils
>         Hölscher
>         >     wrote:
>         >     >     >     >         > >     >> Hi Christin,
>         >     >     >     >         > >     >> Thanks for the hint.
>         >     >     >     >         > >     >> But how can I alter the
>         U- Boot on
>         >     eMMC?
>         >     >     >     >         > >     >> Problem is I have a Linux
>         version
>         >     with an
>         >     >     >     U-Boot that
>         >     >     >     >         disables
>         >     >     >     >         > >     emmc on
>         >     >     >     >         > >     >> the emmc...
>         >     >     >     >         > >     >> And I guess I cant flash emmc
>         >     without SD.
>         >     >     >     >         > >     >> Best,
>         >     >     >     >         > >     >> Nils
>         >     >     >     >         > >     >> On Fri, 16 Aug 2019 at
>         11:03, Christian
>         >     >     Mauderer
>         >     >     >     >         > >     <list at c-mauderer.de
>         <mailto:list at c-mauderer.de>>>>>>>>
>         >     >     >     wrote:
>         >     >     >     >         > >     >>     On 16/08/2019 10:55, Nils
>         >     Hölscher wrote:
>         >     >     >     >         > >     >>     > Hi,
>         >     >     >     >         > >     >>     > It seems the
>         problem was hardware
>         >     >     related.
>         >     >     >     >         > >     >>     > My SD-Card
>         connector just died.
>         >     >     >     >         > >     >>     > I hope I can get a
>         new BBB
>         >     oin a timely
>         >     >     >     manner.
>         >     >     >     >         > >     >>     > Best,
>         >     >     >     >         > >     >>     > Nils
>         >     >     >     >         > >     >>     Hello Nils,
>         >     >     >     >         > >     >>     thanks for the
>         information. That's
>         >     >     >     annoying. Good
>         >     >     >     >         luck finding a
>         >     >     >     >         > >     >>     replacement.
>         >     >     >     >         > >     >>     For a quick workaround: I
>         >     haven't tried
>         >     >     >     that yet
>         >     >     >     >         but if your
>         >     >     >     >         > >     on-board
>         >     >     >     >         > >     >>     eMMC is still intact,
>         you might can
>         >     >     use that
>         >     >     >     >         U-Boot to boot
>         >     >     >     >         > >     from USB.
>         >     >     >     >         > >     >>     Best regards
>         >     >     >     >         > >     >>     Christian
>         >     >     >     >         > >     >>     > On Fri, 16 Aug 2019
>         at 10:48,
>         >     Christian
>         >     >     >     Mauderer
>         >     >     >     >         > >     >>     <list at c-mauderer.de
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>>>
>         wrote:
>         >     >     >     >         > >     >>     >     Hello Nils,
>         >     >     >     >         > >     >>     >     thanks for the
>         file list.
>         >     I can't
>         >     >     >     reproduce
>         >     >     >     >         your
>         >     >     >     >         > >     problem with it.
>         >     >     >     >         > >     >>     >     On 16/08/2019
>         10:01, Nils
>         >     >     Hölscher wrote:
>         >     >     >     >         > >     >>     >     > Hi,
>         >     >     >     >         > >     >>     >     > Short update.
>         >     >     >     >         > >     >>     >     > It seems the
>         device
>         >     only hangs
>         >     >     >     while I am
>         >     >     >     >         connected
>         >     >     >     >         > >     with the
>         >     >     >     >         > >     >>     debugger.
>         >     >     >     >         > >     >>     >     Is that true
>         for the original
>         >     >     file system
>         >     >     >     >         tree? You are
>         >     >     >     >         > >     >>     debugging via
>         >     >     >     >         > >     >>     >     Ethernet,
>         right? In that
>         >     case I
>         >     >     would
>         >     >     >     lean
>         >     >     >     >         more toward a
>         >     >     >     >         > >     >>     problem with
>         >     >     >     >         > >     >>     >     the debugger
>         support than
>         >     the file
>         >     >     >     system.
>         >     >     >     >         Do you have
>         >     >     >     >         > >     enough file
>         >     >     >     >         > >     >>     >     descriptors
>         configured?
>         >     >     >     >         > >     >>     >     Best regards
>         >     >     >     >         > >     >>     >     Christian
>         >     >     >     >         > >     >>     >     > looks like a
>         Heisenberg
>         >     bug.
>         >     >     >     >         > >     >>     >     > Best,
>         >     >     >     >         > >     >>     >     > Nils
>         >     >     >     >         > >     >>     >     > On Fri, 16
>         Aug 2019 at
>         >     09:50,
>         >     >     Nils
>         >     >     >     Hölscher
>         >     >     >     >         > >     >>     <nilhoel1 at gmail.com
>         >     >     >     >         > >     <mailto:nilhoel1 at gmail.com
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>>>
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>>>>
>         <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>>>>>>
>         wrote:
>         >     >     >     >         > >     >>     >     >     On Thu,
>         15 Aug 2019
>         >     at 19:51,
>         >     >     >     >         Christian Mauderer
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>>>>
>         wrote:
>         >     >     >     >         > >     >>     >     >         Hello
>         Nils,
>         >     >     >     >         > >     >>     >     >         maybe
>         another
>         >     bug in our
>         >     >     >     FAT file
>         >     >     >     >         system...
>          Please do three
>         >     things:
>         >     >     >     >         > >     >>     >     >         1.
>         Create an
>         >     image of
>         >     >     your
>         >     >     >     >         current card (with
>         >     >     >     >         > >     dd or
>         >     >     >     >         > >     >>     a similar
>          tool). FAT
>         >     >     >     >         > >     >>     >     >         bugs
>         are sometimes
>         >     >     hard to
>         >     >     >     >         reproduce but it's
>         >     >     >     >         > >     really
>         >     >     >     >         > >     >>     >     urgent that
>         >     >     >     >         > >     >>     >     >         we fix
>         >     >     >     >         > >     >>     >     >         them.
>         So maybe I'll
>         >     >     ask for
>         >     >     >     that
>         >     >     >     >         image later.
>         >     >     >     >         > >     >>     >     >     I did that.
>         >     >     >     >         > >     >>     >     >     Let me
>         know if you need
>         >     >     the image.
>         >     >     >     >         > >     >>     >     >         2.
>         Create a
>         >     complete list
>         >     >     >     of the
>         >     >     >     >         files on
>         >     >     >     >         > >     your card (for
>         >     >     >     >         > >     >>     >     example the
>         >     >     >     >         > >     >>     >     >         Linux
>         `tree -h`
>         >     command),
>         >     >     >     post it
>         >     >     >     >         here and
>         >     >     >     >         > >     tell me
>         >     >     >     >         > >     >>     what you
>         >     >     >     >         > >     >>     >     >         tried
>         to open.
>         >     >     >     >         > >     >>     >     >     ├── [ 50K]
>         >     >     am335x-boneblack.dtb
>         >     >     >     >         > >     >>     >     >     ├── [ 49K]
>         >     >     >     am335x-boneblack+pruss.dtb
>         >     >     >     >         > >     >>     >     >     ├── [ 883]
>         >     >     >     AM335X-PRU-UIO-00A0.dtbo
>         >     >     >     >         > >     >>     >     >     ├── [ 649]
>         >     >     >     AM335X-PRU-UIO-BSD-00A0.dtbo
>         >     >     >     >         > >     >>     >     >     ├── [162K]
>         >     >     Linux-with-UIO.dtb
>         44]  loob.bin
>         [108K]  MLO
>         [2.1M]  pru.exe.img
>         12]  test.bin
>         [471K]  u-boot.img
>         >     >     >     >         > >     >>     >     >     ├── [ 390]
>         >     uEnvLinuxfdt.txt
>         560]  uEnv.txt
>         >     >     >     >         > >     >>     >     >          3.
>         Try another
>         >     name /
>         >     >     >     folder for
>         >     >     >     >         the file
>         >     >     >     >         > >     you wanted to
>         >     >     >     >         > >     >>     >     open.\
>         >     >     >     >         > >     >>     >     >     I moved
>         the file in
>         >     >     another folder
>         >     >     >     >         and renamed it.
>         >     >     >     >         > >     >>     >     >     It now
>         works but I
>         >     got en
>         >     >     >     error, I am
>         >     >     >     >         currently
>         >     >     >     >         > >     >>     investigating if
>         >     >     >     >         > >     >>     >     >     this is
>         on the pru
>         >     driver
>         >     >     side
>         >     >     >     or not.
>         >     >     >     >         > >     >>     >     >     The tree
>         while
>         >     doing this
>         >     >     was:
>         44]  loob.bin
>         [108K]  MLO
>         [2.1M]  pru.exe.img
>         [2.0K]  test
>         [  12]
>         >     test2.bin
>         12]  test2.bin
>         [471K]  u-boot.img
>         >     uEnvLinuxfdt.txt
>         560]  uEnv.txt
>         >     >     >     >         > >     >>     >     >     Thanks,
>         regards
>         >     >     >     >         > >     >>     >     >         Christian
>         >     >     >     >         > >     >>     >     >         On
>         15/08/2019
>         >     19:32, Nils
>         >     >     >     >         Hölscher wrote:
>         >     >     >     >         > >     >>     >     >         > Hi
>         Christian,
>         >     >     >     >         > >     >>     >     >         > The
>         commands
>         >     ls and
>         >     >     cat work.
>         >     >     >     >         > >     >>     >     >         > I
>         just tested
>         >     them,
>         >     >     this
>         >     >     >     seems
>         >     >     >     >         kinda awkward.
>         >     >     >     >         > >     >>     >     >         > Best,
>         >     >     >     >         > >     >>     >     >         > Nils
>         >     >     >     >         > >     >>     >     >         > On
>         Thu, 15
>         >     Aug 2019
>         >     >     at 19:27,
>         >     >     >     >         Christian
>         >     >     >     >         > >     Mauderer
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>>>>>
>         wrote:
>          Hello Nils,
>          does some
>         >     other
>         >     >     access to
>         >     >     >     >         the file system
>         >     >     >     >         > >     >>     work? Like
>         >     >     >     >         > >     >>     >     a ls
>         >     >     >     >         > >     >>     >     >         on
>         the console
>         >     >     >     >         > >     >>     >     >         >     or
>         >     creating a file.
>         >     >     >     Can you
>         >     >     >     >         do a `cat`
>         >     >     >     >         > >     on some
>         >     >     >     >         > >     >>     text file
>         >     >     >     >         > >     >>     >     >         on
>         the file
>          system?
>         >     If not:
>         >     >     Does it
>         >     >     >     >         work for a file
>         >     >     >     >         > >     in the
>         >     >     >     >         > >     >>     root file
>          system (should
>          be a IMFS)?
>          Best regards
>          Christian
>          On 15/08/2019
>         >     >     15:54, Nils
>          > Hi,
>          > I when
>         >     my app
>         >     >     wants to
>         >     >     >     >         open a file on
>         >     >     >     >         > >     the SD
>         >     >     >     >         > >     >>     card
>          dev=mmcsd-0-0 rtems
>          > freezes.
>          > Exact
>         >     call is:
>          > fd =
>         >     open(file,
>         >     >     >     O_RDONLY);
>          > With file
>         >     >     being the pru
>         >     >     >     >         binary I want
>         >     >     >     >         > >     to upload.
>          > Thanks,
>          > Nils
>          > On Tue, 13
>         >     >     Aug 2019
>         >     >     >     at 17:56,
>         >     >     >     >         > >     Christian Mauderer
>          <christian.mauderer at embedded-brains.de
>         <mailto:christian.mauderer at embedded-brains.de>
>         <mailto:christian.mauderer at embedded-brains.de>>
>         >     >     <mailto:christian.mauderer at embedded-brains.de
>         <mailto:christian.mauderer at embedded-brains.de>>>
>         >     >     >     <mailto:christian.mauderer at embedded-brains.de
>         <mailto:christian.mauderer at embedded-brains.de>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>>>>>>
>         <mailto:christian.mauderer at embedded-brains.de>>>>>>>>>>>> wrote:
>         >      Hello Nils,
>          >     a third
>         >     >     >     possibility:
>         >     >     >     >         You could
>         >     >     >     >         > >     start a
>         >     >     >     >         > >     >>     FTP server
>         >     >     >     >         > >     >>     >     >         and
>         push the
>          file
>          >     via
>         >     network.
>         >      Best regards
>         >      Christian
>          >     Am
>         >     >     Dienstag, 13.
>         >     >     >     >         August 2019
>         >     >     >     >         > >     schrieb Nils
>         >     >     >     >         > >     >>     >     Hölscher:
>          >     > Hi,
>         >     Thanks
>         >     >     for the
>         >     >     >     >         input I will try
>         >     >     >     >         > >     the SD
>         >     >     >     >         > >     >>     card
>         >     >     >     >         > >     >>     >     first.
>          >     > That
>         >     >     way I won't
>         >     >     >     >         have to alter the
>         >     >     >     >         > >     >>     code when I
>         >     >     >     >         > >     >>     >     >         want
>         to run other
>         >      stuff on
>         >     >     the pru.
>          >     > Best,
>          >     > Nils
>         >     On Tue, 13
>         >     >     >     Aug 2019
>         >     >     >     >         at 17:32,
>         >     >     >     >         > >     Gedare Bloom
>         >      <gedare at rtems.org <mailto:gedare at rtems.org>
>         >     >     >     >         <mailto:gedare at rtems.org
>         >     >     >     >         > >     <mailto:gedare at rtems.org
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>>
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>>>
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>>>>
>         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>>>>>>> wrote:
>         >     You can
>         >     >     also
>         >     >     >     build
>         >     >     >     >         the PRU
>         >     >     >     >         > >     image into
>         >     >     >     >         > >     >>     the RTEMS
>          binary. See
>         >     >     >     >         examples-v2.git/file_io/crc/init.c
>         >     On Tue,
>         >     >     Aug 13,
>         >     >     >     >         2019 at 8:46 AM
>         >     >     >     >         > >     Christian
>         >     >     >     >         > >     >>     >     Mauderer
>         <mailto:list at c-mauderer.de>>>>>>>>>>>> wrote:
>         >     Hello
>         >     >     Nils,
>         >     that's a
>         >     >     >     bit odd.
>         >     >     >     >         I attached
>         >     >     >     >         > >     an expected
>         >     >     >     >         > >     >>     >     output
>         >     >     >     >         > >     >>     >     >         below.
>          Some guesses:
>         >     - Did you
>         >     >     >     add FAT
>         >     >     >     >         file system
>         >     >     >     >         > >     to your
>         >     >     >     >         > >     >>     >     application?
>         >     - Is
>         >     >     there some
>         >     >     >     >         odd formatting on
>         >     >     >     >         > >     >>     the SD?
>          Normally at
>          least the FAT
>         >     partition
>         >     >     >     used by
>         >     >     >     >         U-Boot
>         >     >     >     >         > >     should be
>         >     >     >     >         > >     >>     visible.
>         >     - Is
>         >     >     your BDBUF
>         >     >     >     >         configuration OK?
>         >     - Do
>         >     >     you have
>         >     >     >     >         enough file
>         >     >     >     >         > >     descriptors?
>         >     Beneath
>         >     >     >     that: If
>         >     >     >     >         you only need
>         >     >     >     >         > >     >>     something where
>         >     >     >     >         > >     >>     >     >         you
>         can put
>          some
>          >     files,
>          >     > > you
>         >     >     can try to
>         >     >     >     >         connect a USB
>         >     >     >     >         > >     stick
>         >     >     >     >         > >     >>     instead.
>         >     >     >     >         > >     >>     >     >         Maybe
>         that
>          works better.
>         >     Best
>         >     >     regards
>         >     Christian
>         >     media
>         >     >     listener:
>         >     >     >     >         event = DISK
>         >     >     >     >         > >     ATTACH,
>         >     >     >     >         > >     >>     state =
>          INQUIRY, src
>          = mmcsd
>         >     media
>         >     >     listener:
>         >     >     >     >         event = DISK
>         >     >     >     >         > >     ATTACH,
>          SUCCESS, src =
>         >      mmcsd, dest
>         >     >     /dev/mmcsd-0
>         >     media
>         >     >     listener:
>         >     >     >     >         event =
>         >     >     >     >         > >     MOUNT, state =
>         >     >     >     >         > >     >>     >     INQUIRY,
>         >     >     >     >         > >     >>     >     >         src =
>          /dev/mmcsd-0
>         >     >     mmcsd0: 4GB
>         >     >     >     <SDHC
>         >     >     >     >         TO 15.15 SN
>         >     >     >     >         > >     >>     000002F6 MFG
>          02/2017 by 25
>          DY> at mmc0
>         >     >     >     >         24.0MHz/4bit/65535-block
>         >     media
>         >     >     listener:
>         >     >     >     >         event =
>         >     >     >     >         > >     >>     >     FAILED, src =
>          /dev/mmcsd-0
>         >     media
>         >     >     listener:
>         >     >     >     >         event = PARTITION
>         >     >     >     >         > >     >>     INQUIRY,
>         >     >     >     >         > >     >>     >     state =
>          INQUIRY,
>         >     src =
>         >     >     /dev/mmcsd-0
>         >     media
>         >     >     listener:
>          SUCCESS,
>         >     src =
>         >     >     /dev/mmcsd-0
>         >     media
>         >     >     listener:
>         >     >     >     >         > >     >>     ATTACH,
>         INQUIRY,
>          src =
>         >     >     /dev/mmcsd-0
>         >     media
>         >     >     listener:
>         SUCCESS,
>          src =
>         >     >     >     /dev/mmcsd-0, dest =
>         >     >     >     >         > >     /dev/mmcsd-0-0
>         >     media
>         >     >     listener:
>         >     >     >     >         event =
>         >      /dev/mmcsd-0-0
>         >     media
>         >     >     listener:
>         >     >     >     >         event =
>         >     >     >     >         > >     >>     >     SUCCESS,
>         >     >      /dev/mmcsd-0-0,
>         >     dest =
>         >     >     >     >         /media/mmcsd-0-0
>         >     media
>         >     >     listener:
>         >     >     >     >         event = DISK
>         >     >     >     >         > >     ATTACH,
>          INQUIRY, src
>          = mmcsd
>         >     media
>         >     >     listener:
>         >     >     >     >         event = DISK
>         >     >     >     >         > >     ATTACH,
>          SUCCESS, src =
>         >      mmcsd, dest
>         >     >     /dev/mmcsd-1
>         >     media
>         >     >     listener:
>         >     >     >     >         event =
>          /dev/mmcsd-1
>         >     >     mmcsd1: 4GB
>         >     >     >     >         <MMCHC MMC04G 5.8 SN
>         >     >     >     >         > >     >>     160D224B MFG
>          09/2014 by 112
>         >      0x0000> at
>         >     mmc1
>         >     >     >     >         48.0MHz/8bit/65535-block
>         >     media
>         >     >     listener:
>         >     >     >     >         event =
>          /dev/mmcsd-1
>         >     media
>         >     >     listener:
>          INQUIRY,
>         >     src =
>         >     >     /dev/mmcsd-1
>         >     media
>         >     >     listener:
>         >     >     >     >         > >     >>     >     >         = FAILED,
>          src =
>         >     >     /dev/mmcsd-1
>         >     media
>         >     >     listener:
>         >     >     >     >         event = DISK
>         >     >     >     >         > >     ATTACH,
>          INQUIRY, src =
>         >      mmcsd1boot
>         >     >     >     mmcsd1boot0: 2MB
>         >     >     >     >         partion 1 at
>         >     >     >     >         > >     mmcsd1
>         >     >     >     mmcsd1boot1: 2MB
>         >     >     >     >         partion 2 at
>         >     >     >     >         > >     mmcsd1
>         >     >     mmcsd1rpmb:
>         >     >     >     131kB
>         >     >     >     >         partion 3
>         >     >     >     >         > >     at mmcsd1
>          >     > > On
>         >     >     13/08/2019
>         >     >     >     >         13:30, Nils
>         >     >     >     >         > >     Hölscher
>         >     >     >     >         > >     >>     wrote:
>         >     > Hi,
>         >     > Thanks
>         >     >     >     for the
>         >     >     >     >         help.
>         >     > I tried
>         >     >     >     to use
>         >     >     >     >         your code, but I
>         >     >     >     >         > >     >>     always get
>          "ERROR: SD
>          could not be
>         >     >     mounted after
>         >     >     >     >         timeout".
>         >     >     Even after
>         >     >     >     >         raising the
>         >     >     >     >         > >     waiting time.
>         >     > The
>         >     >     sources I
>         >     >     >     >         use start here:
>              https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
>         >     > And
>         >     >     my uart
>         >     >     >     >         output is:
>         >     > waiting
>         >     >     >     for SD...
>         >     > usbus0:
>         >     >     >     480Mbps
>         >     >     >     >         High Speed
>         >     >     >     >         > >     USB v2.0
>         >     > usbus1:
>         >     >     >     480Mbps
>         >     >     >     >         High Speed
>         >     >     >     >         > >     USB v2.0
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event = DISK
>         >     >     >     >         > >     >>     ATTACH, state =
>         >     >     >     >         > >     >>     >     >         INQUIRY,
>          src = mmcsd
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event = DISK
>          SUCCESS, src =
>         >      mmcsd, dest
>         >     >     >     /dev/mmcsd-0
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event =
>          INQUIRY, src =
>          /dev/mmcsd-0
>         >     >     ugen0.1:
>         >     >     >     >         <Mentor Graphics
>         >     >     >     >         > >     OTG Root
>         >     >     >     >         > >     >>     HUB>
>         >     >     >     >         > >     >>     >     at usbus0
>         >     >     ugen1.1:
>         >     >     >     >         > >     OTG Root
>         >     >     >     >         > >     >>     HUB>
>         >     >     >     >         > >     >>     >     at usbus1
>         >     > uhub0:
>         >     >     >     <Mentor
>         >     >     >     >         Graphics OTG
>         >     >     >     >         > >     Root
>         >     >     >     >         > >     >>     HUB, class
>         >     >     >     >         > >     >>     >     >         9/0, rev
>         >     >      2.00/1.00, addr 1>
>         >     > on
>         >     >     usbus0
>         >     > uhub1:
>         >     >     >     <Mentor
>         >     >     >     >         Graphics OTG
>         >     >     >     >         > >     Root
>         >     > on
>         >     >     usbus1
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event =
>          /dev/mmcsd-0
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event =
>         >     >     >     >         > >     PARTITION
>         >     >     >     >         > >     >>     >     INQUIRY, state =
>          INQUIRY,
>         >     src =
>         >     >     /dev/mmcsd-0
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event =
>         >     >     >     >         > >     PARTITION
>          SUCCESS,
>         >     src =
>         >     >     /dev/mmcsd-0
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event =
>         >     >     >     >         > >     PARTITION
>         >     >     >     >         > >     >>     >     ATTACH, state =
>          INQUIRY,
>         >     src =
>         >     >     /dev/mmcsd-0
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event =
>         >     >     >     >         > >     PARTITION
>          SUCCESS,
>         >     src =
>         >     >     /dev/mmcsd-0,
>         >     >     >     >         dest =
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event =
>          INQUIRY, src =
>         >     >      /dev/mmcsd-0-0
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event =
>         >     >      /dev/mmcsd-0-0
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event = DISK
>          src = mmcsd
>         >     > media
>         >     >     >     listener:
>         >     >     >     >         event = DISK
>          SUCCESS, src =
>         >      mmcsd, dest
>         >     >     >     /dev/mmcsd-1
