[PATCH v2] Add JSON log generation
Mon Aug 19 22:33:06 UTC 2019
On 20/8/19 2:13 am, Kinsey Moore wrote:
> Add log formatter hooks and JSON log formatter to the test infrastructure
> for consumption by automated processes or report generators.
>  tester/rt/test.py | 84 +++++++++++++++++++++++++++++++++++++++++++++++++++++++
>  1 file changed, 84 insertions(+)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index da0a11e..0ed799a 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -38,6 +38,7 @@ import re
>  import sys
>  import threading
>  import time
> +import json
The import list is sorted :)
>  from rtemstoolkit import configuration
>  from rtemstoolkit import error
> @@ -217,6 +218,69 @@ def killall(tests):
>      for test in tests:
>          test.kill()
> +def generate_json_report(args, reports, start_time, end_time, total, json_file):
> +    import sys
> +    json_log = {}
> +    json_log['Command Line'] = " ".join(args)
> +    json_log['Python'] = sys.version.replace('\n', '')
> +    json_log['test_groups'] = []
> +    json_log['Host'] = host.label(mode = 'all')
> +    json_log['summary'] = {}
> +    json_log['summary']['passed_count'] = reports.passed
> +    json_log['summary']['failed_count'] = reports.failed
> +    json_log['summary']['user-input_count'] = reports.user_input
> +    json_log['summary']['expected-fail_count'] = reports.expected_fail
> +    json_log['summary']['indeterminate_count'] = reports.indeterminate
> +    json_log['summary']['benchmark_count'] = reports.benchmark
> +    json_log['summary']['timeout_count'] = reports.timeouts
> +    json_log['summary']['invalid_count'] = reports.invalids
> +    json_log['summary']['wrong-version_count'] = reports.wrong_version
> +    json_log['summary']['wrong-build_count'] = reports.wrong_build
> +    json_log['summary']['wrong-tools_count'] = reports.wrong_tools
> +    json_log['summary']['total_count'] = reports.total
> +    json_log['summary']['average_test_time'] = str((end_time - start_time) / total)
> +    json_log['summary']['testing_time'] = str(end_time - start_time)
> +    result_types = ['failed', 'user-input', 'expected-fail', 'indeterminate', 'benchmark', 'timeout', 'invalid', 'wrong-version', 'wrong-build', 'wrong-tools']
There is a soft'ish limit that attempts to use 80 columns in the python code.
This one is too long.
> +    json_results = {}
> +    for result_type in result_types:
> +        json_log['summary'][result_type] = []
> +    # collate results for JSON log
> +    for name in reports.results:
> +        result_type = reports.results[name]['result']
> +        test_parts = name.split("/")
> +        test_category = test_parts[-2]
> +        test_name = test_parts[-1]
> +        if result_type != 'passed':
> +            json_log['summary'][result_type].append(test_name)
> +        if test_category not in json_results:
> +            json_results[test_category] = []
> +        json_result = {}
> +        # remove the file extension
> +        json_result["name"] = test_name.split('.')[0]
> +        json_result["result"] = result_type
> +        if result_type == "failed" or result_type == "timeout":
> +            json_result["output"] = reports.results[name]["output"]
> +        json_results[test_category].append(json_result)
> +    # convert results to a better format for report generation
> +    sorted_keys = sorted(json_results.keys())
> +    for i in range(len(sorted_keys)):
> +        results_log = {}
> +        results_log["index"] = i + 1
> +        results_log["name"] = sorted_keys[i]
> +        results_log["results"] = json_results[sorted_keys[i]]
> +        json_log["test_groups"].append(results_log)
> +    # write out JSON log
> +    with open(json_file, 'w') as outfile:
> +        json.dump(json_log, outfile, sort_keys=True, indent=4)
> +report_formatters = {
> +        'json': generate_json_report
>  def run(args, command_path = None):
>      import sys
>      tests = []
> @@ -227,6 +291,8 @@ def run(args, command_path = None):
>          optargs = { '--rtems-tools':    'The path to the RTEMS tools',
>                      '--rtems-bsp':      'The RTEMS BSP to run the test on',
>                      '--user-config':    'Path to your local user configuration INI file',
> +                    '--report-format':  'Formats in which to report test results in addition to txt: json',
> +                    '--log':            'Log output location',
Is this option already taken by the options.py module which imports the
rtemstoolkit's options? Would --report work?
>                      '--report-mode':    'Reporting modes, failures (default),all,none',
I wonder if this is now looking a bit confusing?
>                      '--list-bsps':      'List the supported BSPs',
>                      '--debug-trace':    'Debug trace based on specific flags (console,gdb,output,cov)',
> @@ -251,6 +317,20 @@ def run(args, command_path = None):
>              else:
>                  to_addr = 'build at rtems.org'
>              output = log_capture()
> +        log_location = opts.find_arg('--log')
> +        if log_location is not None:
> +            log_location = log_location[1]
> +        report_formats = opts.find_arg('--report-format')
> +        if report_formats is not None:
> +            if len(report_formats) != 2:
> +                raise error.general('invalid RTEMS report formats option')
> +            if log_location is None:
> +                raise error.general('log location not provided for alternate output format(s)')
> +            report_formats = report_formats[1].split(',')
> +            for report_format in report_formats:
> +                if report_format not in report_formatters:
> +                    raise error.general('invalid RTEMS report formatter specified "%s"' % report_format)
>          log.notice('RTEMS Testing - Tester, %s' % (version.string()))
>          if opts.find_arg('--list-bsps'):
>              bsps.list(opts)
> @@ -360,6 +440,10 @@ def run(args, command_path = None):
>          total_time = 'Testing time     : %s' % (str(end_time - start_time))
>          log.notice(average_time)
>          log.notice(total_time)
> +            report_formatters[report_format](args, reports, start_time,
> +                    end_time, total, '.'.join([log_location, report_format]))
>          if mail is not None and output is not None:
>              m_arch = opts.defaults.expand('%{arch}')
>              m_bsp = opts.defaults.expand('%{bsp}')
