[RSB PATCH] Added qemu 4.1.0 as bare target
Mon Aug 19 22:44:24 UTC 2019
On 20/8/19 6:53 am, Jiri Gaisler wrote:
> This patch will add QEMU-4.1.0 as RSB target devel/qemu4.
Looks good.
> The current devel/qemu target will be preserved.
Should devel/qemu just point to qemu4? I am OK with this happening.
> Builds and installs fine on ubuntu 18.04 x86_64. Build scripts might need tweaks for other platforms.
It can be a lot of work depending on how building the support libraries goes. I
think we have reached a point where a newer qemu on platforms that can build it
is more important and the problem hosts such as MinGW and MacOS can be cleaned
up after.
> A few patches are still pulled in, currently hosted on gaisler.org but could be moved to Trac ..? Tested with sparc/leon3 bsp, about 10 unexpected fails/timeouts out of 530 tests.
Does setting a longer timeout change this? I cannot find a suitable way to
adjust the timeout depending on the load.
> Passed:        409
> Failed:          2
> User Input:      6
> Expected Fail:   0
> Indeterminate:   0
> Benchmark:       3
> Timeout:         9
> Invalid:         2
> Wrong Version:  99
> Wrong Build:     0
> Wrong Tools:     0
> Total:         530
> Average test time: 0:00:00.539311
> Testing time     : 0:04:45.834903
> devel mailing list
> devel at rtems.org
