GSoC 2019 : POSIX Compliance - Final Report
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Tue Aug 20 18:45:44 UTC 2019
On Tue, Aug 20, 2019 at 9:31 PM Joel Sherrill <joel at rtems.org> wrote:
> I am late to the party.
The party is still on :D
> I made a couple of small changes directly to
> the document.
Thanks.
> I encourage you continue to pick at getting the other fenv ports into
> newlib.
This is on top of my priority list.
> As you
> hopefully saw from me adding the stubs for fenv methods and documentation,
> things moving slowly were not a reflection on you personally. I
> certainly went through
> a number of rounds. :)
Yes, I am on it. It would be more easy if RISCV fenv works well. I can get
a testsuite
which will be of lot help.
> Could you add a complete list of POSIX methods that you added? I need to
> update
> the spreadsheet and .csv file in the POSIX Compliance document.
Sure. I added two testsuites, ndbm and inttypes.
Only one header - "ndbm.h".
I will update this in my report.
--Vaibhav Gupta
> --joel
> On Fri, Aug 16, 2019 at 10:48 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Made the changes as suggested :)
> > Please have a look at this now. If every thing is fine.
> > I will publish it in my blog.
> > -Vaibhav Gupta
> > On Fri, Aug 16, 2019 at 7:57 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> Vaibhav,
> >> Please add a subsection near the top that consolidates links to all
> >> the code you wrote during the summer. It is great to have them in
> >> context, but it should also be easy (~10 seconds) to find what code
> >> you wrote.
> >> On Thu, Aug 15, 2019 at 1:27 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> > Hello,
> >> > I have made the draft of my project report on google docs.
> >> > I have mentioned about each and every task completed
> >> > and which are in progress.
> >> > It would be very helpful for me If I can get reviews on this,
> >> > will also make required changes.
> https://docs.google.com/document/d/1I3FsA0whd2AcLKdagUzins-JmWv1QTC6-0v0uvS1_7k/edit?usp=sharing
> >> > Thank You
> >> > Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190821/71da08b9/attachment.html>
