[PATCH v2] Add steps to test Newlib patch.
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Wed Aug 21 01:42:56 UTC 2019
Thanks for considering it!!
On Wed, Aug 21, 2019, 12:29 AM Joel Sherrill <joel.sherrill at gmail.com>
wrote:
> Finally pushed.
> Thanks
> On Tue, Aug 20, 2019 at 8:37 AM Joel Sherrill <joel.sherrill at gmail.com>
> wrote:
>> Can you compress it and send it to me privately as an attachment?
>> Something along the email chain is messing it up.
>> Thanks.
>> --joel
>> On Mon, Aug 19, 2019 at 8:57 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>>> Is it okay to push it??
>>> --Vaibhav Gupta
>>> On Fri, Aug 16, 2019 at 8:14 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>>> Update the checksum to be used for the Newlib patches.
>>>> Earlier it was msd5, but it is depreciated for security
>>>> reasons. Now RSB accepts sha512.
>>>> user/rsb/project-sets.rst | 41 +++++++++++++++++++++++++++++++++------
>>>> 1 file changed, 35 insertions(+), 6 deletions(-)
>>>> diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
>>>> index 5ffce26..b01857e 100644
>>>> --- a/user/rsb/project-sets.rst
>>>> +++ b/user/rsb/project-sets.rst
>>>> @@ -261,17 +261,46 @@ in the ``source-builder/config`` template
>>>> configuration files.
>>>> To test a patch simply copy it to your local ``patches`` directory.
>>>> The RSB
>>>> will see the patch is present and will not attempt to download it.
>>>> Once you are
>>>> happy with the patch submit it to the project and a core developer
>>>> will review
>>>> -it and add it to the RTEMS Tools git repository. For example, to test
>>>> a local
>>>> -patch for newlib, add the following two lines to the .cfg file in
>>>> -``rtems/config/tools/`` that is included by the bset you use:
>>>> +it and add it to the RTEMS Tools git repository.
>>>> +Testing a Newlib Patch
>>>> +To test a local patch for newlib, you need to add the following
>>>> +two lines to the ``.cfg`` file in ``rsb/rtems/config/tools/`` that is
>>>> included
>>>> +by the bset you use:
>>>> +.. topic:: Steps:
>>>> + 1. Create patches for the changes you want to test. (Note: For RSB,
>>>> before
>>>> + creating Newlib patch, you must run ``autoreconf -fvi`` in the
>>>> required
>>>> + directory after you make changes to the code. This is not
>>>> required when
>>>> + you create patch to send to ``newlib-devel``. But if you want RSB
>>>> to
>>>> + address your changes, your patch should also include regenerated
>>>> files.)
>>>> + 2. Calculate ``sha512`` of your patch.
>>>> + 3. Place the patches in ``rsb/rtems/patches`` directory.
>>>> + 4. Open the ``.bset`` file used by your BSP in ``rsb/rtems/config``.
>>>> + For example, for ``rtems5``, ``SPARC``, the file will be
>>>> + ``rsb/rtems/config/5/rtems-sparc.bset``.
>>>> + 5. Inside it you will find the name of ``.cfg`` file for Newlib,
>>>> used by
>>>> + your BSP.
>>>> + For example, I found ``tools/rtems-gcc-7.4.0-newlib-1d35a003f``.
>>>> + 6. Edit your ``.cfg`` file. In my case it will be,
>>>> + ``rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg``.
>>>> And
>>>> + add the information about your patch as mentioned below.
>>>> .. code-block:: spec
>>>> - %patch add newlib file://0001-this-is-a-newlib-patch.patch <1>
>>>> - %hash md5 0001-this-is-a-newlib-patch.diff
>>>> 77d070878112783292461bd6e7db17fb <2>
>>>> + %patch add newlib -p1 file://0001-Port-ndbm.patch <1>
>>>> + %hash sha512 0001-Port-ndbm.patch
>>>> 7d999ceeea4f3dc82e8e0aadc09d983a7a68b44470da8a3d61ab6fc558fdba6f2c2de3acc2f32c0b0b97fcc9ab799c27e87afe046544a69519881f947e7881d1
>>>> <2>
>>>> .. topic:: Items:
>>>> 1. The diff file prepended with ``file://`` to tell RSB this is a
>>>> local file.
>>>> - 2. The output from md5sum on the diff file.
>>>> + 2. The output from sha512sum on the patch file.
>>>> 2.21.0
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190821/c513169f/attachment.html>
