[PATCH v3] Add JSON log generation
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Aug 21 16:34:12 UTC 2019
Add log formatter hooks and JSON log formatter to the test infrastructure
for consumption by automated processes or report generators.
tester/rt/test.py | 124 ++++++++++++++++++++++++++++++++++++++++++++++++------
1 file changed, 111 insertions(+), 13 deletions(-)
diff --git a/tester/rt/test.py b/tester/rt/test.py
index da0a11e..d5c7c66 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -178,7 +178,7 @@ def find_executables(paths, glob):
executables = [e for e in executables if not norun.match(e)]
return sorted(executables)
-def report_finished(reports, report_mode, reporting, finished, job_trace):
+def report_finished(reports, log_mode, reporting, finished, job_trace):
processing = True
while processing:
processing = False
@@ -192,7 +192,7 @@ def report_finished(reports, report_mode, reporting, finished, job_trace):
'reporting',
reporting))
processing = True
- reports.log(tst.executable, report_mode)
+ reports.log(tst.executable, log_mode)
reported += [tst]
reporting += 1
finished[:] = [t for t in finished if t not in reported]
@@ -217,6 +217,88 @@ def killall(tests):
for test in tests:
test.kill()
+def generate_json_report(args, reports, start_time, end_time,
+ total, json_file):
+ import json
+ import sys
+ json_log = {}
+ json_log['Command Line'] = " ".join(args)
+ json_log['Python'] = sys.version.replace('\n', '')
+ json_log['test_groups'] = []
+ json_log['Host'] = host.label(mode='all')
+ json_log['summary'] = {}
+ json_log['summary']['passed_count'] = reports.passed
+ json_log['summary']['failed_count'] = reports.failed
+ json_log['summary']['user-input_count'] = reports.user_input
+ json_log['summary']['expected-fail_count'] = reports.expected_fail
+ json_log['summary']['indeterminate_count'] = reports.indeterminate
+ json_log['summary']['benchmark_count'] = reports.benchmark
+ json_log['summary']['timeout_count'] = reports.timeouts
+ json_log['summary']['invalid_count'] = reports.invalids
+ json_log['summary']['wrong-version_count'] = reports.wrong_version
+ json_log['summary']['wrong-build_count'] = reports.wrong_build
+ json_log['summary']['wrong-tools_count'] = reports.wrong_tools
+ json_log['summary']['total_count'] = reports.total
+ time_delta = end_time - start_time
+ json_log['summary']['average_test_time'] = str(time_delta / total)
+ json_log['summary']['testing_time'] = str(time_delta)
+ result_types = [
+ 'failed', 'user-input', 'expected-fail', 'indeterminate',
+ 'benchmark', 'timeout', 'invalid', 'wrong-version', 'wrong-build',
+ 'wrong-tools'
+ json_results = {}
+ for result_type in result_types:
+ json_log['summary'][result_type] = []
+ # collate results for JSON log
+ for name in reports.results:
+ result_type = reports.results[name]['result']
+ test_parts = name.split("/")
+ test_category = test_parts[-2]
+ test_name = test_parts[-1]
+ if result_type != 'passed':
+ json_log['summary'][result_type].append(test_name)
+ if test_category not in json_results:
+ json_results[test_category] = []
+ json_result = {}
+ # remove the file extension
+ json_result["name"] = test_name.split('.')[0]
+ json_result["result"] = result_type
+ if result_type == "failed" or result_type == "timeout":
+ json_result["output"] = reports.results[name]["output"]
+ json_results[test_category].append(json_result)
+ # convert results to a better format for report generation
+ sorted_keys = sorted(json_results.keys())
+ for i in range(len(sorted_keys)):
+ results_log = {}
+ results_log["index"] = i + 1
+ results_log["name"] = sorted_keys[i]
+ results_log["results"] = json_results[sorted_keys[i]]
+ json_log["test_groups"].append(results_log)
+ # write out JSON log
+ with open(json_file, 'w') as outfile:
+ json.dump(json_log, outfile, sort_keys=True, indent=4)
+report_formatters = {
+ 'json': generate_json_report
+def check_report_formats(report_formats, report_location):
+ if report_location is None:
+ raise error.general('report base path missing')
+ for report_format in report_formats:
+ if report_format not in report_formatters:
+ raise error.general('invalid RTEMS report formatter: %s'
+ % report_format)
def run(args, command_path = None):
import sys
tests = []
@@ -227,7 +309,9 @@ def run(args, command_path = None):
optargs = { '--rtems-tools': 'The path to the RTEMS tools',
'--rtems-bsp': 'The RTEMS BSP to run the test on',
'--user-config': 'Path to your local user configuration INI file',
- '--report-mode': 'Reporting modes, failures (default),all,none',
+ '--report-path': 'Report output base path (file extension will be added)',
+ '--report-format': 'Formats in which to report test results in addition to txt: json',
+ '--log-mode': 'Reporting modes, failures (default),all,none',
'--list-bsps': 'List the supported BSPs',
'--debug-trace': 'Debug trace based on specific flags (console,gdb,output,cov)',
'--filter': 'Glob that executables must match to run (default: ' +
@@ -251,6 +335,16 @@ def run(args, command_path = None):
else:
to_addr = 'build at rtems.org'
output = log_capture()
+ report_location = opts.find_arg('--report-path')
+ if report_location is not None:
+ report_location = report_location[1]
+ report_formats = opts.find_arg('--report-format')
+ if report_formats is not None:
+ if len(report_formats) != 2:
+ raise error.general('invalid RTEMS report formats option')
+ report_formats = report_formats[1].split(',')
+ check_report_formats(report_formats, report_location)
log.notice('RTEMS Testing - Tester, %s' % (version.string()))
if opts.find_arg('--list-bsps'):
bsps.list(opts)
@@ -298,15 +392,15 @@ def run(args, command_path = None):
executables,
rtems_tools,
trace = cov_trace)
- report_mode = opts.find_arg('--report-mode')
- if report_mode:
- if report_mode[1] != 'failures' and \
- report_mode[1] != 'all' and \
- report_mode[1] != 'none':
+ log_mode = opts.find_arg('--log-mode')
+ if log_mode:
+ if log_mode[1] != 'failures' and \
+ log_mode[1] != 'all' and \
+ log_mode[1] != 'none':
raise error.general('invalid report mode')
- report_mode = report_mode[1]
+ log_mode = log_mode[1]
else:
- report_mode = 'failures'
+ log_mode = 'failures'
if len(executables) == 0:
raise error.general('no executables supplied')
start_time = datetime.datetime.now()
@@ -344,22 +438,26 @@ def run(args, command_path = None):
time.sleep(0.250)
if len(finished):
reporting = report_finished(reports,
- report_mode,
+ log_mode,
reporting,
finished,
job_trace)
finished_time = datetime.datetime.now()
- reporting = report_finished(reports, report_mode,
+ reporting = report_finished(reports, log_mode,
if reporting < total:
log.warning('finished jobs does match: %d' % (reporting))
- report_finished(reports, report_mode, -1, finished, job_trace)
+ report_finished(reports, log_mode, -1, finished, job_trace)
reports.summary()
end_time = datetime.datetime.now()
average_time = 'Average test time: %s' % (str((end_time - start_time) / total))
total_time = 'Testing time : %s' % (str(end_time - start_time))
log.notice(average_time)
log.notice(total_time)
+ report_formatters[report_format](args, reports, start_time,
+ end_time, total, '.'.join([report_location, report_format]))
if mail is not None and output is not None:
m_arch = opts.defaults.expand('%{arch}')
m_bsp = opts.defaults.expand('%{bsp}')
2.11.0
