[PATCH v3] Basic Support for Trace Compass
Ravindra Meena rmeena840 at gmail.com
Wed Aug 21 17:46:33 UTC 2019
 user/tracing/eventrecording.rst | 86 ++++++++++++++++-----------------
 1 file changed, 43 insertions(+), 43 deletions(-)
diff --git a/user/tracing/eventrecording.rst b/user/tracing/eventrecording.rst
index d1e44df..39c0117 100644
--- a/user/tracing/eventrecording.rst
+++ b/user/tracing/eventrecording.rst
@@ -55,7 +55,7 @@ function.
 Recorded events can be sent to a host computer with a very simple record server
 started by :c:func:`rtems_record_start_server` via a TCP connection.
-On the host computer you may use the command line tool :file:`rtems-record` to
+On the host computer you may use the command line tool :file:`rtems-record-lttng` to
 get recorded events from the record server running on the target system.
 .. _tracecompass:
@@ -63,49 +63,49 @@ get recorded events from the record server running on the target system.
 Trace Compass
-`Trace Compass <https://www.eclipse.org/tracecompass/>`_ is a tool to analyse
-and display trace data graphically. Trace data can be gathered from  RTEMS
+`Trace Compass <https://www.eclipse.org/tracecompass/>`_ is a tool to analyse
+and display trace data graphically. Trace data can be gathered from  RTEMS
 applications via various means, for example:
 - :ref:`RTEMS Trace Linker <TraceLinker>`
 - :ref:`RTEMS Capture Engine <CaptureEngine>`
 - :ref:`RTEMS Event Recording <EventRecording>`
-Event Recording Infrastructure is used to analyse and display some basic
-information. The basic information is defined by the Linux kernel trace
+Event Recording Infrastructure is used to analyse and display some basic
+information. The basic information is defined by the Linux kernel trace
 support ( `LTTng <https://lttng.org/>`_ ) and includes CPU Usage, IRQ Analysis
-( IRQ Statistics, IRQ Table etc.), Linux Kernel( Control Flow, Resources etc.
+( IRQ Statistics, IRQ Table etc.), Linux Kernel ( Control Flow, Resources etc.
 Advanced support for `Trace Compass <https://www.eclipse.org/
 tracecompass/>`_ includes dynamic memory traces, stack usage,
 network packet flow, etc.
-Event Recording Infrastructure generates the trace stream and converted into
-`LTTng <https://lttng.org/>`_ format at host which is easily understood by
+Event Recording Infrastructure generates the trace stream and converted into
+`LTTng <https://lttng.org/>`_ format at host which is easily understood by
 `Trace Compass <https://www.eclipse.org/tracecompass/>`_.
 This scheme of tracing goes through the flow of events described in a subsequent
-flowchart. This requires the environment setup of
-`rtems-libbsd <https://github.com/RTEMS/rtems-libbsd>`_  and
+flowchart. This requires the environment setup of
+`rtems-libbsd <https://github.com/RTEMS/rtems-libbsd>`_  and
 `rtems-tools <https://github.com/RTEMS/rtems-tools>`_:
 Step 1: The QEMU simulator is used to run a LibBSD based application and connect
 it to a virtual network on host. This requires to create a TAP virtual Ethernet
 interface for this. The QEMU command line is used for board support package, e.g
-the arm/xilinx_zynq_a9_qemu BSP etc. The host can be connected to target via
+the arm/xilinx_zynq_a9_qemu BSP etc. The host can be connected to target via
 telnet.
 Step 2: On the host computer the command line tool rtems-record can be used to
-get recorded events from the record server running on the target system.
+get recorded events from the record server running on the target system.
-started by rtems_record_start_server() via a TCP connection.
+started by :c:func:`rtems_record_start_server` via a TCP connection.
-Step 3: The trace data received at host from QEMU target is converted into
-`LTTng <https://lttng.org/>`_ trace. The
-`Babeltrace <https://diamon.org/babeltrace/>`_ and
-`Trace Compass <https://www.eclipse.org/tracecompass/>`_ are two compatible
-software which can read `LTTng <https://lttng.org/>`_ trace. The converted
+Step 3: The trace data received at host from QEMU target is converted into
+`LTTng <https://lttng.org/>`_ trace. The
+`Babeltrace <https://diamon.org/babeltrace/>`_ and
+`Trace Compass <https://www.eclipse.org/tracecompass/>`_ are two compatible
+software which can read `LTTng <https://lttng.org/>`_ trace. The converted
 `LTTng <https://lttng.org/>`_ trace can be passed to any of these softwares.
 .. figure:: ../../images/user/event-recording-trace.png
@@ -116,7 +116,7 @@ RTEMS LTTng Trace Generation Example
 Step 1: Clone the repositories
-`rtems-libbsd <https://github.com/rmeena840/rtems-libbsd/tree/ravindra-rtems>`_
+`rtems-libbsd <https://github.com/rmeena840/rtems-libbsd/tree/ravindra-rtems>`_
 and
 `rtems-tools <https://github.com/rmeena840/rtems-tools/tree/ravindra-rtems>`_
 and set up the environment, if haven't done already.
@@ -145,23 +145,23 @@ Step 3: This requires to TAP virtual Ethernet interface for this:
 After some seconds it will acquire a IPv4 link-local address, e.g.
 .. code-block:: none
   info: cgem0: probing for an IPv4LL address
   debug: cgem0: checking for 169.254.XXX.XXX
 Use telnet command to connect host to target.
   telnet 169.254.XXX.XXX
-Step 4: After successfully connected to the target, the trace can be
+Step 4: After successfully connected to the target, the trace can be
 generated by target by using the following command:
   cd rtems-tools
-  ./build/misc/rtems-record -H 169.254.XXX.XXX -p 1234 | head
+  ./build/trace/rtems-record-lttng -H 169.254.XXX.XXX -p 1234 | head
 Alternatively, if user have the raw data then the trace can be generated
 from raw data without TCP connection by following command:
@@ -169,26 +169,26 @@ from raw data without TCP connection by following command:
   cd rtems-tools
-  ./build/misc/rtems-record --input=<raw-data-path>
+  ./build/trace/rtems-record-lttng --input=<raw-data-path>
 Here, <raw-data-path> is the path of raw data.
 Step 5: Set up the `Trace Compass <https://www.eclipse.org/
-tracecompass/>`_ and install the `Add-Ons
+tracecompass/>`_ and install the `Add-Ons
 <https://github.com/tuxology/tracevizlab/tree/master/labs/006-installing-tracecompass#task-3-install-the-required-add-ons-for-this-tutorial>`_
-Step 6: The `Babeltrace <https://diamon.org/babeltrace/>`_ and `Trace Compass
-<https://www.eclipse.org/tracecompass/>`_ are two compatible software which
-can read `LTTng <https://lttng.org/>`_ trace. This step demonstrates the
+Step 6: The `Babeltrace <https://diamon.org/babeltrace/>`_ and `Trace Compass
+<https://www.eclipse.org/tracecompass/>`_ are two compatible software which
+can read `LTTng <https://lttng.org/>`_ trace. This step demonstrates the
 trace visualization in `Trace Compass <https://www.eclipse.org/tracecompass/>`_:
-Move the trace from target/raw data and metadata generated in
-common folder, e.g CTF folder and follow the steps given `here
+Move the trace from target/raw data and metadata generated in
+common folder, e.g CTF folder and follow the steps given `here
 <https://github.com/tuxology/tracevizlab/tree/master/labs/006-installing-tracecompass#task-4-import-the-traces-for-the-tutorial>`_
 to import the `LTTng <https://lttng.org/>`_ trace.
-The `LTTng <https://lttng.org/>`_ trace Visualization in `Trace Compass
+The `LTTng <https://lttng.org/>`_ trace Visualization in `Trace Compass
 <https://www.eclipse.org/tracecompass/>`_ should look something like this:
 .. figure:: ../../images/user/Trace-Compass-Visualization.png
@@ -196,12 +196,12 @@ The `LTTng <https://lttng.org/>`_ trace Visualization in `Trace Compass
   :width: 100%
 Currently, `Trace Compass <https://www.eclipse.org/tracecompass/>`_ can only
-display a proper CPU Load, Resources view and thread
-state( IDLE/RUNNING ) with thread names in trace visualization.
+display a proper CPU Load, Resources view and thread
+state ( IDLE/RUNNING ) with thread names in trace visualization.
 Alternatively, `Babeltrace <https://diamon.org/babeltrace/>`_ can be used if
-user is only interested in reading the `LTTng <https://lttng.org/>`_ trace.
-Move the trace and metadata generated in common folder, e.g CTF folder and
+user is only interested in reading the `LTTng <https://lttng.org/>`_ trace.
+Move the trace and metadata generated in common folder, e.g CTF folder and
 run following command:
@@ -209,23 +209,23 @@ run following command:
   cd CTF
   babeltrace .
-The `Babeltrace <https://diamon.org/babeltrace/>`_ output should look
+The `Babeltrace <https://diamon.org/babeltrace/>`_ output should look
-  [19:22:08.679021917] (+0.000004377) Record_Item sched_switch: { cpu_id = 4 },
-  { prev_comm = "IRQS", prev_tid = 167837706, prev_prio = 0, prev_state = 0,
+  [19:22:08.679021917] (+0.000004377) Record_Item sched_switch: { cpu_id = 4 },
+  { prev_comm = "IRQS", prev_tid = 167837706, prev_prio = 0, prev_state = 0,
   next_comm = "IDLE", next_tid = 0, next_prio = 0 }
-  [19:22:08.679022700] (+0.000000783) Record_Item sched_switch: { cpu_id = 5 },
-  { prev_comm = "IRQS", prev_tid = 167837707, prev_prio = 0, prev_state = 0,
+  [19:22:08.679022700] (+0.000000783) Record_Item sched_switch: { cpu_id = 5 },
+  { prev_comm = "IRQS", prev_tid = 167837707, prev_prio = 0, prev_state = 0,
   [19:22:08.679030770] (+0.000008070) Record_Item sched_switch: { cpu_id = 4 },
-  { prev_comm = "IDLE", prev_tid = 0, prev_prio = 0, prev_state = 1026,
+  { prev_comm = "IDLE", prev_tid = 0, prev_prio = 0, prev_state = 1026,
   [19:22:08.679030912] (+0.000000142) Record_Item sched_switch: { cpu_id = 5 },
   next_comm = "IRQS", next_tid = 167837707, next_prio = 0 }
-The above output displays the timestamp, thread state( IDLE/RUNNING ), cpu_id
+The above output displays the timestamp, thread state ( IDLE/RUNNING ), cpu_id
 etc.
2.21.0
