Fwd: Build FreeBSD: FAILED 6/rtems-i386.bset on x86_64-freebsd12.0 (i386-rtems6-gcc-0f81292cb0a-newlib-d06517044-x86_64-freebsd12.0-1)
Sebastian Huber
Mon Aug 26 06:30:51 UTC 2019
Hello,
this error was caused by and looks like a break introduced by the fenv.h
changes:
libtool: compile:
/usr/home/user/rtems-source-builder/rtems/build/i386-rtems6-gcc-0f81292cb0a-newlib-d06517044-x86_64-freebsd12.0-1/build/./gcc/xgcc
B/usr/home/user/rtems-source-builder/rtems/build/i386-rtems6-gcc-0f81292cb0a-newlib-d06517044-x86_64-freebsd12.0-1/build/./gcc/
-nostdinc -B/usr/home/u
ser/rtems-source-builder/rtems/build/i386-rtems6-gcc-0f81292cb0a-newlib-d06517044-x86_64-freebsd12.0-1/build/i386-rtems6/newlib/
-isystem /usr/home/use
r/rtems-source-builder/rtems/build/i386-rtems6-gcc-0f81292cb0a-newlib-d06517044-x86_64-freebsd12.0-1/build/i386-rtems6/newlib/targ-include
-isystem /us
r/home/user/rtems-source-builder/rtems/build/i386-rtems6-gcc-0f81292cb0a-newlib-d06517044-x86_64-freebsd12.0-1/gnu-mirror-gcc-0f81292cb0a/newlib/libc/i
nclude -B/usr/local/rtems/5/i386-rtems6/bin/
-B/usr/local/rtems/5/i386-rtems6/lib/ -isystem
/usr/local/rtems/5/i386-rtems6/include -isystem /usr/local/
rtems/5/i386-rtems6/sys-include -DHAVE_CONFIG_H -I.
-I../../../../gnu-mirror-gcc-0f81292cb0a/libquadmath -I
uadmath/../include -g -O2 -mtune=i486 -MT math/acosq.lo -MD -MP -MF
math/.deps/acosq.Tpo -c
../../../../gnu-mirror-gcc-0f81292cb0a/libquadmath/math/aco
sq.c -o math/acosq.o
In file included from
../../../../gnu-mirror-gcc-0f81292cb0a/libquadmath/math/x2y2m1q.c:19:
../../../../gnu-mirror-gcc-0f81292cb0a/libquadmath/math/x2y2m1q.c: In
function '__quadmath_x2y2m1q':
../../../../gnu-mirror-gcc-0f81292cb0a/libquadmath/math/x2y2m1q.c:57:26:
error: 'FE_TONEAREST' undeclared (first use in this function)
57 | SET_RESTORE_ROUNDF128 (FE_TONEAREST);
../../../../gnu-mirror-gcc-0f81292cb0a/libquadmath/quadmath-imp.h:318:35:
note: in definition of macro 'SET_RESTORE_ROUNDF128'
318 | libc_feholdsetround_ctx (&ctx, (RM))
note: each undeclared identifier is reported only once for each function
it ap
pears in
