[PATCH 1/5] sb/download: Add support for a base64 hash string
chrisj at rtems.org
chrisj at rtems.org
Tue Aug 27 11:42:13 UTC 2019
source-builder/sb/download.py | 10 ++++++++--
1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/source-builder/sb/download.py b/source-builder/sb/download.py
index d8061e6..1fb0155 100644
--- a/source-builder/sb/download.py
+++ b/source-builder/sb/download.py
@@ -24,6 +24,7 @@
from __future__ import print_function
+import base64
import hashlib
import os
import re
@@ -110,8 +111,13 @@ def _hash_check(file_, absfile, macros, remove = True):
raise
if _in is not None:
_in.close()
- log.output('checksums: %s: %s => %s' % (file_, hasher.hexdigest(), hash[1]))
- if hasher.hexdigest() != hash[1]:
+ hash_hex = hasher.hexdigest()
+ hash_base64 = base64.b64encode(hasher.digest()).decode('utf-8')
+ log.output('checksums: %s: (hex: %s) (b64: %s) => %s' % (file_,
+ hash_hex,
+ hash_base64,
+ hash[1]))
+ if hash_hex != hash[1] and hash_base64 != hash[1]:
log.warning('checksum error: %s' % (file_))
failed = True
if failed and remove:
2.20.1
