[PATCH] rtemsbsd: remove dead code fb.c
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Aug 28 12:43:37 UTC 2019
freebsd/sys/dev/fb/fb.c | 762 ---------------------------
libbsd.py | 1 -
rtemsbsd/include/bsp/nexus-devices.h | 2 -
3 files changed, 765 deletions(-)
delete mode 100644 freebsd/sys/dev/fb/fb.c
diff --git a/freebsd/sys/dev/fb/fb.c b/freebsd/sys/dev/fb/fb.c
deleted file mode 100644
index a3263c91..00000000
--- a/freebsd/sys/dev/fb/fb.c
+++ /dev/null
@@ -1,762 +0,0 @@
-#include <machine/rtems-bsd-kernel-space.h>
- * SPDX-License-Identifier: BSD-3-Clause
- * Copyright (c) 1999 Kazutaka YOKOTA <yokota at zodiac.mech.utsunomiya-u.ac.jp>
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer as
- * the first lines of this file unmodified.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * 3. The name of the author may not be used to endorse or promote products
- * derived from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
- * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
- * IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
- * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
- * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
- * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
- * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-#include <sys/cdefs.h>
-__FBSDID("$FreeBSD$");
-#include <rtems/bsd/local/opt_fb.h>
-#include <sys/param.h>
-#include <sys/systm.h>
-#include <sys/conf.h>
-#include <sys/bus.h>
-#include <sys/kernel.h>
-#include <sys/malloc.h>
-#include <sys/module.h>
-#include <sys/uio.h>
-#include <sys/fbio.h>
-#include <sys/linker_set.h>
-#include <vm/vm.h>
-#include <vm/pmap.h>
-#include <dev/fb/fbreg.h>
-SET_DECLARE(videodriver_set, const video_driver_t);
-/* local arrays */
- * We need at least one entry each in order to initialize a video card
- * for the kernel console. The arrays will be increased dynamically
- * when necessary.
-static int vid_malloc;
-static int adapters = 1;
-static video_adapter_t *adp_ini;
-static video_adapter_t **adapter = &adp_ini;
-static video_switch_t *vidsw_ini;
- video_switch_t **vidsw = &vidsw_ini;
-#ifdef FB_INSTALL_CDEV
-static struct cdevsw *vidcdevsw_ini;
-static struct cdevsw **vidcdevsw = &vidcdevsw_ini;
-#endif
-#define ARRAY_DELTA 4
-static int
-vid_realloc_array(void)
- video_adapter_t **new_adp;
- video_switch_t **new_vidsw;
- struct cdevsw **new_cdevsw;
-#endif
- int newsize;
- int s;
- if (!vid_malloc)
- return ENOMEM;
- s = spltty();
- newsize = rounddown(adapters + ARRAY_DELTA, ARRAY_DELTA);
- new_adp = malloc(sizeof(*new_adp)*newsize, M_DEVBUF, M_WAITOK | M_ZERO);
- new_vidsw = malloc(sizeof(*new_vidsw)*newsize, M_DEVBUF,
- M_WAITOK | M_ZERO);
- new_cdevsw = malloc(sizeof(*new_cdevsw)*newsize, M_DEVBUF,
-#endif
- bcopy(adapter, new_adp, sizeof(*adapter)*adapters);
- bcopy(vidsw, new_vidsw, sizeof(*vidsw)*adapters);
- bcopy(vidcdevsw, new_cdevsw, sizeof(*vidcdevsw)*adapters);
-#endif
- if (adapters > 1) {
- free(adapter, M_DEVBUF);
- free(vidsw, M_DEVBUF);
- free(vidcdevsw, M_DEVBUF);
-#endif
- adapter = new_adp;
- vidsw = new_vidsw;
- vidcdevsw = new_cdevsw;
-#endif
- adapters = newsize;
- splx(s);
- if (bootverbose)
- printf("fb: new array size %d\n", adapters);
- return 0;
-static void
-vid_malloc_init(void *arg)
- vid_malloc = TRUE;
-SYSINIT(vid_mem, SI_SUB_KMEM, SI_ORDER_ANY, vid_malloc_init, NULL);
- * Low-level frame buffer driver functions
- * frame buffer subdrivers, such as the VGA driver, call these functions
- * to initialize the video_adapter structure and register it to the virtual
- * frame buffer driver `fb'.
-/* initialize the video_adapter_t structure */
-void
-vid_init_struct(video_adapter_t *adp, char *name, int type, int unit)
- adp->va_flags = 0;
- adp->va_name = name;
- adp->va_type = type;
- adp->va_unit = unit;
-/* Register a video adapter */
-int
-vid_register(video_adapter_t *adp)
- const video_driver_t **list;
- const video_driver_t *p;
- int index;
- for (index = 0; index < adapters; ++index) {
- if (adapter[index] == NULL)
- break;
- if (index >= adapters) {
- if (vid_realloc_array())
- return -1;
- adp->va_index = index;
- adp->va_token = NULL;
- SET_FOREACH(list, videodriver_set) {
- p = *list;
- if (strcmp(p->name, adp->va_name) == 0) {
- adapter[index] = adp;
- vidsw[index] = p->vidsw;
- return index;
- return -1;
-int
-vid_unregister(video_adapter_t *adp)
- if ((adp->va_index < 0) || (adp->va_index >= adapters))
- return ENOENT;
- if (adapter[adp->va_index] != adp)
- return ENOENT;
- adapter[adp->va_index] = NULL;
- vidsw[adp->va_index] = NULL;
- return 0;
-/* Get video I/O function table */
-video_switch_t
-*vid_get_switch(char *name)
- p = *list;
- if (strcmp(p->name, name) == 0)
- return p->vidsw;
- return NULL;
- * Video card client functions
- * Video card clients, such as the console driver `syscons' and the frame
- * buffer cdev driver, use these functions to claim and release a card for
- * exclusive use.
-/* find the video card specified by a driver name and a unit number */
-int
-vid_find_adapter(char *driver, int unit)
- int i;
- for (i = 0; i < adapters; ++i) {
- if (adapter[i] == NULL)
- continue;
- if (strcmp("*", driver) && strcmp(adapter[i]->va_name, driver))
- continue;
- if ((unit != -1) && (adapter[i]->va_unit != unit))
- continue;
- return i;
- return -1;
-/* allocate a video card */
-int
-vid_allocate(char *driver, int unit, void *id)
- int index;
- int s;
- s = spltty();
- index = vid_find_adapter(driver, unit);
- if (index >= 0) {
- if (adapter[index]->va_token) {
- splx(s);
- return -1;
- adapter[index]->va_token = id;
- splx(s);
- return index;
-int
-vid_release(video_adapter_t *adp, void *id)
- int error;
- int s;
- s = spltty();
- if (adp->va_token == NULL) {
- error = EINVAL;
- } else if (adp->va_token != id) {
- error = EPERM;
- } else {
- error = 0;
- splx(s);
- return error;
-/* Get a video adapter structure */
-video_adapter_t
-*vid_get_adapter(int index)
- if ((index < 0) || (index >= adapters))
- return NULL;
- return adapter[index];
-/* Configure drivers: this is a backdoor for the console driver XXX */
-int
-vid_configure(int flags)
- p = *list;
- if (p->configure != NULL)
- (*p->configure)(flags);
- return 0;
- * Virtual frame buffer cdev driver functions
- * The virtual frame buffer driver dispatches driver functions to
- * appropriate subdrivers.
-#define FB_DRIVER_NAME "fb"
-#if 0 /* experimental */
-static devclass_t fb_devclass;
-static int fbprobe(device_t dev);
-static int fbattach(device_t dev);
-static device_method_t fb_methods[] = {
- DEVMETHOD(device_probe, fbprobe),
- DEVMETHOD(device_attach, fbattach),
- DEVMETHOD_END
-static driver_t fb_driver = {
- FB_DRIVER_NAME,
- fb_methods,
- 0,
-static int
-fbprobe(device_t dev)
- int unit;
- unit = device_get_unit(dev);
- if (unit >= adapters)
- return ENXIO;
- if (adapter[unit] == NULL)
- return ENXIO;
- device_set_desc(dev, "generic frame buffer");
- return 0;
-static int
-fbattach(device_t dev)
- printf("fbattach: about to attach children\n");
- bus_generic_attach(dev);
- return 0;
-#endif
-#define FB_UNIT(dev) dev2unit(dev)
-#define FB_MKMINOR(unit) (u)
-static d_open_t fbopen;
-static d_close_t fbclose;
-static d_read_t fbread;
-static d_write_t fbwrite;
-static d_ioctl_t fbioctl;
-static d_mmap_t fbmmap;
-static struct cdevsw fb_cdevsw = {
- .d_version = D_VERSION,
- .d_flags = D_NEEDGIANT,
- .d_open = fbopen,
- .d_close = fbclose,
- .d_read = fbread,
- .d_write = fbwrite,
- .d_ioctl = fbioctl,
- .d_mmap = fbmmap,
- .d_name = FB_DRIVER_NAME,
-#endif
-static int
-fb_modevent(module_t mod, int type, void *data)
- switch (type) {
- case MOD_LOAD:
- break;
- case MOD_UNLOAD:
- printf("fb module unload - not possible for this module type\n");
- return EINVAL;
- default:
- return EOPNOTSUPP;
- return 0;
-static moduledata_t fb_mod = {
- "fb",
- fb_modevent,
- NULL
-DECLARE_MODULE(fb, fb_mod, SI_SUB_PSEUDO, SI_ORDER_ANY);
-int
-fb_attach(int unit, video_adapter_t *adp, struct cdevsw *cdevsw)
- int s;
- if (adp->va_index >= adapters)
- return EINVAL;
- return EINVAL;
- s = spltty();
- adp->va_minor = unit;
- vidcdevsw[adp->va_index] = cdevsw;
- splx(s);
- printf("fb%d at %s%d\n", adp->va_index, adp->va_name, adp->va_unit);
- return 0;
-int
-fb_detach(int unit, video_adapter_t *adp, struct cdevsw *cdevsw)
- int s;
- return EINVAL;
- return EINVAL;
- if (vidcdevsw[adp->va_index] != cdevsw)
- return EINVAL;
- s = spltty();
- vidcdevsw[adp->va_index] = NULL;
- splx(s);
- return 0;
- * Generic frame buffer cdev driver functions
- * Frame buffer subdrivers may call these functions to implement common
- * driver functions.
-int genfbopen(genfb_softc_t *sc, video_adapter_t *adp, int flag, int mode,
- struct thread *td)
- int s;
- s = spltty();
- if (!(sc->gfb_flags & FB_OPEN))
- sc->gfb_flags |= FB_OPEN;
- splx(s);
- return 0;
-int genfbclose(genfb_softc_t *sc, video_adapter_t *adp, int flag, int mode,
- int s;
- s = spltty();
- sc->gfb_flags &= ~FB_OPEN;
- splx(s);
- return 0;
-int genfbread(genfb_softc_t *sc, video_adapter_t *adp, struct uio *uio,
- int flag)
- int size;
- int offset;
- int error;
- int len;
- error = 0;
- size = adp->va_buffer_size/adp->va_info.vi_planes;
- while (uio->uio_resid > 0) {
- if (uio->uio_offset >= size)
- break;
- offset = uio->uio_offset%adp->va_window_size;
- len = imin(uio->uio_resid, size - uio->uio_offset);
- len = imin(len, adp->va_window_size - offset);
- if (len <= 0)
- break;
- vidd_set_win_org(adp, uio->uio_offset);
- error = uiomove((caddr_t)(adp->va_window + offset), len, uio);
- if (error)
- break;
- return error;
-int genfbwrite(genfb_softc_t *sc, video_adapter_t *adp, struct uio *uio,
- int flag)
- return ENODEV;
-int genfbioctl(genfb_softc_t *sc, video_adapter_t *adp, u_long cmd,
- caddr_t arg, int flag, struct thread *td)
- int error;
- if (adp == NULL) /* XXX */
- return ENXIO;
- error = vidd_ioctl(adp, cmd, arg);
- if (error == ENOIOCTL)
- error = ENODEV;
- return error;
-int genfbmmap(genfb_softc_t *sc, video_adapter_t *adp, vm_ooffset_t offset,
- vm_offset_t *paddr, int prot, vm_memattr_t *memattr)
- return vidd_mmap(adp, offset, paddr, prot, memattr);
-#endif /* FB_INSTALL_CDEV */
-static char
-*adapter_name(int type)
- static struct {
- int type;
- char *name;
- } names[] = {
- { KD_MONO, "MDA" },
- { KD_HERCULES, "Hercules" },
- { KD_CGA, "CGA" },
- { KD_EGA, "EGA" },
- { KD_VGA, "VGA" },
- { KD_TGA, "TGA" },
- { -1, "Unknown" },
- int i;
- for (i = 0; names[i].type != -1; ++i)
- if (names[i].type == type)
- break;
- return names[i].name;
- * Generic low-level frame buffer functions
- * The low-level functions in the frame buffer subdriver may use these
- * functions.
-void
-fb_dump_adp_info(char *driver, video_adapter_t *adp, int level)
- if (level <= 0)
- return;
- printf("%s%d: %s%d, %s, type:%s (%d), flags:0x%x\n",
- FB_DRIVER_NAME, adp->va_index, driver, adp->va_unit, adp->va_name,
- adapter_name(adp->va_type), adp->va_type, adp->va_flags);
- printf("%s%d: port:0x%lx-0x%lx, crtc:0x%lx, mem:0x%lx 0x%x\n",
- FB_DRIVER_NAME, adp->va_index, (u_long)adp->va_io_base,
- (u_long)adp->va_io_base + adp->va_io_size - 1,
- (u_long)adp->va_crtc_addr, (u_long)adp->va_mem_base,
- adp->va_mem_size);
- printf("%s%d: init mode:%d, bios mode:%d, current mode:%d\n",
- adp->va_initial_mode, adp->va_initial_bios_mode, adp->va_mode);
- printf("%s%d: window:%p size:%dk gran:%dk, buf:%p size:%dk\n",
- (void *)adp->va_window, (int)adp->va_window_size/1024,
- (int)adp->va_window_gran/1024, (void *)adp->va_buffer,
- (int)adp->va_buffer_size/1024);
-void
-fb_dump_mode_info(char *driver, video_adapter_t *adp, video_info_t *info,
- int level)
- if (level <= 0)
- return;
- printf("%s%d: %s, mode:%d, flags:0x%x ",
- driver, adp->va_unit, adp->va_name, info->vi_mode, info->vi_flags);
- if (info->vi_flags & V_INFO_GRAPHICS)
- printf("G %dx%dx%d, %d plane(s), font:%dx%d, ",
- info->vi_width, info->vi_height,
- info->vi_depth, info->vi_planes,
- info->vi_cwidth, info->vi_cheight);
- else
- printf("T %dx%d, font:%dx%d, ",
- printf("win:0x%lx\n", (u_long)info->vi_window);
-int
-fb_type(int adp_type)
- static struct {
- int fb_type;
- int va_type;
- } types[] = {
- { FBTYPE_MDA, KD_MONO },
- { FBTYPE_HERCULES, KD_HERCULES },
- { FBTYPE_CGA, KD_CGA },
- { FBTYPE_EGA, KD_EGA },
- { FBTYPE_VGA, KD_VGA },
- { FBTYPE_TGA, KD_TGA },
- int i;
- for (i = 0; i < nitems(types); ++i) {
- if (types[i].va_type == adp_type)
- return types[i].fb_type;
- return -1;
-int
-fb_commonioctl(video_adapter_t *adp, u_long cmd, caddr_t arg)
- int error;
- int s;
- /* assert(adp != NULL) */
- error = 0;
- s = spltty();
- switch (cmd) {
- case FBIO_ADAPTER: /* get video adapter index */
- *(int *)arg = adp->va_index;
- break;
- case FBIO_ADPTYPE: /* get video adapter type */
- *(int *)arg = adp->va_type;
- break;
- case FBIO_ADPINFO: /* get video adapter info */
- ((video_adapter_info_t *)arg)->va_index = adp->va_index;
- ((video_adapter_info_t *)arg)->va_type = adp->va_type;
- bcopy(adp->va_name, ((video_adapter_info_t *)arg)->va_name,
- imin(strlen(adp->va_name) + 1,
- sizeof(((video_adapter_info_t *)arg)->va_name)));
- ((video_adapter_info_t *)arg)->va_unit = adp->va_unit;
- ((video_adapter_info_t *)arg)->va_flags = adp->va_flags;
- ((video_adapter_info_t *)arg)->va_io_base = adp->va_io_base;
- ((video_adapter_info_t *)arg)->va_io_size = adp->va_io_size;
- ((video_adapter_info_t *)arg)->va_crtc_addr = adp->va_crtc_addr;
- ((video_adapter_info_t *)arg)->va_mem_base = adp->va_mem_base;
- ((video_adapter_info_t *)arg)->va_mem_size = adp->va_mem_size;
- ((video_adapter_info_t *)arg)->va_window
-#if defined(__amd64__) || defined(__i386__)
- = vtophys(adp->va_window);
-#else
- = adp->va_window;
-#endif
- ((video_adapter_info_t *)arg)->va_window_size
- = adp->va_window_size;
- ((video_adapter_info_t *)arg)->va_window_gran
- = adp->va_window_gran;
- ((video_adapter_info_t *)arg)->va_window_orig
- = adp->va_window_orig;
- ((video_adapter_info_t *)arg)->va_unused0
- = adp->va_buffer != 0 ? vtophys(adp->va_buffer) : 0;
-#else
- = adp->va_buffer;
-#endif
- ((video_adapter_info_t *)arg)->va_buffer_size
- = adp->va_buffer_size;
- ((video_adapter_info_t *)arg)->va_mode = adp->va_mode;
- ((video_adapter_info_t *)arg)->va_initial_mode
- = adp->va_initial_mode;
- ((video_adapter_info_t *)arg)->va_initial_bios_mode
- = adp->va_initial_bios_mode;
- ((video_adapter_info_t *)arg)->va_line_width
- = adp->va_line_width;
- ((video_adapter_info_t *)arg)->va_disp_start.x
- = adp->va_disp_start.x;
- ((video_adapter_info_t *)arg)->va_disp_start.y
- = adp->va_disp_start.y;
- break;
- case FBIO_MODEINFO: /* get mode information */
- error = vidd_get_info(adp,
- ((video_info_t *)arg)->vi_mode,
- (video_info_t *)arg);
- if (error)
- error = ENODEV;
- break;
- case FBIO_FINDMODE: /* find a matching video mode */
- error = vidd_query_mode(adp, (video_info_t *)arg);
- break;
- case FBIO_GETMODE: /* get video mode */
- *(int *)arg = adp->va_mode;
- break;
- case FBIO_SETMODE: /* set video mode */
- error = vidd_set_mode(adp, *(int *)arg);
- if (error)
- error = ENODEV; /* EINVAL? */
- break;
- case FBIO_GETWINORG: /* get frame buffer window origin */
- *(u_int *)arg = adp->va_window_orig;
- break;
- case FBIO_GETDISPSTART: /* get display start address */
- ((video_display_start_t *)arg)->x = adp->va_disp_start.x;
- ((video_display_start_t *)arg)->y = adp->va_disp_start.y;
- break;
- case FBIO_GETLINEWIDTH: /* get scan line width in bytes */
- *(u_int *)arg = adp->va_line_width;
- break;
- case FBIO_BLANK: /* blank display */
- error = vidd_blank_display(adp, *(int *)arg);
- break;
- case FBIO_GETPALETTE: /* get color palette */
- case FBIO_SETPALETTE: /* set color palette */
- /* XXX */
- case FBIOPUTCMAP:
- case FBIOGETCMAP:
- case FBIOPUTCMAPI:
- case FBIOGETCMAPI:
- /* XXX */
- case FBIO_SETWINORG: /* set frame buffer window origin */
- case FBIO_SETDISPSTART: /* set display start address */
- case FBIO_SETLINEWIDTH: /* set scan line width in pixel */
- case FBIOGTYPE:
- case FBIOGATTR:
- case FBIOSVIDEO:
- case FBIOGVIDEO:
- case FBIOVERTICAL:
- case FBIOSCURSOR:
- case FBIOGCURSOR:
- case FBIOSCURPOS:
- case FBIOGCURPOS:
- case FBIOGCURMAX:
- case FBIOMONINFO:
- case FBIOGXINFO:
- default:
- error = ENODEV;
- break;
- splx(s);
- return error;
diff --git a/libbsd.py b/libbsd.py
index f128961b..bd8963ef 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -815,7 +815,6 @@ class display(builder.Module):
'sys/dev/videomode/edid.c',
'sys/dev/videomode/vesagtf.c',
'sys/dev/videomode/videomode.c',
- 'sys/dev/fb/fb.c',
'sys/dev/fb/fbd.c',
'sys/arm/ti/am335x/am335x_lcd.c',
'sys/arm/ti/am335x/am335x_pwmss.c',
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index e9da3be1..ac9afbce 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -70,8 +70,6 @@ SYSINIT_DRIVER_REFERENCE(iic, iicbus);
SYSINIT_DRIVER_REFERENCE(tda, iicbus);
SYSINIT_DRIVER_REFERENCE(iicbus, rtems_i2c);
SYSINIT_DRIVER_REFERENCE(fbd, fb);
-SYSINIT_DRIVER_REFERENCE(fb, fb_mod);
-SYSINIT_MODULE_REFERENCE(fb_mod);
#ifdef RTEMS_BSD_MODULE_NET80211
SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
2.20.1
