[PATCH 1/2] score: Add RTEMS_RETURN_ADDRESS()
Wed Aug 28 14:05:22 UTC 2019
 cpukit/include/rtems/score/basedefs.h | 13 ++++++++++++-
 testsuites/sptests/spmisc01/init.c    |  7 ++++++-
 2 files changed, 18 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index 7a36c74e65..782958920c 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -10,7 +10,7 @@
  *  COPYRIGHT (c) 1989-2007.
  *  On-Line Applications Research Corporation (OAR).
- *  Copyright (c) 2010, 2018 embedded brains GmbH.
+ *  Copyright (C) 2010, 2019 embedded brains GmbH
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -371,6 +371,17 @@
   #define RTEMS_PREDICT_FALSE( _exp ) ( _exp )
 #endif
+ * @brief Returns the return address of the current function.
+ * @return The return address.
+#if defined(__GNUC__)
+  #define RTEMS_RETURN_ADDRESS() __builtin_return_address( 0 )
+#else
+  #define RTEMS_RETURN_ADDRESS() NULL
+#endif
 #if __cplusplus >= 201103L
   #define RTEMS_STATIC_ASSERT(cond, msg) \
     static_assert(cond, # msg)
diff --git a/testsuites/sptests/spmisc01/init.c b/testsuites/sptests/spmisc01/init.c
index d179e1239c..9090069973 100644
--- a/testsuites/sptests/spmisc01/init.c
+++ b/testsuites/sptests/spmisc01/init.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+ * Copyright (C) 2018, 2019 embedded brains GmbH
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -192,6 +192,8 @@ static int concat(void)
 static void Init(rtems_task_argument arg)
+  void *p;
   TEST_BEGIN();
   rtems_test_assert(inline_func() == 7);
   RTEMS_COMPILER_MEMORY_BARRIER();
@@ -260,6 +262,9 @@ static void Init(rtems_task_argument arg)
     rtems_test_assert(true);
+  p = RTEMS_RETURN_ADDRESS();
+  (void) p;
   TEST_END();
   rtems_test_exit(0);
2.16.4
