[PATCH] riscv: add freedom E310 Arty A7 bsp
Hesham Almatary heshamelmatary at gmail.com
Thu Aug 29 08:48:30 UTC 2019
I have a pending partial review which seconds Sebastian's opinion.
Most notably, the clock, btimer drivers code duplicate most of the
existing riscv drivers. It might be easier to just use the existing
generic riscv BSP ones, and if they lack any features, you can fix
that. Also, all of the csr_*() functions are already defined in the
riscv-utility.h header.
On Thu, 29 Aug 2019 at 07:19, Sebastian Huber
> Hello Pragnesh Patel,
> thanks for your patch. This patch contains a bit of copy and paste which
> may make the maintenance of the port harder. In general, why can't you
> add the support to the generic riscv BSP?
> devel mailing list
> devel at rtems.org
Hesham
