littleVGL now supports FreeBSD framebuffer
Fri Aug 30 00:42:48 UTC 2019
On 30/8/19 5:56 am, Vijay Kumar Banerjee wrote:
> On Thu, Aug 29, 2019 at 8:49 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
> <mailto:vijaykumar9597 at gmail.com>> wrote:
>     Hello Chris,
>     I have written the scripts to build littlevgl using rtems_waf. The build
>     works fine
>     and installs the required header and the static library in the prefix
>     library path.
>     The repository is pushed here, please have a look:
>     https://github.com/thelunatic/littlevgl-rsb
> I wrote a sample app[1] that uses the library built by this repo and prints
> hello world on the screen[2].
> [1]: https://github.com/thelunatic/rtems-bbb/tree/master/apps/lvgl-waf-sample
> [2]: https://drive.google.com/file/d/1Lyp8464s44a4yIWB_lp_7H2GnhK8GTQ5/view?usp=sharing
Nice. Would it be possible to add the example to rtems-exapmles? A test for
liblvgl.a could be used to enable building the example.
Thanks
