littleVGL now supports FreeBSD framebuffer
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Aug 30 06:38:08 UTC 2019
On 30/08/2019 02:39, Chris Johns wrote:
> On 30/8/19 1:19 am, Vijay Kumar Banerjee wrote:
>> I have written the scripts to build littlevgl using rtems_waf. The build works fine
>> and installs the required header and the static library in the prefix library path.
> This is great work. Well done.
+1
>> The repository is pushed here, please have a look:
>> https://github.com/thelunatic/littlevgl-rsb
> First a simple question ... why is there an import of runpy in wscript?
> Second, I have moved the repo to the git.rtems.org. :)
> Could you please check if it is OK?
> I have sorted out how to manage the repos in cgit so from the previous
> discussions I have taken the path of separate repos.
Hello Chris,
that looks great. Very clear structure.
Best regards
Christian
> Please have a look at
> https://git.rtems.org/ and the LittleVGL repo I have added under Packages.
> Again, thank you for this and your work in creating the package.
> Chris
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
