[PATCH 1/2] psxmsgq05: Added priority unblocking mq tests
Peter Dufault dufault at hda.com
Fri Aug 30 10:29:40 UTC 2019
> On Aug 30, 2019, at 03:08 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> +/* forward declarations to avoid warnings */
> Static functions don't need forward declarations to avoid warnings.
... because you should order the definitions properly.  Only if two static functions need to reference each other do you need to forward declare one.  That’s a rare situation.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
