[PATCH] rtemsbsd: remove dead code fb.c
Christian Mauderer list at c-mauderer.de
Sat Aug 31 18:34:35 UTC 2019
Sorry. I've been lazy and hadn't tested it yet. After a short test I
just pushed it. Thanks for the patch.
Best regards
Christian
On 31/08/2019 20:20, Vijay Kumar Banerjee wrote:
> ping :-)
> On Wed, Aug 28, 2019 at 6:13 PM Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>      freebsd/sys/dev/fb/fb.c              | 762 ---------------------------
>      libbsd.py                            |   1 -
>      rtemsbsd/include/bsp/nexus-devices.h |   2 -
>      3 files changed, 765 deletions(-)
>      delete mode 100644 freebsd/sys/dev/fb/fb.c
>     diff --git a/freebsd/sys/dev/fb/fb.c b/freebsd/sys/dev/fb/fb.c
>     deleted file mode 100644
>     index a3263c91..00000000
>     --- a/freebsd/sys/dev/fb/fb.c
>     +++ /dev/null
>     @@ -1,762 +0,0 @@
>     -#include <machine/rtems-bsd-kernel-space.h>
>     - * SPDX-License-Identifier: BSD-3-Clause
>     - * Copyright (c) 1999 Kazutaka YOKOTA
>     <yokota at zodiac.mech.utsunomiya-u.ac.jp
>     <mailto:yokota at zodiac.mech.utsunomiya-u.ac.jp>>
>     - * All rights reserved.
>     - * Redistribution and use in source and binary forms, with or without
>     - * modification, are permitted provided that the following conditions
>     - * are met:
>     - * 1. Redistributions of source code must retain the above copyright
>     - *    notice, this list of conditions and the following disclaimer as
>     - *    the first lines of this file unmodified.
>     - * 2. Redistributions in binary form must reproduce the above copyright
>     in the
>     - *    documentation and/or other materials provided with the
>     distribution.
>     - * 3. The name of the author may not be used to endorse or promote
>     products
>     - *    derived from this software without specific prior written
>     permission.
>     - * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY
>     EXPRESS OR
>     - * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
>     WARRANTIES
>     - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
>     DISCLAIMED.
>     - * IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT,
>     - * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
>     (INCLUDING, BUT
>     - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
>     LOSS OF USE,
>     - * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
>     ON ANY
>     - * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>     - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF
>     THE USE OF
>     - * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>     -#include <sys/cdefs.h>
>     -__FBSDID("$FreeBSD$");
>     -#include <rtems/bsd/local/opt_fb.h>
>     -#include <sys/param.h>
>     -#include <sys/systm.h>
>     -#include <sys/conf.h>
>     -#include <sys/bus.h>
>     -#include <sys/kernel.h>
>     -#include <sys/malloc.h>
>     -#include <sys/module.h>
>     -#include <sys/uio.h>
>     -#include <sys/fbio.h>
>     -#include <sys/linker_set.h>
>     -#include <vm/vm.h>
>     -#include <vm/pmap.h>
>     -#include <dev/fb/fbreg.h>
>     -SET_DECLARE(videodriver_set, const video_driver_t);
>     -/* local arrays */
>     - * We need at least one entry each in order to initialize a video card
>     - * for the kernel console.  The arrays will be increased dynamically
>     - * when necessary.
>     -static int             vid_malloc;
>     -static int             adapters = 1;
>     -static video_adapter_t *adp_ini;
>     -static video_adapter_t **adapter = &adp_ini;
>     -static video_switch_t  *vidsw_ini;
>     -       video_switch_t  **vidsw = &vidsw_ini;
>     -#ifdef FB_INSTALL_CDEV
>     -static struct cdevsw   *vidcdevsw_ini;
>     -static struct cdevsw   **vidcdevsw = &vidcdevsw_ini;
>     -#endif
>     -#define ARRAY_DELTA    4
>     -static int
>     -vid_realloc_array(void)
>     -       video_adapter_t **new_adp;
>     -       video_switch_t **new_vidsw;
>     -       struct cdevsw **new_cdevsw;
>     -#endif
>     -       int newsize;
>     -       int s;
>     -       if (!vid_malloc)
>     -               return ENOMEM;
>     -       s = spltty();
>     -       newsize = rounddown(adapters + ARRAY_DELTA, ARRAY_DELTA);
>     -       new_adp = malloc(sizeof(*new_adp)*newsize, M_DEVBUF,
>     M_WAITOK | M_ZERO);
>     -       new_vidsw = malloc(sizeof(*new_vidsw)*newsize, M_DEVBUF,
>     -           M_WAITOK | M_ZERO);
>     -       new_cdevsw = malloc(sizeof(*new_cdevsw)*newsize, M_DEVBUF,
>     -#endif
>     -       bcopy(adapter, new_adp, sizeof(*adapter)*adapters);
>     -       bcopy(vidsw, new_vidsw, sizeof(*vidsw)*adapters);
>     -       bcopy(vidcdevsw, new_cdevsw, sizeof(*vidcdevsw)*adapters);
>     -#endif
>     -       if (adapters > 1) {
>     -               free(adapter, M_DEVBUF);
>     -               free(vidsw, M_DEVBUF);
>     -               free(vidcdevsw, M_DEVBUF);
>     -#endif
>     -       adapter = new_adp;
>     -       vidsw = new_vidsw;
>     -       vidcdevsw = new_cdevsw;
>     -#endif
>     -       adapters = newsize;
>     -       splx(s);
>     -       if (bootverbose)
>     -               printf("fb: new array size %d\n", adapters);
>     -       return 0;
>     -static void
>     -vid_malloc_init(void *arg)
>     -       vid_malloc = TRUE;
>     -SYSINIT(vid_mem, SI_SUB_KMEM, SI_ORDER_ANY, vid_malloc_init, NULL);
>     - * Low-level frame buffer driver functions
>     - * frame buffer subdrivers, such as the VGA driver, call these
>     functions
>     - * to initialize the video_adapter structure and register it to the
>     virtual
>     - * frame buffer driver `fb'.
>     -/* initialize the video_adapter_t structure */
>     -void
>     -vid_init_struct(video_adapter_t *adp, char *name, int type, int unit)
>     -       adp->va_flags = 0;
>     -       adp->va_name = name;
>     -       adp->va_type = type;
>     -       adp->va_unit = unit;
>     -/* Register a video adapter */
>     -int
>     -vid_register(video_adapter_t *adp)
>     -       const video_driver_t **list;
>     -       const video_driver_t *p;
>     -       int index;
>     -       for (index = 0; index < adapters; ++index) {
>     -               if (adapter[index] == NULL)
>     -                       break;
>     -       if (index >= adapters) {
>     -               if (vid_realloc_array())
>     -                       return -1;
>     -       adp->va_index = index;
>     -       adp->va_token = NULL;
>     -       SET_FOREACH(list, videodriver_set) {
>     -               p = *list;
>     -               if (strcmp(p->name, adp->va_name) == 0) {
>     -                       adapter[index] = adp;
>     -                       vidsw[index] = p->vidsw;
>     -                       return index;
>     -       return -1;
>     -int
>     -vid_unregister(video_adapter_t *adp)
>     -       if ((adp->va_index < 0) || (adp->va_index >= adapters))
>     -               return ENOENT;
>     -       if (adapter[adp->va_index] != adp)
>     -               return ENOENT;
>     -       adapter[adp->va_index] = NULL;
>     -       vidsw[adp->va_index] = NULL;
>     -       return 0;
>     -/* Get video I/O function table */
>     -video_switch_t
>     -*vid_get_switch(char *name)
>     -               p = *list;
>     -               if (strcmp(p->name, name) == 0)
>     -                       return p->vidsw;
>     -       return NULL;
>     - * Video card client functions
>     - * Video card clients, such as the console driver `syscons' and the
>     frame
>     - * buffer cdev driver, use these functions to claim and release a
>     card for
>     - * exclusive use.
>     -/* find the video card specified by a driver name and a unit number */
>     -int
>     -vid_find_adapter(char *driver, int unit)
>     -       int i;
>     -       for (i = 0; i < adapters; ++i) {
>     -               if (adapter[i] == NULL)
>     -                       continue;
>     -               if (strcmp("*", driver) &&
>     strcmp(adapter[i]->va_name, driver))
>     -                       continue;
>     -               if ((unit != -1) && (adapter[i]->va_unit != unit))
>     -                       continue;
>     -               return i;
>     -       return -1;
>     -/* allocate a video card */
>     -int
>     -vid_allocate(char *driver, int unit, void *id)
>     -       int index;
>     -       int s;
>     -       s = spltty();
>     -       index = vid_find_adapter(driver, unit);
>     -       if (index >= 0) {
>     -               if (adapter[index]->va_token) {
>     -                       splx(s);
>     -                       return -1;
>     -               adapter[index]->va_token = id;
>     -       splx(s);
>     -       return index;
>     -int
>     -vid_release(video_adapter_t *adp, void *id)
>     -       int error;
>     -       int s;
>     -       s = spltty();
>     -       if (adp->va_token == NULL) {
>     -               error = EINVAL;
>     -       } else if (adp->va_token != id) {
>     -               error = EPERM;
>     -       } else {
>     -               error = 0;
>     -       splx(s);
>     -       return error;
>     -/* Get a video adapter structure */
>     -video_adapter_t
>     -*vid_get_adapter(int index)
>     -       if ((index < 0) || (index >= adapters))
>     -               return NULL;
>     -       return adapter[index];
>     -/* Configure drivers: this is a backdoor for the console driver XXX */
>     -int
>     -vid_configure(int flags)
>     -               p = *list;
>     -               if (p->configure != NULL)
>     -                       (*p->configure)(flags);
>     -       return 0;
>     - * Virtual frame buffer cdev driver functions
>     - * The virtual frame buffer driver dispatches driver functions to
>     - * appropriate subdrivers.
>     -#define FB_DRIVER_NAME "fb"
>     -#if 0 /* experimental */
>     -static devclass_t      fb_devclass;
>     -static int             fbprobe(device_t dev);
>     -static int             fbattach(device_t dev);
>     -static device_method_t fb_methods[] = {
>     -       DEVMETHOD(device_probe,         fbprobe),
>     -       DEVMETHOD(device_attach,        fbattach),
>     -       DEVMETHOD_END
>     -static driver_t fb_driver = {
>     -       FB_DRIVER_NAME,
>     -       fb_methods,
>     -       0,
>     -static int
>     -fbprobe(device_t dev)
>     -       int unit;
>     -       unit = device_get_unit(dev);
>     -       if (unit >= adapters)
>     -               return ENXIO;
>     -       if (adapter[unit] == NULL)
>     -               return ENXIO;
>     -       device_set_desc(dev, "generic frame buffer");
>     -       return 0;
>     -static int
>     -fbattach(device_t dev)
>     -       printf("fbattach: about to attach children\n");
>     -       bus_generic_attach(dev);
>     -       return 0;
>     -#endif
>     -#define FB_UNIT(dev)   dev2unit(dev)
>     -#define FB_MKMINOR(unit) (u)
>     -static d_open_t                fbopen;
>     -static d_close_t       fbclose;
>     -static d_read_t                fbread;
>     -static d_write_t       fbwrite;
>     -static d_ioctl_t       fbioctl;
>     -static d_mmap_t                fbmmap;
>     -static struct cdevsw fb_cdevsw = {
>     -       .d_version =    D_VERSION,
>     -       .d_flags =      D_NEEDGIANT,
>     -       .d_open =       fbopen,
>     -       .d_close =      fbclose,
>     -       .d_read =       fbread,
>     -       .d_write =      fbwrite,
>     -       .d_ioctl =      fbioctl,
>     -       .d_mmap =       fbmmap,
>     -       .d_name =       FB_DRIVER_NAME,
>     -#endif
>     -static int
>     -fb_modevent(module_t mod, int type, void *data)
>     -       switch (type) {
>     -       case MOD_LOAD:
>     -               break;
>     -       case MOD_UNLOAD:
>     -               printf("fb module unload - not possible for this
>     module type\n");
>     -               return EINVAL;
>     -       default:
>     -               return EOPNOTSUPP;
>     -       return 0;
>     -static moduledata_t fb_mod = {
>     -       "fb",
>     -       fb_modevent,
>     -       NULL
>     -DECLARE_MODULE(fb, fb_mod, SI_SUB_PSEUDO, SI_ORDER_ANY);
>     -int
>     -fb_attach(int unit, video_adapter_t *adp, struct cdevsw *cdevsw)
>     -       int s;
>     -       if (adp->va_index >= adapters)
>     -               return EINVAL;
>     -               return EINVAL;
>     -       s = spltty();
>     -       adp->va_minor = unit;
>     -       vidcdevsw[adp->va_index] = cdevsw;
>     -       splx(s);
>     -       printf("fb%d at %s%d\n", adp->va_index, adp->va_name,
>     adp->va_unit);
>     -       return 0;
>     -int
>     -fb_detach(int unit, video_adapter_t *adp, struct cdevsw *cdevsw)
>     -       int s;
>     -               return EINVAL;
>     -               return EINVAL;
>     -       if (vidcdevsw[adp->va_index] != cdevsw)
>     -               return EINVAL;
>     -       s = spltty();
>     -       vidcdevsw[adp->va_index] = NULL;
>     -       splx(s);
>     -       return 0;
>     - * Generic frame buffer cdev driver functions
>     - * Frame buffer subdrivers may call these functions to implement common
>     - * driver functions.
>     -int genfbopen(genfb_softc_t *sc, video_adapter_t *adp, int flag,
>     int mode,
>     -             struct thread *td)
>     -       int s;
>     -       s = spltty();
>     -       if (!(sc->gfb_flags & FB_OPEN))
>     -               sc->gfb_flags |= FB_OPEN;
>     -       splx(s);
>     -       return 0;
>     -int genfbclose(genfb_softc_t *sc, video_adapter_t *adp, int flag,
>     int mode,
>     -       int s;
>     -       s = spltty();
>     -       sc->gfb_flags &= ~FB_OPEN;
>     -       splx(s);
>     -       return 0;
>     -int genfbread(genfb_softc_t *sc, video_adapter_t *adp, struct uio *uio,
>     -             int flag)
>     -       int size;
>     -       int offset;
>     -       int error;
>     -       int len;
>     -       error = 0;
>     -       size = adp->va_buffer_size/adp->va_info.vi_planes;
>     -       while (uio->uio_resid > 0) {
>     -               if (uio->uio_offset >= size)
>     -                       break;
>     -               offset = uio->uio_offset%adp->va_window_size;
>     -               len = imin(uio->uio_resid, size - uio->uio_offset);
>     -               len = imin(len, adp->va_window_size - offset);
>     -               if (len <= 0)
>     -                       break;
>     -               vidd_set_win_org(adp, uio->uio_offset);
>     -               error = uiomove((caddr_t)(adp->va_window + offset),
>     len, uio);
>     -               if (error)
>     -                       break;
>     -       return error;
>     -int genfbwrite(genfb_softc_t *sc, video_adapter_t *adp, struct uio
>     *uio,
>     -              int flag)
>     -       return ENODEV;
>     -int genfbioctl(genfb_softc_t *sc, video_adapter_t *adp, u_long cmd,
>     -              caddr_t arg, int flag, struct thread *td)
>     -       int error;
>     -       if (adp == NULL)        /* XXX */
>     -               return ENXIO;
>     -       error = vidd_ioctl(adp, cmd, arg);
>     -       if (error == ENOIOCTL)
>     -               error = ENODEV;
>     -       return error;
>     -int genfbmmap(genfb_softc_t *sc, video_adapter_t *adp, vm_ooffset_t
>     offset,
>     -             vm_offset_t *paddr, int prot, vm_memattr_t *memattr)
>     -       return vidd_mmap(adp, offset, paddr, prot, memattr);
>     -#endif /* FB_INSTALL_CDEV */
>     -static char
>     -*adapter_name(int type)
>     -    static struct {
>     -       int type;
>     -       char *name;
>     -    } names[] = {
>     -       { KD_MONO,      "MDA" },
>     -       { KD_HERCULES,  "Hercules" },
>     -       { KD_CGA,       "CGA" },
>     -       { KD_EGA,       "EGA" },
>     -       { KD_VGA,       "VGA" },
>     -       { KD_TGA,       "TGA" },
>     -       { -1,           "Unknown" },
>     -    int i;
>     -    for (i = 0; names[i].type != -1; ++i)
>     -       if (names[i].type == type)
>     -           break;
>     -    return names[i].name;
>     - * Generic low-level frame buffer functions
>     - * The low-level functions in the frame buffer subdriver may use these
>     - * functions.
>     -void
>     -fb_dump_adp_info(char *driver, video_adapter_t *adp, int level)
>     -    if (level <= 0)
>     -       return;
>     -    printf("%s%d: %s%d, %s, type:%s (%d), flags:0x%x\n",
>     -          FB_DRIVER_NAME, adp->va_index, driver, adp->va_unit,
>     adp->va_name,
>     -          adapter_name(adp->va_type), adp->va_type, adp->va_flags);
>     -    printf("%s%d: port:0x%lx-0x%lx, crtc:0x%lx, mem:0x%lx 0x%x\n",
>     -          FB_DRIVER_NAME, adp->va_index, (u_long)adp->va_io_base,
>     -          (u_long)adp->va_io_base + adp->va_io_size - 1,
>     -          (u_long)adp->va_crtc_addr, (u_long)adp->va_mem_base,
>     -          adp->va_mem_size);
>     -    printf("%s%d: init mode:%d, bios mode:%d, current mode:%d\n",
>     -          adp->va_initial_mode, adp->va_initial_bios_mode,
>     adp->va_mode);
>     -    printf("%s%d: window:%p size:%dk gran:%dk, buf:%p size:%dk\n",
>     -          (void *)adp->va_window, (int)adp->va_window_size/1024,
>     -          (int)adp->va_window_gran/1024, (void *)adp->va_buffer,
>     -          (int)adp->va_buffer_size/1024);
>     -void
>     -fb_dump_mode_info(char *driver, video_adapter_t *adp, video_info_t
>     *info,
>     -                 int level)
>     -    if (level <= 0)
>     -       return;
>     -    printf("%s%d: %s, mode:%d, flags:0x%x ",
>     -          driver, adp->va_unit, adp->va_name, info->vi_mode,
>     info->vi_flags);
>     -    if (info->vi_flags & V_INFO_GRAPHICS)
>     -       printf("G %dx%dx%d, %d plane(s), font:%dx%d, ",
>     -              info->vi_width, info->vi_height,
>     -              info->vi_depth, info->vi_planes,
>     -              info->vi_cwidth, info->vi_cheight);
>     -    else
>     -       printf("T %dx%d, font:%dx%d, ",
>     -    printf("win:0x%lx\n", (u_long)info->vi_window);
>     -int
>     -fb_type(int adp_type)
>     -       static struct {
>     -               int     fb_type;
>     -               int     va_type;
>     -       } types[] = {
>     -               { FBTYPE_MDA,           KD_MONO },
>     -               { FBTYPE_HERCULES,      KD_HERCULES },
>     -               { FBTYPE_CGA,           KD_CGA },
>     -               { FBTYPE_EGA,           KD_EGA },
>     -               { FBTYPE_VGA,           KD_VGA },
>     -               { FBTYPE_TGA,           KD_TGA },
>     -       int i;
>     -       for (i = 0; i < nitems(types); ++i) {
>     -               if (types[i].va_type == adp_type)
>     -                       return types[i].fb_type;
>     -       return -1;
>     -int
>     -fb_commonioctl(video_adapter_t *adp, u_long cmd, caddr_t arg)
>     -       int error;
>     -       int s;
>     -       /* assert(adp != NULL) */
>     -       error = 0;
>     -       s = spltty();
>     -       switch (cmd) {
>     -       case FBIO_ADAPTER:      /* get video adapter index */
>     -               *(int *)arg = adp->va_index;
>     -               break;
>     -       case FBIO_ADPTYPE:      /* get video adapter type */
>     -               *(int *)arg = adp->va_type;
>     -               break;
>     -       case FBIO_ADPINFO:      /* get video adapter info */
>     -               ((video_adapter_info_t *)arg)->va_index = adp->va_index;
>     -               ((video_adapter_info_t *)arg)->va_type = adp->va_type;
>     -               bcopy(adp->va_name, ((video_adapter_info_t
>     *)arg)->va_name,
>     -                     imin(strlen(adp->va_name) + 1,
>     -                          sizeof(((video_adapter_info_t
>     *)arg)->va_name)));
>     -               ((video_adapter_info_t *)arg)->va_unit = adp->va_unit;
>     -               ((video_adapter_info_t *)arg)->va_flags = adp->va_flags;
>     -               ((video_adapter_info_t *)arg)->va_io_base =
>     adp->va_io_base;
>     -               ((video_adapter_info_t *)arg)->va_io_size =
>     adp->va_io_size;
>     -               ((video_adapter_info_t *)arg)->va_crtc_addr =
>     adp->va_crtc_addr;
>     -               ((video_adapter_info_t *)arg)->va_mem_base =
>     adp->va_mem_base;
>     -               ((video_adapter_info_t *)arg)->va_mem_size =
>     adp->va_mem_size;
>     -               ((video_adapter_info_t *)arg)->va_window
>     -#if defined(__amd64__) || defined(__i386__)
>     -                       = vtophys(adp->va_window);
>     -#else
>     -                       = adp->va_window;
>     -#endif
>     -               ((video_adapter_info_t *)arg)->va_window_size
>     -                       = adp->va_window_size;
>     -               ((video_adapter_info_t *)arg)->va_window_gran
>     -                       = adp->va_window_gran;
>     -               ((video_adapter_info_t *)arg)->va_window_orig
>     -                       = adp->va_window_orig;
>     -               ((video_adapter_info_t *)arg)->va_unused0
>     -                       = adp->va_buffer != 0 ?
>     vtophys(adp->va_buffer) : 0;
>     -#else
>     -                       = adp->va_buffer;
>     -#endif
>     -               ((video_adapter_info_t *)arg)->va_buffer_size
>     -                       = adp->va_buffer_size;
>     -               ((video_adapter_info_t *)arg)->va_mode = adp->va_mode;
>     -               ((video_adapter_info_t *)arg)->va_initial_mode
>     -                       = adp->va_initial_mode;
>     -               ((video_adapter_info_t *)arg)->va_initial_bios_mode
>     -                       = adp->va_initial_bios_mode;
>     -               ((video_adapter_info_t *)arg)->va_line_width
>     -                       = adp->va_line_width;
>     -               ((video_adapter_info_t *)arg)->va_disp_start.x
>     -                       = adp->va_disp_start.x;
>     -               ((video_adapter_info_t *)arg)->va_disp_start.y
>     -                       = adp->va_disp_start.y;
>     -               break;
>     -       case FBIO_MODEINFO:     /* get mode information */
>     -               error = vidd_get_info(adp,
>     -                   ((video_info_t *)arg)->vi_mode,
>     -                   (video_info_t *)arg);
>     -               if (error)
>     -                       error = ENODEV;
>     -               break;
>     -       case FBIO_FINDMODE:     /* find a matching video mode */
>     -               error = vidd_query_mode(adp, (video_info_t *)arg);
>     -               break;
>     -       case FBIO_GETMODE:      /* get video mode */
>     -               *(int *)arg = adp->va_mode;
>     -               break;
>     -       case FBIO_SETMODE:      /* set video mode */
>     -               error = vidd_set_mode(adp, *(int *)arg);
>     -               if (error)
>     -                       error = ENODEV; /* EINVAL? */
>     -               break;
>     -       case FBIO_GETWINORG:    /* get frame buffer window origin */
>     -               *(u_int *)arg = adp->va_window_orig;
>     -               break;
>     -       case FBIO_GETDISPSTART: /* get display start address */
>     -               ((video_display_start_t *)arg)->x =
>     -               ((video_display_start_t *)arg)->y =
>     -               break;
>     -       case FBIO_GETLINEWIDTH: /* get scan line width in bytes */
>     -               *(u_int *)arg = adp->va_line_width;
>     -               break;
>     -       case FBIO_BLANK:        /* blank display */
>     -               error = vidd_blank_display(adp, *(int *)arg);
>     -               break;
>     -       case FBIO_GETPALETTE:   /* get color palette */
>     -       case FBIO_SETPALETTE:   /* set color palette */
>     -               /* XXX */
>     -       case FBIOPUTCMAP:
>     -       case FBIOGETCMAP:
>     -       case FBIOPUTCMAPI:
>     -       case FBIOGETCMAPI:
>     -               /* XXX */
>     -       case FBIO_SETWINORG:    /* set frame buffer window origin */
>     -       case FBIO_SETDISPSTART: /* set display start address */
>     -       case FBIO_SETLINEWIDTH: /* set scan line width in pixel */
>     -       case FBIOGTYPE:
>     -       case FBIOGATTR:
>     -       case FBIOSVIDEO:
>     -       case FBIOGVIDEO:
>     -       case FBIOVERTICAL:
>     -       case FBIOSCURSOR:
>     -       case FBIOGCURSOR:
>     -       case FBIOSCURPOS:
>     -       case FBIOGCURPOS:
>     -       case FBIOGCURMAX:
>     -       case FBIOMONINFO:
>     -       case FBIOGXINFO:
>     -       default:
>     -               error = ENODEV;
>     -               break;
>     -       splx(s);
>     -       return error;
>     diff --git a/libbsd.py b/libbsd.py
>     index f128961b..bd8963ef 100644
>     --- a/libbsd.py
>     +++ b/libbsd.py
>     @@ -815,7 +815,6 @@ class display(builder.Module):
>                      'sys/dev/videomode/edid.c',
>                      'sys/dev/videomode/vesagtf.c',
>                      'sys/dev/videomode/videomode.c',
>     -                'sys/dev/fb/fb.c',
>                      'sys/dev/fb/fbd.c',
>                      'sys/arm/ti/am335x/am335x_lcd.c',
>                      'sys/arm/ti/am335x/am335x_pwmss.c',
>     diff --git a/rtemsbsd/include/bsp/nexus-devices.h
>     b/rtemsbsd/include/bsp/nexus-devices.h
>     index e9da3be1..ac9afbce 100644
>     --- a/rtemsbsd/include/bsp/nexus-devices.h
>     +++ b/rtemsbsd/include/bsp/nexus-devices.h
>     @@ -70,8 +70,6 @@ SYSINIT_DRIVER_REFERENCE(iic, iicbus);
>      SYSINIT_DRIVER_REFERENCE(tda, iicbus);
>      SYSINIT_DRIVER_REFERENCE(iicbus, rtems_i2c);
>      SYSINIT_DRIVER_REFERENCE(fbd, fb);
>     -SYSINIT_DRIVER_REFERENCE(fb, fb_mod);
>     -SYSINIT_MODULE_REFERENCE(fb_mod);
>      #ifdef RTEMS_BSD_MODULE_NET80211
>      SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
>      SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
>     2.20.1
