GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena rmeena840 at gmail.com
Tue Aug 6 06:34:34 UTC 2019
> > The decoded thread name is "swi6: task queu"
> > For each RTEMS_RECORD_THREAD_NAME event you start the loop at i == 0, so
> > you overwrite your previous data.
> The thread name encoding was difficult to decode. I changed it like this:
> https://git.rtems.org/rtems/commit/?id=cc91fae43a71ccb5f47fa7ed179dd86c53e290ae
> I pushed new raw data to the repository.
Okay.
This is how Konsole output looks like:
Object Index: 1 Name: IDLE
Object Index: 2 Name: IDLE
Object Index: 3 Name: IDLE
Object Index: 4 Name: IDLE
Object Index: 5 Name: IDLE
Object Index: 6 Name: IDLE
Object Index: 7 Name: IDLE
Object Index: 8 Name: IDLE
Object Index: 9 Name: IDLE
Object Index: 10 Name: IDLE
Object Index: 11 Name: IDLE
Object Index: 12 Name: IDLE
Object Index: 13 Name: IDLE
Object Index: 14 Name: IDLE
Object Index: 15 Name: IDLE
Object Index: 16 Name: IDLE
Object Index: 17 Name: IDLE
Object Index: 18 Name: IDLE
Object Index: 19 Name: IDLE
Object Index: 20 Name: IDLE
Object Index: 21 Name: IDLE
Object Index: 22 Name: IDLE
Object Index: 23 Name: IDLE
Object Index: 24 Name: IDLE
Object Index: 1 Name: UI1
Object Index: 2 Name: BSWP
Object Index: 3 Name: BRDA
Object Index: 4 Name: MDIA
Object Index: 5 Name: TIME
Object Index: 6 Name: IRQS
Object Index: 7 Name: IRQS
Object Index: 8 Name: IRQS
Object Index: 9 Name: IRQS
Object Index: 10 Name: IRQS
Object Index: 11 Name: IRQS
Object Index: 12 Name: IRQS
Object Index: 13 Name: IRQS
Object Index: 14 Name: IRQS
Object Index: 15 Name: IRQS
Object Index: 16 Name: IRQS
Object Index: 17 Name: IRQS
Object Index: 18 Name: IRQS
Object Index: 19 Name: IRQS
Object Index: 20 Name: IRQS
Object Index: 21 Name: IRQS
Object Index: 22 Name: IRQS
Object Index: 23 Name: IRQS
Object Index: 24 Name: IRQS
Object Index: 25 Name: IRQS
Object Index: 26 Name: IRQS
Object Index: 27 Name: IRQS
Object Index: 28 Name: IRQS
Object Index: 29 Name: IRQS
Object Index: 30 Name: swi6
Object Index: 30 Name: swi6sk q
Object Index: 31 Name: conf
Object Index: 32 Name: swi5
Object Index: 32 Name: swi5st t
Object Index: 33 Name: kque
Object Index: 33 Name: kquetx t
Object Index: 34 Name: thre
Object Index: 34 Name: threaskq
Object Index: 35 Name: swi6
Object Index: 35 Name: swi6ant
Object Index: 36 Name: swi1
Object Index: 36 Name: swi1tisr
Object Index: 37 Name: soft
Object Index: 37 Name: soft0
Object Index: 38 Name: DHCP
Object Index: 39 Name: PRTL
Object Index: 40 Name: PSTA
Object Index: 41 Name: PRTL
Object Index: 42 Name: PSTA
Object Index: 43 Name: FTPa
Object Index: 44 Name: FTPb
Object Index: 45 Name: FTPc
Object Index: 46 Name: FTPd
Object Index: 47 Name: FTPe
Object Index: 48 Name: FTPf
Object Index: 49 Name: FTPg
Object Index: 50 Name: FTPh
Object Index: 51 Name: FTPi
Object Index: 52 Name: FTPj
Object Index: 53 Name: FTPk
Object Index: 54 Name: FTPl
Object Index: 55 Name: FTPm
Object Index: 56 Name: FTPn
Object Index: 57 Name: FTPo
Object Index: 58 Name: FTPp
Object Index: 59 Name: FTPq
Object Index: 60 Name: FTPr
Object Index: 61 Name: FTPs
Object Index: 62 Name: FTPt
Object Index: 63 Name: FTPu
Object Index: 64 Name: FTPv
Object Index: 65 Name: FTPw
Object Index: 66 Name: FTPx
Object Index: 67 Name: FTPD
Object Index: 68 Name: TNTa
Object Index: 69 Name: TNTb
Object Index: 70 Name: TNTc
Object Index: 71 Name: TNTd
Object Index: 72 Name: TNTe
Object Index: 73 Name: TNTD
Object Index: 74 Name: RCRD
Object Index: 75 Name: SHLL
Thread name is in the right order now.
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/d5d3c464/attachment-0002.html>
