Not able to run riscv-rv32imac testsuites
Vaibhav Gupta vaibhavgupta40 at gmail.com
Tue Aug 6 13:51:26 UTC 2019
I am getting following error:
$ rtems-test --rtems-bsp=rv32imac_spike
--rtems-tools=$HOME/development/rtems/5
~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
RTEMS Testing - Tester, 5.0.not_released
 Command Line: /home/varodek/development/rtems/5/bin/rtems-test
--rtems-bsp=rv32imac_spike --rtems-tools=/home/varodek/development/rtems/5
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
 Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46
UTC 2019 x86_64
 Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
[ 2/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | riscv32/rv32imac:
capture.exe
[ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | riscv32/rv32imac:
cdtest.exe
[ 4/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | riscv32/rv32imac:
cxx_iostream.exe
[ 1/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | riscv32/rv32imac:
base_sp.exe
error: spike.cfg:58: execute failed: spike --isa=RV32IMAC
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe:
exit-code:2
exit-code:2
warning: switched to dry run due to errors
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe:
exit-code:2
exit-code:2
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe:
exit-code:2
exit-code:2
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe:
exit-code:2
exit-code:2
base_sp.exe
Result: invalid    Time: 0:00:00.032377 base_sp.exe
=>  run: spike --isa=RV32IMAC
capture.exe
Result: invalid    Time: 0:00:00.037950 capture.exe
cdtest.exe
Result: invalid    Time: 0:00:00.038061 cdtest.exe
cxx_iostream.exe
Result: invalid    Time: 0:00:00.034353 cxx_iostream.exe
[ 7/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | riscv32/rv32imac:
minimum.exe
[ 8/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | riscv32/rv32imac:
nsecs.exe
[ 5/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | riscv32/rv32imac:
fileio.exe
[ 6/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | riscv32/rv32imac:
hello.exe
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/minimum.exe:
exit-code:2
exit-code:2
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe:
exit-code:2
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe:
exit-code:2
exit-code:2
exit-code:2
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe:
exit-code:2
exit-code:2
fileio.exe
Result: invalid    Time: 0:00:00.009235 fileio.exe
hello.exe
Result: invalid    Time: 0:00:00.005886 hello.exe
minimum.exe
nsecs.exe
Result: invalid    Time: 0:00:00.011045 nsecs.exe
[ 9/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  | riscv32/rv32imac:
paranoia.exe
[10/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  | riscv32/rv32imac:
ticker.exe
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe:
exit-code:2
exit-code:2
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe:
exit-code:2
exit-code:2
[11/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:8  W:0  | riscv32/rv32imac:
unlimited.exe
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe:
exit-code:2
exit-code:2
paranoia.exe
Result: invalid    Time: 0:00:00.011650 paranoia.exe
ticker.exe
Result: invalid    Time: 0:00:00.009872 ticker.exe
unlimited.exe
Result: invalid    Time: 0:00:00.002352 unlimited.exe
Passed:         1
Failed:         0
User Input:     0
Expected Fail:  0
Indeterminate:  0
Benchmark:      0
Timeout:        0
Invalid:       10
Wrong Version:  0
Wrong Build:    0
Wrong Tools:    0
Total:         11
Invalid:
 capture.exe
 cdtest.exe
 cxx_iostream.exe
 base_sp.exe
 nsecs.exe
 fileio.exe
 hello.exe
 paranoia.exe
 ticker.exe
 unlimited.exe
Average test time: 0:00:00.093749
Testing time     : 0:00:01.031239
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/3fabe390/attachment-0002.html>
