Spike fails to build with RSB
    Joel Sherrill
    joel at rtems.org
    Tue Aug  6 16:01:48 UTC 2019
Adding the log with --trace.
I hope this helps someone.
--joel
On Tue, Aug 6, 2019 at 10:55 AM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I wanted to pitch in on the spike testing but can't build it:
> + ../source-builder/sb-set-builder --trace --log=l-spike.txt
> --prefix=/home/joel/rtems-work/tools/5 devel/spike
> RTEMS Source Builder - Set Builder, 5 (29fab0500e22)
> Build Set: devel/spike
> config: devel/spike-1.1.0.cfg
> package: spike-1.1.0-x86_64-linux-gnu-1
> building: spike-1.1.0-x86_64-linux-gnu-1
> sizes: spike-1.1.0-x86_64-linux-gnu-1: 85.471MB (installed: 12.497MB)
> cleaning: spike-1.1.0-x86_64-linux-gnu-1
> error: copying tree (3):
> /data/home/joel/rtems-work/rtems-source-builder/bare/build/tmp/spike-1.1.0-x86_64-linux-gnu-1-joel/home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc
> /data/home/joel/rtems-work/rtems-source-builder/bare/build/tmp/sb-joel/devel/spike/home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc:
> [Errno 13] Permission denied:
> u'/data/home/joel/rtems-work/rtems-source-builder/bare/build/tmp/sb-joel/devel/spike/home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc'
> Build Set: Time 0:00:19.604209
> Build FAILED
> Any ideas why this fails?
> FWIW I have never been able to build spike with the RSB and have reported
> it before. It would be nice if it got fixed.
> Thanks.
> --joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/ff4038ae/attachment-0002.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/ff4038ae/attachment-0002.obj>
