GSoC PRU: AM35xx Clock driver
    Nils Hölscher
    nilhoel1 at gmail.com
    Wed Aug  7 09:35:38 UTC 2019
Hi,
I was able to confirm that the current libBSD implementation scans the fdt
only once.
caller:
https://github.com/RTEMS/rtems-libbsd/blob/f60ac53420f36060c13104f9a555f39ebc619b09/freebsd/sys/kern/subr_bus.c#L5100
callee:
https://github.com/RTEMS/rtems-libbsd/blob/f60ac53420f36060c13104f9a555f39ebc619b09/freebsd/sys/kern/subr_bus.c#L969
The function BUS_NEW_PASS initialises a pass over fdt with all drivers of
the current pass level.
However after trying to add another pass, I realized that all drivers are
on the DEFAULT_PASS_LEVEL (max_integer).
Best and thanks,
Nils
On Thu, 1 Aug 2019 at 11:36, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Hello Nils,
> On 31/07/2019 14:54, Nils Hölscher wrote:
> > Hi,
> > I have been reading into the FreeBSD init code the past few days,
> > especially for Driver_MODULE.
> > Expect an Blog entry today or tomorrow.
> > Because I don't have JTAG, it took me quite some time.
> I would always suggest a JTAG or some other kind of debugger for
> embedded work. In a professional work environment you should try to
> convince your boss that it is a big time saver (which is definitively
> true) so that even an expensive debugger is a good investment
> By the way: For understanding the initialization sequence you might can
> use a simulator too. For the basic sequence you can simulate any BSP and
> are not bound to BBB.
> > With BUS_DEBUG enabled I saw that the problem is indeed that the pruss
> > unit is discovered too early.
> > Is this device tree related?
> It's possible that this is a difference in how modules are handled. I'm
> not sure whether FreeBSD loads EARLY_MODULES dynamically at another time
> during boot while we link everything in from the start. If that is true,
> the mechanism might not work the same like in FreeBSD. You might want to
> have a look at that.
> > I am not sure, cause the overlay I am using is from the BSD community.
> > I added my output to a gist and link to the interesting parts.
> > The EARLY_DRIVER_MODULE's are indeed loaded first.
> https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L125
> > Nexus bus attaches and the driver goes over every discovered device and
> > tries to attach the drivers in order:
> https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L326
> > ofwbus gets discovered:
> https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L747
> > Here the ti_pruss device gets discovered too early in the fdt and fails:
> https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L904
> > I still haven't found the loop running over fdt.
> Don't have a test environment ready so this is just from a quick glance
> at the code. I might have missed something:
> simplebus_attach adds all child nodes from the tree to the bus:
> https://git.rtems.org/rtems-libbsd/tree/freebsd/sys/dev/fdt/simplebus.c#n157
> The bus_generic_attach then loops over all children and calls their
> probe and attach functions:
> https://git.rtems.org/rtems-libbsd/tree/freebsd/sys/kern/subr_bus.c#n3768
> Best regards
> Christian
> > And it seems that the device tree only gets one iteration.
> > But the BSD man page for EARLY_DRIVER_MODULE states that every
> > PASS_LEVEL has an iteration.
> >      The *EARLY*_*DRIVER*_*MODULE*() macro allows a driver to be
> registered for a
> >      specific pass level.  The boot time probe and attach process makes
>      *_multi- _ _ple passes over the device tree_*.  Certain critical
>   drivers that provide
> >      basic services needed by other devices are       attach during
> earlier passes.
> >      Most drivers are attached in a final general pass.        A driver
> that
> >      attaches during an       early pass must register for a specific
> pass level
> >      (BUS_PASS_*) via the /pass/ argument.  Once a driver     is
> registered it is
> >      available to attach to devices for       all subsequent passes."
> https://www.freebsd.org/cgi/man.cgi?query=DRIVER_MODULE&sektion=9&apropos=0&manpath=FreeBSD+12.0-RELEASE+and+Ports
> > Best,
> > Nils
> > On Sun, 28 Jul 2019 at 11:34, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     On 28/07/2019 11:22, Nils Hölscher wrote:
> >     > On Sat, 27 Jul 2019 at 14:34, Christian Mauderer
> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >     On 24/07/2019 16:53, Nils Hölscher wrote:
> >     >     > Hi,
> >     >     > @Vijay Kumar Banerjee <mailto:vijaykumar9597 at gmail.com
> >     <mailto:vijaykumar9597 at gmail.com>
> >     <mailto:vijaykumar9597 at gmail.com>>>  thanks for the
> >     >     > dtb file.
> >     >     > I build my file from FreeBSD master.
> >     >     > Prcm attaches now but still after the pruss driver...:
> >     >     > nexus0: <RTEMS Nexus device>
> >     >     > ofwbus0: <Open Firmware Device Tree> on nexus0
> >     >     > simplebus0: <Flattened device tree simple bus> on ofwbus0
> >     >     > *ti_pruss0: <TI Programmable Realtime Unit Subsystem> mem
> >     >     > 0x4a300000-0x4a37ffff irq 20,21,22,23,24,25,26,27 on
> simplebus0
> >     >     > ti_pruss0: could not enable PRUSS clock
> >     >     > device_attach: ti_pruss0 attach returned 6*
> >     >     > simplebus1: <Flattened device tree simple bus> on simplebus0*
> >     >     > am335x_prcm0: <AM335x Power and Clock Management> mem
> >     >     0x200000-0x203fff
> >     >     > on simplebus1*
> >     >     Hello Nils,
> >     >     I'm not sure about the order. But what seems a little bit odd
> >     is that
> >     >     the prcm0 is found in simplebus0 while am335x_prcm0 is found on
> >     >     simplebus1. Maybe it's worth investigating how that order is
> >     created and
> >     >     how it is handled in RTEMS.
> >     > Thanks for the information.
> >     > I think the way rtems initializes the bsd modules differs from the
> way
> >     > described in the libbsd manuel.
> >     > But I will have to investigate that further.
> >     I'm not 100% sure but as far as I know the _modules_ should be
> >     initialized in the given order (early module prior to normal module).
> >     But the device detection is something different. I think there is
> some
> >     loop in simplebus that loops over the devices and asks every driver
> >     whether it wants to handle that device. If yes the driver can have
> it.
> >     If no the device is unhandled.
> >     For a module that is mentioned in the device tree I would expect that
> >     the order in the device tree binary is the one used. For devices
> outside
> >     of the device tree most likely some link order is used.
> >     If you have a debugger you might want to search for the loops and
> take a
> >     look at when they are called and how they add devices. I don't think
> >     that there are that many early modules yet that would use the device
> >     tree. So it's possible that there is some call missing that would
> parse
> >     the device tree for early modules.
> >     >     A general note regarding the prcm module: In RTEMS most
> >     (non-libbsd)
> >     >     drivers enable their power and clocks themself. Please make
> >     sure that
> >     >     the FreeBSD prcm doesn't interfere with that. Otherwise you
> >     might get
> >     >     odd effects.
> >     > Thanks I will keep that in mind.
> >     > Best,
> >     > Nils
> >     >     Best regards
> >     >     Christian
> >     >     > *====am335x_prcm_attach====*
> >     >     > Is there anything else I can do besides using
> MODULE_DEPENDENCY,
> >     >     which I
> >     >     > already use.
> >     >     > The prcm module is also a EARLY_DRIVER_MODULE.
> >     >     > Best,
> >     >     > Nils
> >     >     > On Wed, 24 Jul 2019 at 16:04, Vijay Kumar Banerjee
> >     >     > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>
> >     <mailto:vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>
> >     <mailto:vijaykumar9597 at gmail.com> <mailto:vijaykumar9597 at gmail.com
> >     <mailto:vijaykumar9597 at gmail.com>>>>
> >     >     wrote:
> >     >     >     On Wed, Jul 24, 2019 at 7:03 PM Nils Hölscher
> >     >     <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
> >     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>
> >     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>> wrote:
> >     >     >         On Wed, 24 Jul 2019 at 15:14, Vijay Kumar Banerjee
> >     <mailto:vijaykumar9597 at gmail.com>> <mailto:vijaykumar9597 at gmail.com
> >     <mailto:vijaykumar9597 at gmail.com>>>> wrote:
> >     >     >             On Wed, Jul 24, 2019 at 6:36 PM Nils Hölscher
> >     >     >                 Hi again,
> >     >     >             Hi Nils
> >     >     >                 I just decompiled my device tree and checked.
> >     >     >                 The probe code of the prcm driver is as
> follows:
> >     >     >                 static int
> >     >     >                 am335x_prcm_probe(device_t dev)
> >     >     >                     printk("am335x_prcm_probe\n");
> >     >     >                     if (!ofw_bus_status_okay(dev)){
> >     >     >                         printk("ofw_bus_status_not_okay\n");
> >     >     >                         return (ENXIO);
> >     >     >             Do you get the "ofw_bus_status_not_okay" print ?
> >     >     >         Yes. But I also see the other print. except the
> >     success one.
> >     >     >                     if (ofw_bus_is_compatible(dev,
> >     "ti,am3-prcm")) {
> >     >     >                         device_set_desc(dev, "AM335x Power
> >     and Clock
> >     >     >                 Management");
> >     >     >                         printk("PROBE SUCESSFULL\n");
> >     >     >                         return(BUS_PROBE_DEFAULT);
> >     >     >                     printk("ofw_bus incompatible\n");
> >     >     >                     return (ENXIO);
> >     >     >                 So it seems the prcm part in the device tree
> >     has to be
> >     >     >                 compatible to "ti,am3-prcm".
> >     >     >                 The thing is the decompiled device tree
> states
> >     >     just that:
> >     >     >                 prcm at 0 {
> >     >     >                                         compatible =
> >     >     >                 "ti,am3-prcm\0simple-bus";
> >     >     >             In my device tree, it runs successfully and the
> >     decompiled
> >     >     >             compatible looks like  :
> >     >     >                         prcm at 200000 {
> >     >     >                             compatible = "ti,am3-prcm";
> >     >     >                             reg = < 0x200000 0x4000 >;
> >     >     >                             linux,phandle = < 0x4a >;
> >     >     >                             phandle = < 0x4a >;
> >     >     >         OK, this is awkward, cause we both should have used
> >     the same
> >     >     >         sources.
> >     >     >     Have you checked that your source is from the tree
> >     matching the
> >     >     >     libBSD HEAD
> >     >     >     commit?
> >     >     >                                         reg = <0x00 0x2000>;
> >     >     >                                         #address-cells =
> <0x01>;
> >     >     >                                         #size-cells = <0x01>;
> >     >     >                                         ranges = <0x00 0x00
> >     0x2000>;
> >     >     >                                         phandle = <0x5a>;
> >     >     >                 Any ideas would help, cause I am currently
> >     not able to
> >     >     >                 understand this behaviour.
> >     >     >                 Also without this driver even the
> >     dev_usb_bbb driver
> >     >     >                 shouldn't work.
> >     >     >                 However it attaches because it doesn't check
> >     for the
> >     >     >                 clocks error code.
> >     >     >             I remember testing this a few days ago for my fb
> >     >     drivers and
> >     >     >             it was attaching alright,
> >     >     >             if I remember correctly. If changing the dtb
> >     doesn't work
> >     >     >             for you, I won't mind checking
> >     >     >             again, this will give me a hint for the display
> >     issue
> >     >     as well.
> >     >     >         I will keep you updated on this.
> >     >     >         Would you be so kind and send me your compiled
> >     device tree?
> >     >     >     Please find it attached in this mail.
> >     >     >     Note: I have removed the devel from the cc because the
> >     >     >     might be
> >     >     >     big for the list. Please continue the discussion in the
> >     >     mailing list
> >     >     >     and maybe note
> >     >     >     it somewhere that you already received the dtb from me in
> >     >     private mail.
> >     >     >     Regards,
> >     >     >     Vijay
> >     >     >                 Best,
> >     >     >                 Nils
> >     >     >                 On Wed, 24 Jul 2019 at 14:43, Nils Hölscher
> >     <mailto:nilhoel1 at gmail.com> <mailto:nilhoel1 at gmail.com
> >     >     >                     Hi,
> >     >     >                     I just found out that the prcm driver
> >     fails to
> >     >     probe
> >     >     >                     on the simplebus and therefore cannot
> apply
> >     >     itself.
> >     >     >                     Seems like I am back to checking dtb.
> >     >     >                     Best,
> >     >     >                     Nils
> >     >     >                     On Tue, 23 Jul 2019 at 14:26, Nils
> Hölscher
> wrote:
> >     >     >                         Hi,
> >     >     >                         After debugging with printk, didn't
> >     get the
> >     >     >                         module loading working as suggested
> by
> >     >     Sebastian.
> >     >     >                         I just found out that my PRU driver
> >     can't be
> >     >     >                         attached, cause the AM35xx clock
> >     driver isn't
> >     >     >                         loaded.
> >     >     >                         The driver can be found her:
> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c
> >     >     >                         Can anyone tell me how to load this
> >     driver and
> >     >     >                         obisouly before I initialize my BSD
> >     modules?
> >     >     >                         FYI: The code line that fails is
> >     this one,
> >     >     cause
> >     >     >                         the driver hasn't been initialized.
> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c#L854
> >     >     >                         Thanks,
> >     >     >                         Nils
>  _______________________________________________
> >     >     >                 devel mailing list
> >     >     >                 devel at rtems.org <mailto:devel at rtems.org>
> >     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> >     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
> >     >     > devel mailing list
> > devel mailing list
> > devel at rtems.org
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190807/59199795/attachment-0002.html>
