[PATCH] user: Improve bug report section
    Gedare Bloom
    gedare at rtems.org
    Thu Aug  8 16:06:32 UTC 2019
On Thu, Aug 8, 2019 at 1:02 AM Sebastian Huber
> On 06/08/2019 21:22, Joel Sherrill wrote:
> > FWIW the pages converted by the high school students during Google Code-in
> > to be in the SW Eng Guide were from Wiki pages which ultimately need to be
> > deleted. There needs to be a pass to compare Rest version against the Wiki
> > version and then delete the Wiki version. And anytime a Wiki document is
> > deleted,
> > it is very likely links on other pages (including rtems.org
> > <http://rtems.org> top) need to be changed.
> Should a converted page get removed or should its content be replaced
> with a redirect to the corresponding section in the manuals?
I think a template of some sort with a link to the manual entry. I
wouldn't try to make it an automatic redirect.
> This page contains some content which should also move to the user
> manual bug reporting section:
> https://devel.rtems.org/wiki/NewTicket
> Everything in
> https://devel.rtems.org/wiki/NewTicket#RequiredInformation
> and below.
