[PATCH] user/bsps: Fix typo in beagle
Thu Aug 8 21:35:16 UTC 2019
P.S. The link to "device-tree" section is not working.
On Thu, Aug 8, 2019 at 3:10 PM Gedare Bloom <gedare at rtems.org> wrote:
> Vijay's copyright should probably go in the start of the user's manual.
> On Thu, Aug 8, 2019 at 7:38 AM Joel Sherrill <joel at rtems.org> wrote:
> > Pushed.  Thanks.
> > I assume Gedare pinged you also about the objcopy :)
> > --joel
> > On Wed, Aug 7, 2019 at 5:12 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com> wrote:
> >>  user/bsps/arm/beagle.rst | 4 ++--
> >>  1 file changed, 2 insertions(+), 2 deletions(-)
> >> diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
> >> index fa7fa05..6c8796b 100644
> >> --- a/user/bsps/arm/beagle.rst
> >> +++ b/user/bsps/arm/beagle.rst
> >> @@ -26,8 +26,8 @@ To boot via uboot, the ELF must be converted to a U-Boot image like below:
> >>  .. code-block:: none
> >> -    arm-rtems5-objcopy hello.exe -O app.bin
> >> -    gzip 9 app.bin
> >> +    arm-rtems5-objcopy hello.exe -O binary app.bin
> >> +    gzip -9 app.bin
> >>      mkimage -A arm -O linux -T kernel -a 0x80000000 -e 0x80000000 -n RTEMS -d app.bin.gz rtems-app.img
> >>  Getting the Device Tree Blob
> >> 2.20.1
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
