GSoC PRU: AM35xx Clock driver
    Christian Mauderer
    list at c-mauderer.de
    Fri Aug  9 18:24:21 UTC 2019
Hello Nils,
sorry, I missed the patch on the mailing list.
Best regards
Christian
On 09/08/2019 20:07, Nils Hölscher wrote:
> Hi Christian,
> I want to thank you again, since you actually helped me a lot with this
> problem.
> But I already patched this problem, didn't I.
> Thanks,
> Nils
> Christian Mauderer <list at c-mauderer.de <mailto:list at c-mauderer.de>>
> schrieb am Fr., 9. Aug. 2019, 19:50:
>     Hello Nils,
>     great that you found your problem. It sounds like it is a general bug in
>     libbsd. What did you change and do you have a patch that would fix this?
>     Best regards
>     Christian
>     On 09/08/2019 15:42, Nils Hölscher wrote:
>     > Hi,
>     > I was able to resolve the problem.
>     > The reason that all the devices attached in the last pass and not
>     in the
>     > pass they were assigned, was the nexus bus being loaded as a standard
>     > driver Module.
>     > So the pass level of nexus bus was BUS_PASS_DEFAULT and all devices
>     > depend on nexus bus.
>     > Please see my Output attached.
>     > The prints print the linkpass list and the link list and some
>     other parts.
>     > At the bottom you can also see the pruss device in /dev.
>     > I will create a patch right away.
>     > Best,
>     > Nils
>     > On Wed, 7 Aug 2019 at 11:35, Nils Hölscher <nilhoel1 at gmail.com
>     <mailto:nilhoel1 at gmail.com>
>     > <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>> wrote:
>     >     Hi,
>     >     I was able to confirm that the current libBSD implementation scans
>     >     the fdt only once.
>      caller: https://github.com/RTEMS/rtems-libbsd/blob/f60ac53420f36060c13104f9a555f39ebc619b09/freebsd/sys/kern/subr_bus.c#L5100
>      callee: https://github.com/RTEMS/rtems-libbsd/blob/f60ac53420f36060c13104f9a555f39ebc619b09/freebsd/sys/kern/subr_bus.c#L969
>     >     The function BUS_NEW_PASS initialises a pass over fdt with all
>     >     drivers of the current pass level.
>     >     However after trying to add another pass, I realized that all
>     >     drivers are on the DEFAULT_PASS_LEVEL (max_integer).
>     >     Best and thanks,
>     >     Nils
>     >     On Thu, 1 Aug 2019 at 11:36, Christian Mauderer
>     >     <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>     >         Hello Nils,
>     >         On 31/07/2019 14:54, Nils Hölscher wrote:
>     >         > Hi,
>     >         > I have been reading into the FreeBSD init code the past
>     few days,
>     >         > especially for Driver_MODULE.
>     >         > Expect an Blog entry today or tomorrow.
>     >         > Because I don't have JTAG, it took me quite some time.
>     >         I would always suggest a JTAG or some other kind of
>     debugger for
>     >         embedded work. In a professional work environment you
>     should try to
>     >         convince your boss that it is a big time saver (which is
>     >         definitively
>     >         true) so that even an expensive debugger is a good investment
>     >         By the way: For understanding the initialization sequence you
>     >         might can
>     >         use a simulator too. For the basic sequence you can
>     simulate any
>     >         BSP and
>     >         are not bound to BBB.
>     >         > With BUS_DEBUG enabled I saw that the problem is indeed that
>     >         the pruss
>     >         > unit is discovered too early.
>     >         > Is this device tree related?
>     >         It's possible that this is a difference in how modules are
>     >         handled. I'm
>     >         not sure whether FreeBSD loads EARLY_MODULES dynamically at
>     >         another time
>     >         during boot while we link everything in from the start. If
>     that
>     >         is true,
>     >         the mechanism might not work the same like in FreeBSD. You
>     might
>     >         want to
>     >         have a look at that.
>     >         > I am not sure, cause the overlay I am using is from the BSD
>     >         community.
>     >         > I added my output to a gist and link to the interesting
>     parts.
>     >         > The EARLY_DRIVER_MODULE's are indeed loaded first.
>      https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L125
>     >         > Nexus bus attaches and the driver goes over every discovered
>     >         device and
>     >         > tries to attach the drivers in order:
>      https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L326
>     >         > ofwbus gets discovered:
>      https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L747
>     >         > Here the ti_pruss device gets discovered too early in
>     the fdt
>     >         and fails:
>      https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L904
>     >         > I still haven't found the loop running over fdt.
>     >         Don't have a test environment ready so this is just from a
>     quick
>     >         glance
>     >         at the code. I might have missed something:
>     >         simplebus_attach adds all child nodes from the tree to the
>     bus:
>      https://git.rtems.org/rtems-libbsd/tree/freebsd/sys/dev/fdt/simplebus.c#n157
>     >         The bus_generic_attach then loops over all children and
>     calls their
>     >         probe and attach functions:
>      https://git.rtems.org/rtems-libbsd/tree/freebsd/sys/kern/subr_bus.c#n3768
>     >         Best regards
>     >         Christian
>     >         > And it seems that the device tree only gets one iteration.
>     >         > But the BSD man page for EARLY_DRIVER_MODULE states that
>     every
>     >         > PASS_LEVEL has an iteration.
>     >         >      The *EARLY*_*DRIVER*_*MODULE*() macro allows a
>     driver to
>     >         be registered for a
>     >         >      specific pass level.  The boot time probe and attach
>     >         process makes       *_multi- _ _ple passes over the device
>     >         tree_*.  Certain critical        drivers that provide
>     >         >      basic services needed by other devices are       attach
>     >         during earlier passes.
>     >         >      Most drivers are attached in a final general pass.
>     >         A driver that
>     >         >      attaches during an       early pass must register for a
>     >         specific pass level
>     >         >      (BUS_PASS_*) via the /pass/ argument.  Once a driver
>     >          is registered it is
>     >         >      available to attach to devices for       all subsequent
>     >         passes."
>      https://www.freebsd.org/cgi/man.cgi?query=DRIVER_MODULE&sektion=9&apropos=0&manpath=FreeBSD+12.0-RELEASE+and+Ports
>     >         > Best,
>     >         > Nils
>     >         > On Sun, 28 Jul 2019 at 11:34, Christian Mauderer
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
>     >         > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>     >         >     On 28/07/2019 11:22, Nils Hölscher wrote:
>     >         >     > On Sat, 27 Jul 2019 at 14:34, Christian Mauderer
>     >         >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     >         >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>     >         >     >     On 24/07/2019 16:53, Nils Hölscher wrote:
>     >         >     >     > Hi,
>     >         >     >     > @Vijay Kumar Banerjee
>     >         <mailto:vijaykumar9597 at gmail.com
>     <mailto:vijaykumar9597 at gmail.com> <mailto:vijaykumar9597 at gmail.com
>     <mailto:vijaykumar9597 at gmail.com>>
>     <mailto:vijaykumar9597 at gmail.com>>>
>     >         >     >     <mailto:vijaykumar9597 at gmail.com
>     <mailto:vijaykumar9597 at gmail.com>>>>>  thanks for the
>     >         >     >     > dtb file.
>     >         >     >     > I build my file from FreeBSD master.
>     >         >     >     > Prcm attaches now but still after the pruss
>     driver...:
>     >         >     >     > nexus0: <RTEMS Nexus device>
>     >         >     >     > ofwbus0: <Open Firmware Device Tree> on nexus0
>     >         >     >     > simplebus0: <Flattened device tree simple
>     bus> on
>     >         ofwbus0
>     >         >     >     > *ti_pruss0: <TI Programmable Realtime Unit
>     >         Subsystem> mem
>     >         >     >     > 0x4a300000-0x4a37ffff irq
>     20,21,22,23,24,25,26,27
>     >         on simplebus0
>     >         >     >     > ti_pruss0: could not enable PRUSS clock
>     >         >     >     > device_attach: ti_pruss0 attach returned 6*
>     >         >     >     > simplebus1: <Flattened device tree simple
>     bus> on
>     >         simplebus0*
>     >         >     >     > am335x_prcm0: <AM335x Power and Clock
>     Management> mem
>     >         >     >     0x200000-0x203fff
>     >         >     >     > on simplebus1*
>     >         >     >     Hello Nils,
>     >         >     >     I'm not sure about the order. But what seems a
>     >         little bit odd
>     >         >     is that
>     >         >     >     the prcm0 is found in simplebus0 while
>     am335x_prcm0
>     >         is found on
>     >         >     >     simplebus1. Maybe it's worth investigating how
>     that
>     >         order is
>     >         >     created and
>     >         >     >     how it is handled in RTEMS.
>     >         >     > Thanks for the information.
>     >         >     > I think the way rtems initializes the bsd modules
>     >         differs from the way
>     >         >     > described in the libbsd manuel.
>     >         >     > But I will have to investigate that further.
>     >         >     I'm not 100% sure but as far as I know the _modules_
>     should be
>     >         >     initialized in the given order (early module prior to
>     >         normal module).
>     >         >     But the device detection is something different. I think
>     >         there is some
>     >         >     loop in simplebus that loops over the devices and asks
>     >         every driver
>     >         >     whether it wants to handle that device. If yes the
>     driver
>     >         can have it.
>     >         >     If no the device is unhandled.
>     >         >     For a module that is mentioned in the device tree I
>     would
>     >         expect that
>     >         >     the order in the device tree binary is the one used. For
>     >         devices outside
>     >         >     of the device tree most likely some link order is used.
>     >         >     If you have a debugger you might want to search for the
>     >         loops and take a
>     >         >     look at when they are called and how they add devices. I
>     >         don't think
>     >         >     that there are that many early modules yet that
>     would use
>     >         the device
>     >         >     tree. So it's possible that there is some call missing
>     >         that would parse
>     >         >     the device tree for early modules.
>     >         >     >     A general note regarding the prcm module: In
>     RTEMS most
>     >         >     (non-libbsd)
>     >         >     >     drivers enable their power and clocks themself.
>     >         Please make
>     >         >     sure that
>     >         >     >     the FreeBSD prcm doesn't interfere with that.
>     >         Otherwise you
>     >         >     might get
>     >         >     >     odd effects.
>     >         >     > Thanks I will keep that in mind.
>     >         >     > Best,
>     >         >     > Nils
>     >         >     >     Best regards
>     >         >     >     Christian
>     >         >     >     > *====am335x_prcm_attach====*
>     >         >     >     > Is there anything else I can do besides using
>     >         MODULE_DEPENDENCY,
>     >         >     >     which I
>     >         >     >     > already use.
>     >         >     >     > The prcm module is also a EARLY_DRIVER_MODULE.
>     >         >     >     > Best,
>     >         >     >     > Nils
>     >         >     >     > On Wed, 24 Jul 2019 at 16:04, Vijay Kumar
>     Banerjee
>     >         >     >     > <vijaykumar9597 at gmail.com
>     <mailto:vijaykumar9597 at gmail.com>>>>>>
>     >         >     >     wrote:
>     >         >     >     >     On Wed, Jul 24, 2019 at 7:03 PM Nils
>     Hölscher
>     >         >     >     <nilhoel1 at gmail.com
>     <mailto:nilhoel1 at gmail.com> <mailto:nilhoel1 at gmail.com
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>
>     >         >     >     >     <mailto:nilhoel1 at gmail.com
>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>>> wrote:
>     >         >     >     >         On Wed, 24 Jul 2019 at 15:14, Vijay
>     Kumar
>     >         Banerjee
>     <mailto:vijaykumar9597 at gmail.com>>>>>> wrote:
>     >         >     >     >             On Wed, Jul 24, 2019 at 6:36 PM Nils
>     >         Hölscher
>     >         >     >     >             <nilhoel1 at gmail.com
>     >         >     >     >                 Hi again,
>     >         >     >     >             Hi Nils
>     >         >     >     >                 I just decompiled my device tree
>     >         and checked.
>     >         >     >     >                 The probe code of the prcm
>     driver
>     >         is as follows:
>     >         >     >     >                 static int
>     >         >     >     >                 am335x_prcm_probe(device_t dev)
>          printk("am335x_prcm_probe\n");
>     >         >     >     >                     if
>     (!ofw_bus_status_okay(dev)){
>     >                  printk("ofw_bus_status_not_okay\n");
>     >         >     >     >                         return (ENXIO);
>     >         >     >     >             Do you get the
>     >         "ofw_bus_status_not_okay" print ?
>     >         >     >     >         Yes. But I also see the other print.
>     >         except the
>     >         >     success one.
>     >         >     >     >                     if
>     (ofw_bus_is_compatible(dev,
>     >         >     "ti,am3-prcm")) {
>     >         >     >     >                         device_set_desc(dev,
>     >         "AM335x Power
>     >         >     and Clock
>     >         >     >     >                 Management");
>     >         >     >     >                         printk("PROBE
>     SUCESSFULL\n");
>              return(BUS_PROBE_DEFAULT);
>     >         >     >     >                     printk("ofw_bus
>     incompatible\n");
>     >         >     >     >                 So it seems the prcm part in the
>     >         device tree
>     >         >     has to be
>     >         >     >     >                 compatible to "ti,am3-prcm".
>     >         >     >     >                 The thing is the decompiled
>     device
>     >         tree states
>     >         >     >     just that:
>     >         >     >     >                 prcm at 0 {
>                              compatible =
>     >         >     >     >                 "ti,am3-prcm\0simple-bus";
>     >         >     >     >             In my device tree, it runs
>     >         successfully and the
>     >         >     decompiled
>     >         >     >     >             compatible looks like  :
>     >         >     >     >                         prcm at 200000 {
>     >         >     >     >                             compatible =
>     >         "ti,am3-prcm";
>     >         >     >     >                             reg = < 0x200000
>     0x4000 >;
>     >         >     >     >                             linux,phandle =
>     < 0x4a >;
>     >         >     >     >                             phandle = < 0x4a >;
>     >         >     >     >         OK, this is awkward, cause we both
>     should
>     >         have used
>     >         >     the same
>     >         >     >     >         sources.
>     >         >     >     >     Have you checked that your source is
>     from the tree
>     >         >     matching the
>     >         >     >     >     libBSD HEAD
>     >         >     >     >     commit?
>     >         >     >     >                                         reg =
>     >         <0x00 0x2000>;
>     >                                  #address-cells = <0x01>;
>     >                                  #size-cells = <0x01>;
>     >         >     >     >                                         ranges =
>     >         <0x00 0x00
>     >         >     0x2000>;
>                              phandle =
>     >         <0x5a>;
>     >         >     >     >                 Any ideas would help, cause I am
>     >         currently
>     >         >     not able to
>     >         >     >     >                 understand this behaviour.
>     >         >     >     >                 Also without this driver
>     even the
>     >         >     dev_usb_bbb driver
>     >         >     >     >                 shouldn't work.
>     >         >     >     >                 However it attaches because it
>     >         doesn't check
>     >         >     for the
>     >         >     >     >                 clocks error code.
>     >         >     >     >             I remember testing this a few
>     days ago
>     >         for my fb
>     >         >     >     drivers and
>     >         >     >     >             it was attaching alright,
>     >         >     >     >             if I remember correctly. If changing
>     >         the dtb
>     >         >     doesn't work
>     >         >     >     >             for you, I won't mind checking
>     >         >     >     >             again, this will give me a hint for
>     >         the display
>     >         >     issue
>     >         >     >     as well.
>     >         >     >     >         I will keep you updated on this.
>     >         >     >     >         Would you be so kind and send me
>     your compiled
>     >         >     device tree?
>     >         >     >     >     Please find it attached in this mail.
>     >         >     >     >     Note: I have removed the devel from the cc
>     >         because the
>     >         >     attachment
>     >         >     >     >     might be
>     >         >     >     >     big for the list. Please continue the
>     >         discussion in the
>     >         >     >     mailing list
>     >         >     >     >     and maybe note
>     >         >     >     >     it somewhere that you already received
>     the dtb
>     >         from me in
>     >         >     >     private mail.
>     >         >     >     >     Regards,
>     >         >     >     >     Vijay
>     >         >     >     >                 Best,
>     >         >     >     >                 Nils
>     14:43, Nils
>     >         Hölscher
>     >         >     >     >                     Hi,
>     >         >     >     >                     I just found out that
>     the prcm
>     >         driver
>     >         >     fails to
>     >         >     >     probe
>     >         >     >     >                     on the simplebus and
>     therefore
>     >         cannot apply
>     >         >     >     itself.
>     >         >     >     >                     Seems like I am back to
>     >         checking dtb.
>     >         >     >     >                     Best,
>     >         >     >     >                     Nils
>     >         >     >     >                     On Tue, 23 Jul 2019 at
>     14:26,
>     >         Nils Hölscher
>     >         >     >     >                         Hi,
>     >         >     >     >                         After debugging with
>     >         printk, didn't
>     >         >     get the
>     >         >     >     >                         module loading
>     working as
>     >         suggested by
>     >         >     >     Sebastian.
>     >         >     >     >                         I just found out that my
>     >         PRU driver
>     >         >     can't be
>     >         >     >     >                         attached, cause the
>     AM35xx
>     >         clock
>     >         >     driver isn't
>     >         >     >     >                         loaded.
>     >         >     >     >                         The driver can be
>     found her:
>         https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c
>     >         >     >     >                         Can anyone tell me
>     how to
>     >         load this
>     >         >     driver and
>     >         >     >     >                         obisouly before I
>     >         initialize my BSD
>     >         >     modules?
>     >         >     >     >                         FYI: The code line that
>     >         fails is
>     >         >     this one,
>     >         >     >     cause
>     >         >     >     >                         the driver hasn't been
>     >         initialized.
>         https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c#L854
>     >         >     >     >                         Thanks,
>     >         >     >     >                         Nils
>     >          _______________________________________________
>     >         >     >     >                 devel mailing list
>     >         >     >     >                 devel at rtems.org
>     <mailto:devel at rtems.org>
>     >         <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>     >         <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>     >         >     <mailto:devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>
>     >         >     >     <mailto:devel at rtems.org
>     <mailto:devel at rtems.org> <mailto:devel at rtems.org
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>>
>     >          http://lists.rtems.org/mailman/listinfo/devel
>     >         >     >     > _______________________________________________
>     >         >     >     > devel at rtems.org <mailto:devel at rtems.org>
>     >         >     >     > http://lists.rtems.org/mailman/listinfo/devel
>     >         embedded brains GmbH
>     >         Herr Christian Mauderer
>     >         Dornierstr. 4
>     >         D-82178 Puchheim
>     >         Germany
>     >         email: christian.mauderer at embedded-brains.de
>     >         Phone: +49-89-18 94 741 - 18
>     >         Fax:   +49-89-18 94 741 - 08
>     >         PGP: Public key available on request.
>     >         Diese Nachricht ist keine geschäftliche Mitteilung im
>     Sinne des
>     >         EHUG.
