[PATCH] rtems/rtems-kernel-nexus.c: LibBSD init now uses all pass levels.
Nils Hölscher nilhoel1 at gmail.com
Sat Aug 10 08:31:59 UTC 2019
Hi,
BUS_PASS_BUS + BUS_PASS_ORDER_FIRST equals BUS_PASS_BUS, cause
BUS_PASS_ORDER_FIRST is defined 0.
So this is just cosmetical but you are right I should add this.
Best,
Nils
On Fri, 9 Aug 2019 at 20:33, Christian Mauderer <list at c-mauderer.de> wrote:
> Hello Nils,
> thanks for the patch. It sounds like we will get a behaviour that is
> more similar to FreeBSD one with it. But it has the potential to have a
> big influence on existing BSPs so it would be good to have some more
> feedback for it before merging it.
> On 09/08/2019 15:53, Nils Hölscher wrote:
> > I observed all Modules loading in the last fdt pass.
> > The reason was, nexus bus loading with BUS_PASS_DEFAULT.
> >  rtemsbsd/rtems/rtems-kernel-nexus.c | 2 +-
> >  1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/rtemsbsd/rtems/rtems-kernel-nexus.c
> b/rtemsbsd/rtems/rtems-kernel-nexus.c
> > index 15b0f84d..197f23f6 100644
> > --- a/rtemsbsd/rtems/rtems-kernel-nexus.c
> > +++ b/rtemsbsd/rtems/rtems-kernel-nexus.c
> > @@ -394,4 +394,4 @@ static driver_t nexus_driver = {
> >  static devclass_t nexus_devclass;
> > -DRIVER_MODULE(nexus, root, nexus_driver, nexus_devclass, 0, 0);
> > +EARLY_DRIVER_MODULE_ORDERED(nexus, root, nexus_driver, nexus_devclass,
> 0, 0, SI_ORDER_FIRST, BUS_PASS_BUS);
> In freeBSD some of the nexus devices have a "BUS_PASS_BUS +
> BUS_PASS_ORDER_xxx". Did you have a reason to not add a BUS_PASS_ORDER?
> For example:
> freebsd-org/sys/riscv/riscv/nexus.c:
> EARLY_DRIVER_MODULE(nexus_fdt, root, nexus_fdt_driver,
> nexus_fdt_devclass, 0, 0, BUS_PASS_BUS + BUS_PASS_ORDER_FIRST);
> freebsd-org/sys/arm64/arm64/nexus.c:
> freebsd-org/sys/mips/mips/nexus.c:
> EARLY_DRIVER_MODULE(nexus, root, nexus_driver, nexus_devclass, 0, 0,
> BUS_PASS_BUS + BUS_PASS_ORDER_EARLY);
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190810/13a8603e/attachment-0002.html>
