rtems-tester with griscv
Jiri Gaisler
jiri at gaisler.se
Mon Aug 12 21:23:02 UTC 2019
You should probably use --rtems-bsp=griscv-sis . The griscv bsp uses the (now deleted) built-in sis in gdb...
I am preparing a patch to purge the stale tester bsps ...
Jiri.
On 8/12/19 8:22 PM, Joel Sherrill wrote:
> Hi
> Running riscv-rtems5-sis by hand, hello.exe runs. But when I try it with rtems-tester, nothign passes and the tester hangs. I killed python after about 30 minutes of CPU time.
> + /home/joel/rtems-work/rtems-tools//tester/rtems-test --rtems-tools=/home/joel/rtems-work/tools/5 --rtems-bsp=griscv --log=run.log .
> RTEMS Testing - Tester, 5 (30a5cd65cc54)
> [ 1/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: base_sp.exe
> [ 8/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: nsecs.exe
> [ 2/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: capture.exe
> [ 6/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: hello.exe
> [ 5/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: fileio.exe
> [ 4/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: cxx_iostream.exe
> [ 3/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: cdtest.exe
> [10/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: ticker.exe
> [ 7/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: minimum.exe
> [ 9/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: paranoia.exe
> [11/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv: unlimited.exe
> ^Cabort: user terminated
> Any ideas?
> Thanks.
> --joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190812/3b4ac926/attachment-0002.html>
