Chapter/section numbers in document internal references
Tue Aug 13 20:14:09 UTC 2019
Ok that seems good to me.
On Tue, Aug 13, 2019, 11:30 AM Sebastian Huber <
> ----- Am 13. Aug 2019 um 19:05 schrieb Gedare Bloom gedare at gwmail.gwu.edu:
> > If you can make different rules for HTML than PDF, the Chapter part could
> > be omitted in HTML since one will expect the link to work. PDF should be
> > usable even without links.
> > I'd change it to use for example "Chapter 3.3" format of
> Ch#.Sec#.subsec#.
> > this is more like a textbook reference then.
> I am in favour of the standard Sphinx latex_show_pagerefs option:
> https://lists.rtems.org/pipermail/devel/2019-August/027308.html
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190813/07cf36bd/attachment-0002.html>
