Mounting/Accessing SD-Card on BBB
Christian Mauderer
list at c-mauderer.de
Fri Aug 16 12:03:27 UTC 2019
Hello Nils,
you are right that system freezes are not a wanted behaviour. But
hot-plugging a disk isn't that common in embedded systems (except maybe
for USB drives). It's a case that isn't tested that often. So most
likely no one noticed that bug. I wouldn't see it critical as long as I
don't have a project where I need that (either hobby or funded).
Is this a blocking problem for your project? If not you might want to
fill a bug report for this. But I suspect that no one will work on that
too fast as long as there is no urgent necessity.
Note that if it would have been a FAT bug the situation would have been
quite different. FAT bugs are bad for all targets and for quite some
funded projects too. So I would have tried to fix that as soon as possible.
Best regards
Christian
On 16/08/2019 12:08, Nils Hölscher wrote:
> Ok.
> But back to the bug.
> The behaviour I described should be reproducible by removing SD-Card
> after it was mounted.
> And then the System should freeze when open is called on some file on
> SD-Card.
> System freezes can't be wanted behaviour.
> Best,
> Nils
> On Fri, 16 Aug 2019 at 11:40, Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
> PS: If neither the SD nor the eMMC has a bootable image your BBB falls
> back to serial and then USB boot anyway. So no need to change any
> boot pins.
> On 16/08/2019 11:38, Christian Mauderer wrote:
> > Hello Nils,
> > if the U-Boot doesn't start from eMMC any more it won't be easy.
> > Theoretically it is possible to boot via serial. See for example
> http://linuxkernel51.blogspot.com/2015/08/booting-beagle-bone-black-over-uart.html
> > With that you could load an U-Boot (via X-Modem) that could start a
> > system from USB (image from Beagle home page maybe could work if
> it can
> > boot from USB) that could re-write the eMMC. Most likely it would
> need a
> > few hours to a day to figure out the details. So you should
> definitively
> > order a replacement as a backup solution.
> > Best regards
> > Christian
> > On 16/08/2019 11:13, Nils Hölscher wrote:
> >> Hi Christin,
> >> Thanks for the hint.
> >> But how can I alter the U- Boot on eMMC?
> >> Problem is I have a Linux version with an U-Boot that disables
> emmc on
> >> the emmc...
> >> And I guess I cant flash emmc without SD.
> >> Best,
> >> Nils
> >> On Fri, 16 Aug 2019 at 11:03, Christian Mauderer
> <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >> On 16/08/2019 10:55, Nils Hölscher wrote:
> >> > Hi,
> >> > It seems the problem was hardware related.
> >> > My SD-Card connector just died.
> >> > I hope I can get a new BBB oin a timely manner.
> >> > Best,
> >> > Nils
> >> Hello Nils,
> >> thanks for the information. That's annoying. Good luck finding a
> >> replacement.
> >> For a quick workaround: I haven't tried that yet but if your
> on-board
> >> eMMC is still intact, you might can use that U-Boot to boot
> from USB.
> >> Best regards
> >> Christian
> >> > On Fri, 16 Aug 2019 at 10:48, Christian Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> >> > Hello Nils,
> >> > thanks for the file list. I can't reproduce your
> problem with it.
> >> > On 16/08/2019 10:01, Nils Hölscher wrote:
> >> > > Hi,
> >> > > Short update.
> >> > > It seems the device only hangs while I am connected
> with the
> >> debugger.
> >> > Is that true for the original file system tree? You are
> >> debugging via
> >> > Ethernet, right? In that case I would lean more toward a
> >> problem with
> >> > the debugger support than the file system. Do you have
> enough file
> >> > descriptors configured?
> >> > Best regards
> >> > Christian
> >> > > looks like a Heisenberg bug.
> >> > > Best,
> >> > > Nils
> >> > > On Fri, 16 Aug 2019 at 09:50, Nils Hölscher
> >> <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
> <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>
> <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>
> <mailto:nilhoel1 at gmail.com> <mailto:nilhoel1 at gmail.com
> <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>>> wrote:
> >> > > On Thu, 15 Aug 2019 at 19:51, Christian Mauderer
> <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
> >> > > Hello Nils,
> >> > > maybe another bug in our FAT file system...
> >> > > Please do three things:
> >> > > 1. Create an image of your current card (with
> dd or
> >> a similar
> >> > > tool). FAT
> >> > > bugs are sometimes hard to reproduce but it's
> really
> >> > urgent that
> >> > > we fix
> >> > > them. So maybe I'll ask for that image later.
> >> > > I did that.
> >> > > Let me know if you need the image.
> >> > > 2. Create a complete list of the files on
> your card (for
> >> > example the
> >> > > Linux `tree -h` command), post it here and
> tell me
> >> what you
> >> > > tried to open.
> >> > > ├── [ 50K] am335x-boneblack.dtb
> >> > > ├── [ 49K] am335x-boneblack+pruss.dtb
> >> > > ├── [ 883] AM335X-PRU-UIO-00A0.dtbo
> >> > > ├── [ 649] AM335X-PRU-UIO-BSD-00A0.dtbo
> >> > > ├── [162K] Linux-with-UIO.dtb
> >> > > ├── [ 44] loob.bin
> >> > > ├── [108K] MLO
> >> > > ├── [2.1M] pru.exe.img
> >> > > ├── [ 12] test.bin
> >> > > ├── [471K] u-boot.img
> >> > > ├── [ 390] uEnvLinuxfdt.txt
> >> > > └── [ 560] uEnv.txt
> >> > > 3. Try another name / folder for the file
> you wanted to
> >> > open.\
> >> > > I moved the file in another folder and renamed it.
> >> > > It now works but I got en error, I am currently
> >> investigating if
> >> > > this is on the pru driver side or not.
> >> > > The tree while doing this was:
> >> > > ├── [ 44] loob.bin
> >> > > ├── [108K] MLO
> >> > > ├── [2.0K] test
> >> > > │ └── [ 12] test2.bin
> >> > > ├── [ 12] test2.bin
> >> > > └── [ 560] uEnv.txt
> >> > > Thanks,
> >> > > Nils
> >> > > Best regards
> >> > > Christian
> >> > > On 15/08/2019 19:32, Nils Hölscher wrote:
> >> > > > Hi Christian,
> >> > > > The commands ls and cat work.
> >> > > > I just tested them, this seems kinda awkward.
> >> > > > Best,
> >> > > > Nils
> >> > > > On Thu, 15 Aug 2019 at 19:27, Christian
> Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
> >> > > > Hello Nils,
> >> > > > does some other access to the file system
> >> work? Like
> >> > a ls
> >> > > on the console
> >> > > > or creating a file. Can you do a `cat`
> on some
> >> text file
> >> > > on the file
> >> > > > system? If not: Does it work for a file
> in the
> >> root file
> >> > > system (should
> >> > > > be a IMFS)?
> >> > > > Best regards
> >> > > > Christian
> >> > > > On 15/08/2019 15:54, Nils Hölscher wrote:
> >> > > > > Hi,
> >> > > > > I when my app wants to open a file on
> the SD
> >> card
> >> > > dev=mmcsd-0-0 rtems
> >> > > > > freezes.
> >> > > > > Exact call is:
> >> > > > > fd = open(file, O_RDONLY);
> >> > > > > With file being the pru binary I want
> to upload.
> >> > > > > Thanks,
> >> > > > > Nils
> >> > > > > On Tue, 13 Aug 2019 at 17:56,
> Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>
> <mailto:christian.mauderer at embedded-brains.de>>
> <mailto:christian.mauderer at embedded-brains.de>>>
> <mailto:christian.mauderer at embedded-brains.de>>>>
> <mailto:christian.mauderer at embedded-brains.de>>>>>
> <mailto:christian.mauderer at embedded-brains.de>>>>>>> wrote:
> >> > > > > Hello Nils,
> >> > > > > a third possibility: You could
> start a
> >> FTP server
> >> > > and push the
> >> > > > file
> >> > > > > via network.
> >> > > > > Best regards
> >> > > > > Christian
> >> > > > > Am Dienstag, 13. August 2019
> schrieb Nils
> >> > Hölscher:
> >> > > > > > Hi,
> >> > > > > > Thanks for the input I will try
> the SD
> >> card
> >> > first.
> >> > > > > > That way I won't have to alter the
> >> code when I
> >> > > want to run other
> >> > > > > stuff on the pru.
> >> > > > > > Best,
> >> > > > > > Nils
> >> > > > > > On Tue, 13 Aug 2019 at 17:32,
> Gedare Bloom
> >> > > <gedare at rtems.org <mailto:gedare at rtems.org>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>
> <mailto:gedare at rtems.org> <mailto:gedare at rtems.org
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>>> wrote:
> >> > > > > > You can also build the PRU
> image into
> >> the RTEMS
> >> > > binary. See
> >> > > > > > examples-v2.git/file_io/crc/init.c
> >> > > > > > On Tue, Aug 13, 2019 at 8:46 AM
> Christian
> >> > Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
> >> > > > > > > Hello Nils,
> >> > > > > > > that's a bit odd. I attached
> an expected
> >> > output
> >> > > below.
> >> > > > Some guesses:
> >> > > > > > > - Did you add FAT file system
> to your
> >> > application?
> >> > > > > > > - Is there some odd formatting on
> >> the SD?
> >> > > Normally at
> >> > > > least the FAT
> >> > > > > > > partition used by U-Boot
> should be
> >> visible.
> >> > > > > > > - Is your BDBUF configuration OK?
> >> > > > > > > - Do you have enough file
> descriptors?
> >> > > > > > > Beneath that: If you only need
> >> something where
> >> > > you can put
> >> > > > some
> >> > > > > files,
> >> > > > > > > you can try to connect a USB
> stick
> >> instead.
> >> > > Maybe that
> >> > > > works better.
> >> > > > > > > Best regards
> >> > > > > > > Christian
> >> > > > > > > media listener: event = DISK
> ATTACH,
> >> state =
> >> > > INQUIRY, src
> >> > > > = mmcsd
> ATTACH,
> >> state =
> >> > > SUCCESS, src =
> >> > > > > mmcsd, dest
> >> > > > > > > = /dev/mmcsd-0
> MOUNT, state =
> >> > INQUIRY,
> >> > > src =
> >> > > > /dev/mmcsd-0
> >> > > > > > > mmcsd0: 4GB <SDHC TO 15.15 SN
> >> 000002F6 MFG
> >> > > 02/2017 by 25
> >> > > > DY> at mmc0
> >> > > > > > > 24.0MHz/4bit/65535-block
> MOUNT, state =
> >> > FAILED, src =
> >> > > > /dev/mmcsd-0
> >> > > > > > > media listener: event = PARTITION
> >> INQUIRY,
> >> > state =
> >> > > > INQUIRY, src =
> >> > > > > > > /dev/mmcsd-0
> >> INQUIRY,
> >> > state =
> >> > > > SUCCESS, src =
> >> > > > > > > /dev/mmcsd-0
> >> ATTACH,
> >> > state
> >> > > = INQUIRY,
> >> > > > src =
> >> > > > > > > /dev/mmcsd-0
> >> ATTACH,
> >> > state
> >> > > = SUCCESS,
> >> > > > src =
> >> > > > > > > /dev/mmcsd-0, dest =
> /dev/mmcsd-0-0
> MOUNT, state =
> >> > INQUIRY,
> >> > > src =
> >> > > > /dev/mmcsd-0-0
> MOUNT, state =
> >> > SUCCESS,
> >> > > src =
> >> > > > > /dev/mmcsd-0-0,
> >> > > > > > > dest = /media/mmcsd-0-0
> ATTACH,
> >> state =
> >> > > INQUIRY, src
> >> > > > = mmcsd
> ATTACH,
> >> state =
> >> > > SUCCESS, src =
> >> > > > > mmcsd, dest
> >> > > > > > > = /dev/mmcsd-1
> MOUNT, state =
> >> > INQUIRY,
> >> > > src =
> >> > > > /dev/mmcsd-1
> >> > > > > > > mmcsd1: 4GB <MMCHC MMC04G 5.8 SN
> >> 160D224B MFG
> >> > > 09/2014 by 112
> >> > > > > 0x0000> at
> >> > > > > > > mmc1 48.0MHz/8bit/65535-block
> MOUNT, state =
> >> > FAILED, src =
> >> > > > /dev/mmcsd-1
> >> INQUIRY,
> >> > state =
> >> > > > INQUIRY, src =
> >> > > > > > > /dev/mmcsd-1
> >> INQUIRY,
> >> > state
> >> > > = FAILED,
> >> > > > src =
> >> > > > > > > /dev/mmcsd-1
> ATTACH,
> >> state =
> >> > > INQUIRY, src =
> >> > > > > mmcsd1boot
> >> > > > > > > mmcsd1boot0: 2MB partion 1 at
> mmcsd1
> >> > > > > > > mmcsd1boot1: 2MB partion 2 at
> mmcsd1
> >> > > > > > > mmcsd1rpmb: 131kB partion 3
> at mmcsd1
> >> > > > > > > On 13/08/2019 13:30, Nils
> Hölscher
> >> wrote:
> >> > > > > > > > Hi,
> >> > > > > > > > Thanks for the help.
> >> > > > > > > > I tried to use your code, but I
> >> always get
> >> > > "ERROR: SD
> >> > > > could not be
> >> > > > > > > > mounted after timeout".
> >> > > > > > > > Even after raising the
> waiting time.
> >> > > > > > > > The sources I use start here:
> https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
> >> > > > > > > > And my uart output is:
> >> > > > > > > > waiting for SD...
> >> > > > > > > > usbus0: 480Mbps High Speed
> USB v2.0
> >> > > > > > > > usbus1: 480Mbps High Speed
> USB v2.0
> >> ATTACH, state =
> >> > > INQUIRY,
> >> > > > src = mmcsd
> >> ATTACH, state =
> >> > > SUCCESS, src =
> >> > > > > mmcsd, dest
> >> > > > > > > > = /dev/mmcsd-0
> MOUNT, state =
> >> > > INQUIRY, src =
> >> > > > /dev/mmcsd-0
> >> > > > > > > > ugen0.1: <Mentor Graphics
> OTG Root
> >> HUB>
> >> > at usbus0
> >> > > > > > > > ugen1.1: <Mentor Graphics
> OTG Root
> >> HUB>
> >> > at usbus1
> >> > > > > > > > uhub0: <Mentor Graphics OTG
> Root
> >> HUB, class
> >> > > 9/0, rev
> >> > > > > 2.00/1.00, addr 1>
> >> > > > > > > > on usbus0
> >> > > > > > > > uhub1: <Mentor Graphics OTG
> Root
> >> HUB, class
> >> > > 9/0, rev
> >> > > > > 2.00/1.00, addr 1>
> >> > > > > > > > on usbus1
> MOUNT, state =
> >> > FAILED,
> >> > > src =
> >> > > > /dev/mmcsd-0
> PARTITION
> >> > INQUIRY, state =
> >> > > > INQUIRY, src =
> >> > > > > > > > /dev/mmcsd-0
> PARTITION
> >> > INQUIRY, state =
> >> > > > SUCCESS, src =
> >> > > > > > > > /dev/mmcsd-0
> PARTITION
> >> > ATTACH, state =
> >> > > > INQUIRY, src =
> >> > > > > > > > /dev/mmcsd-0
> PARTITION
> >> > ATTACH, state =
> >> > > > SUCCESS, src =
> /dev/mmcsd-0-0
> MOUNT, state =
> >> > > INQUIRY, src =
> >> > > > > /dev/mmcsd-0-0
> MOUNT, state =
> >> > FAILED,
> >> > > src =
> >> > > > > /dev/mmcsd-0-0
> >> ATTACH, state =
> >> > > INQUIRY,
> >> > > > src = mmcsd
> >> ATTACH, state =
> >> > > SUCCESS, src =
> >> > > > > mmcsd, dest
> >> > > > > > > > = /dev/mmcsd-1
> MOUNT, state =
> >> > > INQUIRY, src =
> >> > > > /dev/mmcsd-1
> MOUNT, state =
> >> > FAILED,
> >> > > src =
> >> > > > /dev/mmcsd-1
> PARTITION
> >> > INQUIRY, state =
> >> > > > INQUIRY, src =
> >> > > > > > > > /dev/mmcsd-1
> PARTITION
> >> > INQUIRY, state =
> >> > > > SUCCESS, src =
> >> > > > > > > > /dev/mmcsd-1
> PARTITION
> >> > ATTACH, state =
> >> > > > INQUIRY, src =
> >> > > > > > > > /dev/mmcsd-1
> PARTITION
> >> > ATTACH, state =
> >> > > > SUCCESS, src =
> >> > > > > > > > /dev/mmcsd-1, dest =
> /dev/mmcsd-1-0
> MOUNT, state =
> >> > > INQUIRY, src =
> >> > > > > /dev/mmcsd-1-0
> MOUNT, state =
> >> > FAILED,
> >> > > src =
> >> > > > > /dev/mmcsd-1-0
> >> ATTACH, state =
> >> > > INQUIRY, src =
> >> > > > > mmcsd1boot
> >> > > > > > > > uhub0: 1 port with 1 removable,
> >> self powered
> >> > > > > > > > uhub1: 1 port with 1 removable,
> >> self powered
> >> > > > > > > > ERROR: SD could not be mounted
> >> after timeout
> >> > > > > > > > Thanks,
> >> > > > > > > > Nils
> >> > > > > > > > On Mon, 12 Aug 2019 at 18:01,
> >> Christian
> >> > Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>> wrote:
> >> > > > > > > > On 12/08/2019 07:28,
> Nils Hölscher
> >> > wrote:
> >> > > > > > > > > Hi,
> >> > > > > > > > > Can anyone help me
> with this?
> >> > > > > > > > > I need to access the
> BBB's
> >> SD-Card, so
> >> > > that I can load
> >> > > > > my pru
> >> > > > > > > > example on
> >> > > > > > > > > the pru.
> >> > > > > > > > > Thanks,
> >> > > > > > > > > Nils
> >> > > > > > > > Hello Nils,
> >> > > > > > > > take a look at the
> following
> >> > application:
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/init.c#L64
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/libbsdhelper.c#L122
> >> > > > > > > > You should mainly need
> the stuff
> >> > from the
> >> > > > > libbsdhelper_init_sd_card()
> >> > > > > > > > and
> libbsdhelper_wait_for_sd().
> >> > > > > > > > Please note that the SD
> card
> >> needs quite
> >> > > some time to
> >> > > > > initialize on BBB.
> >> > > > > > > > I haven't had a look at
> it why
> >> that
> >> > is the
> >> > > case.
> >> > > > > > > > Best regards
> >> > > > > > > > Christian
> >> > _______________________________________________
> >> > > > > > > > users mailing list
> >> > > > > > > > users at rtems.org
> <mailto:users at rtems.org>
> >> <mailto:users at rtems.org <mailto:users at rtems.org>>
> >> <mailto:users at rtems.org <mailto:users at rtems.org>>>
> <mailto:users at rtems.org <mailto:users at rtems.org>>>>
> <mailto:users at rtems.org> <mailto:users at rtems.org
> <mailto:users at rtems.org <mailto:users at rtems.org>>>>>
> <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>
> >> > http://lists.rtems.org/mailman/listinfo/users
> >> > > > > > > users mailing list
> >> > > > > > > users at rtems.org
> >> > > > > embedded brains GmbH
> >> > > > > Herr Christian Mauderer
> >> > > > > Dornierstr. 4
> >> > > > > D-82178 Puchheim
> >> > > > > Germany
> >> > > > > email:
> >> > > > > Phone: +49-89-18 94 741 - 18
> >> > > > > Fax: +49-89-18 94 741 - 08
> >> > > > > PGP: Public key available on request.
> >> > > > > Diese Nachricht ist keine
> geschäftliche
> >> Mitteilung
> >> > > im Sinne
> >> > > > des EHUG.
> >> > > > > users mailing list
> >> > > > > users at rtems.org
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
