Added support for MX Linux
Joel Sherrill
joel at rtems.org
Tue Aug 20 13:32:13 UTC 2019
I was curious why this didn't apply. I tried it as a patch and then looked
at git blame. The code hasn't changed since 2014 according to git blame.
Is your repo up to date? Are you on the master?
--joel
On Tue, Aug 20, 2019 at 6:55 AM Himanshu Sekhar Nayak
<himanshuwindows8.1 at gmail.com> wrote:
> Ok, I'll check it out and report you soon
> On Tue, Aug 20, 2019, 5:23 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 18/8/19 4:41 pm, Himanshu Sekhar Nayak wrote:
>> > Hi Chris,
>> > Here is the patch and test output. Seems like two executable file failed.|| Here
>> > is the test output:-
>> > https://paste.ofcode.org/gHYFmCZQ9YcDCvc6YiAJuc and warnings
>> > https://paste.ofcode.org/YBgGpNV7yhXsmJJjwYWMYF
>> I could not apply the patch, `git am` failed and I am not sure why. Maybe
>> someone can figure this out and push the patch.
>> Chris
> devel mailing list
> devel at rtems.org
