GSoC 2019 : POSIX Compliance - Final Report
Vaibhav Gupta vaibhavgupta40 at gmail.com
Wed Aug 21 15:13:55 UTC 2019
Here is the final report, published in my Blog. Please review it.
https://medium.com/my-gsoc-2019-journey/gsoc-2019-posix-compliance-74571990c32a
Vaibhav Gupta
On Wed, Aug 21, 2019 at 12:21 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> On Wed, Aug 21, 2019 at 12:15 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> On Tue, Aug 20, 2019 at 9:31 PM Joel Sherrill <joel at rtems.org> wrote:
>>> I am late to the party.
>> The party is still on :D
>>> I made a couple of small changes directly to
>>> the document.
>> Thanks.
>>> I encourage you continue to pick at getting the other fenv ports into
>>> newlib.
>> This is on top of my priority list.
>>> As you
>>> hopefully saw from me adding the stubs for fenv methods and
>>> documentation,
>>> things moving slowly were not a reflection on you personally. I
>>> certainly went through
>>> a number of rounds. :)
>> Yes, I am on it. It would be more easy if RISCV fenv works well. I can
>> get a testsuite
>> which will be of lot help.
>>> Could you add a complete list of POSIX methods that you added? I need to
>>> update
>>> the spreadsheet and .csv file in the POSIX Compliance document.
>> Sure. I added two testsuites, ndbm and inttypes.
>> Only one header - "ndbm.h".
>    int     dbm_clearerr(DBM *);
>    void    dbm_close(DBM *);
>    int     dbm_delete(DBM *, datum);
>    int     dbm_error(DBM *);
>    datum   dbm_fetch(DBM *, datum);
>    datum   dbm_firstkey(DBM *);
>    datum   dbm_nextkey(DBM *);
>    DBM    *dbm_open(const char *, int, mode_t);
>    int     dbm_store(DBM *, datum, datum, int);
>    int     dbm_dirfno(DBM *);
> Updated in report too.
>> I will update this in my report.
>> --Vaibhav Gupta
>>> --joel
>>> On Fri, Aug 16, 2019 at 10:48 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>> > Made the changes as suggested :)
>>> > Please have a look at this now. If every thing is fine.
>>> > I will publish it in my blog.
>>> > -Vaibhav Gupta
>>> > On Fri, Aug 16, 2019 at 7:57 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> >> Vaibhav,
>>> >> Please add a subsection near the top that consolidates links to all
>>> >> the code you wrote during the summer. It is great to have them in
>>> >> context, but it should also be easy (~10 seconds) to find what code
>>> >> you wrote.
>>> >> On Thu, Aug 15, 2019 at 1:27 PM Vaibhav Gupta <
>>> vaibhavgupta40 at gmail.com> wrote:
>>> >> > Hello,
>>> >> > I have made the draft of my project report on google docs.
>>> >> > I have mentioned about each and every task completed
>>> >> > and which are in progress.
>>> >> > It would be very helpful for me If I can get reviews on this,
>>> >> > will also make required changes.
>>> https://docs.google.com/document/d/1I3FsA0whd2AcLKdagUzins-JmWv1QTC6-0v0uvS1_7k/edit?usp=sharing
>>> >> > Thank You
>>> >> > Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190821/27832bed/attachment-0002.html>
