Waf + gccdeps on Mingw64/MSYS2?
Tue Dec 3 02:50:12 UTC 2019
On 2/12/19 5:27 pm, Sebastian Huber wrote:
> On 02/12/2019 01:24, Chris Johns wrote:
>> On 2/12/19 11:10 am, Chris Johns wrote:
>>> On 28/11/19 5:55 pm, Sebastian Huber wrote:
>> I updated MSYS2 to the latest and this error did not appear however I am now
>> seeing ...
>> [1867/4038] Processing testsuites/libtests/tar01/init.o:
>> testsuites/libtests/tar01/init.c
>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar.h
>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar-gz.h
>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar-xz.h ->
>> build/sparc/erc32/testsuites/libtests/tar01/init.o
>> In file included from
>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:26:0:
>> testsuites/libtests/tar01/tar01-tar.h:7:12: warning: extra tokens at end of
>> #ifndef directive
>>   #ifndef
>> __D:_opt_rtems_rtems_seb_build_sparc_erc32_testsuites_libtests_tar01_tar01_tar_h
>> testsuites/libtests/tar01/tar01-tar.h:8:12: warning: ISO C99 requires whitespace
>> after the macro name
>>   #define
>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:27:0:
>> testsuites/libtests/tar01/tar01-tar-gz.h:7:12: warning: extra tokens at end of
>> #ifndef directive
>>   #ifndef
>> __D:_opt_rtems_rtems_seb_build_sparc_erc32_testsuites_libtests_tar01_tar01_tar_gz_h
>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c: In function
>> 'test_untar_unzip_tgz':
>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:44:26: error:
>> 'tar01_tar_gz' undeclared (first use in this function); did you mean
>> 'tar01_tar_size'?
>>   #define TARFILE_GZ_START tar01_tar_gz
>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:198:26: note: in
>> expansion of macro 'TARFILE_GZ_START'
>>     char *buffer = (char *)TARFILE_GZ_START;
>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:44:26: note: each
>> undeclared identifier is reported only once for each function it appears in
>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:45:26: error:
>> 'tar01_tar_gz_size' undeclared (first use in this function); did you mean
>> 'tar01_tar_size'?
>>   #define TARFILE_GZ_SIZE  tar01_tar_gz_size
>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:199:19: note: in
>> expansion of macro 'TARFILE_GZ_SIZE'
>>     size_t buflen = TARFILE_GZ_SIZE;
> I think this revealed two issues.
> 1. The file name sanitation in bin2c was not really good. I fixed it like this:
> https://git.rtems.org/rtems-tools/commit/?id=83b8f1f2a5838a5d56e15c70d44348e3e393e3f7
I cannot test this at the moment because I cannot build the sparc tools after
the updates. Something about an unresolved external in string.h in gdb and I
have not tracked it down.
