Waf + gccdeps on Mingw64/MSYS2?
Tue Dec 3 07:25:34 UTC 2019
On 03/12/2019 03:50, Chris Johns wrote:
> On 2/12/19 5:27 pm, Sebastian Huber wrote:
>> On 02/12/2019 01:24, Chris Johns wrote:
>>> On 2/12/19 11:10 am, Chris Johns wrote:
>>>> On 28/11/19 5:55 pm, Sebastian Huber wrote:
>>> I updated MSYS2 to the latest and this error did not appear however I am now
>>> seeing ...
>>> [1867/4038] Processing testsuites/libtests/tar01/init.o:
>>> testsuites/libtests/tar01/init.c
>>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar.h
>>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar-gz.h
>>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar-xz.h ->
>>> build/sparc/erc32/testsuites/libtests/tar01/init.o
>>> In file included from
>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:26:0:
>>> testsuites/libtests/tar01/tar01-tar.h:7:12: warning: extra tokens at end of
>>> #ifndef directive
>>>    #ifndef
>>> __D:_opt_rtems_rtems_seb_build_sparc_erc32_testsuites_libtests_tar01_tar01_tar_h
>>> testsuites/libtests/tar01/tar01-tar.h:8:12: warning: ISO C99 requires whitespace
>>> after the macro name
>>>    #define
>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:27:0:
>>> testsuites/libtests/tar01/tar01-tar-gz.h:7:12: warning: extra tokens at end of
>>> #ifndef directive
>>>    #ifndef
>>> __D:_opt_rtems_rtems_seb_build_sparc_erc32_testsuites_libtests_tar01_tar01_tar_gz_h
>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c: In function
>>> 'test_untar_unzip_tgz':
>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:44:26: error:
>>> 'tar01_tar_gz' undeclared (first use in this function); did you mean
>>> 'tar01_tar_size'?
>>>    #define TARFILE_GZ_START tar01_tar_gz
>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:198:26: note: in
>>> expansion of macro 'TARFILE_GZ_START'
>>>      char *buffer = (char *)TARFILE_GZ_START;
>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:44:26: note: each
>>> undeclared identifier is reported only once for each function it appears in
>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:45:26: error:
>>> 'tar01_tar_gz_size' undeclared (first use in this function); did you mean
>>> 'tar01_tar_size'?
>>>    #define TARFILE_GZ_SIZE  tar01_tar_gz_size
>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:199:19: note: in
>>> expansion of macro 'TARFILE_GZ_SIZE'
>>>      size_t buflen = TARFILE_GZ_SIZE;
>> I think this revealed two issues.
>> 1. The file name sanitation in bin2c was not really good. I fixed it like this:
>> https://git.rtems.org/rtems-tools/commit/?id=83b8f1f2a5838a5d56e15c70d44348e3e393e3f7
> I cannot test this at the moment because I cannot build the sparc tools after
> the updates. Something about an unresolved external in string.h in gdb and I
> have not tracked it down.
I don't get this far:
Sebastian Huber at Blub MINGW64 ~/src/rsb/rtems
$ ../source-builder/sb-set-builder 5/rtems-sparc --prefix=$HOME/rtems/5
RTEMS Source Builder - Set Builder, 5 (784f518df465 modified)
Build Set: 5/rtems-sparc
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-w64-mingw32-1
building: expat-2.1.0-x86_64-w64-mingw32-1
sizes: expat-2.1.0-x86_64-w64-mingw32-1: 9.231MB (installed: 2.037MB)
cleaning: expat-2.1.0-x86_64-w64-mingw32-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-w64-mingw32-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-w64-mingw32-1.xml
config: tools/rtems-gdb-8.3-1.cfg
error: shell macro failed: sh -c
"/c/test-msys64/home/src/rsb/source-builder/sb/rtems-build-dep -c
x86_64-w64-mingw32-gcc  -I '-IC:/test-msys64/mingw64/include/python3.8
-IC:/test-msys64/mingw64/include/python3.8' -H Python.h": 1: sh: -c:
line 0: unexpected EOF while looking for matching `''
sh: -c: line 1: syntax error: unexpected end of file
Build FAILED
Build Set: Time 0:00:27.190800
Build FAILED
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
