Waf + gccdeps on Mingw64/MSYS2?
Sebastian Huber
Tue Dec 3 13:27:24 UTC 2019
On 03/12/2019 14:10, Sebastian Huber wrote:
> On 03/12/2019 07:03, Sebastian Huber wrote:
>> On 03/12/2019 03:50, Chris Johns wrote:
>>> On 2/12/19 5:27 pm, Sebastian Huber wrote:
>>>> On 02/12/2019 01:24, Chris Johns wrote:
>>>>> On 2/12/19 11:10 am, Chris Johns wrote:
>>>>>> On 28/11/19 5:55 pm, Sebastian Huber wrote:
>>>>> I updated MSYS2 to the latest and this error did not appear however
>>>>> I am now
>>>>> seeing ...
>>>>> [1867/4038] Processing testsuites/libtests/tar01/init.o:
>>>>> testsuites/libtests/tar01/init.c
>>>>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar.h
>>>>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar-gz.h
>>>>> build/sparc/erc32/testsuites/libtests/tar01/tar01-tar-xz.h ->
>>>>> build/sparc/erc32/testsuites/libtests/tar01/init.o
>>>>> In file included from
>>>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:26:0:
>>>>> testsuites/libtests/tar01/tar01-tar.h:7:12: warning: extra tokens
>>>>> at end of
>>>>> #ifndef directive
>>>>> #ifndef
>>>>> __D:_opt_rtems_rtems_seb_build_sparc_erc32_testsuites_libtests_tar01_tar01_tar_h
>>>>> testsuites/libtests/tar01/tar01-tar.h:8:12: warning: ISO C99
>>>>> requires whitespace
>>>>> after the macro name
>>>>> #define
>>>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:27:0:
>>>>> testsuites/libtests/tar01/tar01-tar-gz.h:7:12: warning: extra
>>>>> tokens at end of
>>>>> #ifndef directive
>>>>> #ifndef
>>>>> __D:_opt_rtems_rtems_seb_build_sparc_erc32_testsuites_libtests_tar01_tar01_tar_gz_h
>>>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c: In function
>>>>> 'test_untar_unzip_tgz':
>>>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:44:26: error:
>>>>> 'tar01_tar_gz' undeclared (first use in this function); did you mean
>>>>> 'tar01_tar_size'?
>>>>> #define TARFILE_GZ_START tar01_tar_gz
>>>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:198:26:
>>>>> note: in
>>>>> expansion of macro 'TARFILE_GZ_START'
>>>>> char *buffer = (char *)TARFILE_GZ_START;
>>>>> note: each
>>>>> undeclared identifier is reported only once for each function it
>>>>> appears in
>>>>> note: in
>>>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:45:26: error:
>>>>> 'tar01_tar_gz_size' undeclared (first use in this function); did
>>>>> you mean
>>>>> 'tar01_tar_size'?
>>>>> #define TARFILE_GZ_SIZE tar01_tar_gz_size
>>>>> D:/opt/rtems/rtems.seb/testsuites/libtests/tar01/init.c:199:19:
>>>>> note: in
>>>>> expansion of macro 'TARFILE_GZ_SIZE'
>>>>> size_t buflen = TARFILE_GZ_SIZE;
>>>> I think this revealed two issues.
>>>> 1. The file name sanitation in bin2c was not really good. I fixed it
>>>> like this:
>>>> https://git.rtems.org/rtems-tools/commit/?id=83b8f1f2a5838a5d56e15c70d44348e3e393e3f7
>>> I cannot test this at the moment because I cannot build the sparc
>>> tools after
>>> the updates. Something about an unresolved external in string.h in
>>> gdb and I
>>> have not tracked it down.
>> I do currently a MinGW64/MSYS2 installation from scratch. For the
>> first tests I used an existing installation. I think it makes a
>> difference if you build the rtems-tools with the MSYS2 GCC or the
>> MinGW64 GCC. For example, I didn't observe the bin2c issue in my tests.
> I was able to build the tools without GDB:
> installing: sparc-rtems5-binutils-2.33.1-x86_64-w64-mingw32-1 ->
> c:\test-msys64\home\rtems\5
> installing: sparc-rtems5-gcc-7.5.0-newlib-d14714c69-x86_64-w64-mingw32-1
> -> c:\test-msys64\home\rtems\5
> installing: rtems-tools-83b8f1f2a5838a5d56e15c70d44348e3e393e3f7-1 ->
> installing: sis-2.20-x86_64-w64-mingw32-1 -> c:\test-msys64\home\rtems\5
> cleaning: sparc-rtems5-binutils-2.33.1-x86_64-w64-mingw32-1
> cleaning: sparc-rtems5-gcc-7.5.0-newlib-d14714c69-x86_64-w64-mingw32-1
> cleaning: rtems-tools-83b8f1f2a5838a5d56e15c70d44348e3e393e3f7-1
> cleaning: sis-2.20-x86_64-w64-mingw32-1
> Build Sizes: usage: 7.813GB total: 1.792GB (sources: 124.484MB, patches:
> 19.412KB, installed 1.670GB)
> installing: 5/rtems-sparc -> c:\test-msys64\home\rtems\5
> clean staging: 5/rtems-sparc
> Staging Size: 5.292MB
> Build Set: Time 2:08:23.014800
> However:
> $ ./waf configure --prefix=$HOME/rtems/5
> Setting top to : C:/test-msys64/home/src/rtems
> Setting out to :
> C:/test-msys64/home/src/rtems/build
> Configure board support package (BSP) : sparc/leon3
> Checking for program 'sparc-rtems5-gcc' :
> C:/test-msys64/home/rtems/5/bin/sparc-rtems5-gcc.exe
> Checking for program 'sparc-rtems5-g++' :
> C:/test-msys64/home/rtems/5/bin/sparc-rtems5-g++.exe
> Checking for program 'sparc-rtems5-ar' :
> C:/test-msys64/home/rtems/5/bin/sparc-rtems5-ar.exe
> Checking for program 'sparc-rtems5-ld' :
> C:/test-msys64/home/rtems/5/bin/sparc-rtems5-ld.exe
> Checking for program 'ar' :
> Checking for program 'g++, c++' :
> Checking for program 'gas, gcc' :
> Checking for program 'gcc, cc' :
> Checking for program 'rtems-bin2c' : not found
> Could not find the program ['rtems-bin2c']
> (complete log in C:/test-msys64/home/src/rtems/build/config.log)
> And:
> $ ls -l $HOME/rtems/5/bin/*bin2c*
> ls: cannot access '/c/test-msys64/home/rtems/5/bin/*bin2c*': No such
> file or directory
> And:
> $ grep bin2c rsb-log-20191203-111304.txt
> x -rw-rw-rw- 0 nickc nickc 1639 Sep 9 15:19
> binutils-2.33.1/binutils/bin2c.c
> x drwxrwxr-x 0 root root 0 Dec 2 06:44
> rtems-tools-83b8f1f2a5838a5d56e15c70d44348e3e393e3f7/misc/bin2c/
> x -rw-rw-r-- 0 root root 1683 Dec 2 06:44
> rtems-tools-83b8f1f2a5838a5d56e15c70d44348e3e393e3f7/misc/bin2c/compat.c
> x -rw-rw-r-- 0 root root 7463 Dec 2 06:44
> rtems-tools-83b8f1f2a5838a5d56e15c70d44348e3e393e3f7/misc/bin2c/rtems-bin2c.c
> [238/255] Compiling misc/bin2c/compat.c
> [239/255] Compiling misc/bin2c/rtems-bin2c.c
> [244/255] Linking build/misc/rtems-bin2c.exe
> + install
> C:/test-msys64/home/src/rsb/rtems/build/tmp/rt81-197608/test-msys64/home/rtems/5/bin/rtems-bin2c.exe
> (from build/misc/rtems-bin2c.exe)
> It seems rtems-bin2c.exe is only installed in the RSB build tree?
I cloned and installed the rtems-tools by hand. This seems to work:
Setting out to :
C:/test-msys64/home/rtems/5/bin/rtems-bin2c.exe
Checking for program 'gzip' : C:\test-msys64\usr\bin/gzip.exe
Checking for program 'pax' : C:\test-msys64\usr\bin/pax.exe
Checking for program 'rtems-ld' :
C:/test-msys64/home/rtems/5/bin/rtems-ld.exe
Checking for program 'rtems-syms' :
C:/test-msys64/home/rtems/5/bin/rtems-syms.exe
Checking for program 'xz' : C:\test-msys64\mingw64\bin/xz.exe
'configure' finished successfully (0.223s)
$ ./waf
[4571/4571] Processing link:
build/sparc/leon3/testsuites/libtests/dl04/dl04-tar.o
build/sparc/leon3/testsuites/libtests/dl04/init.o
build/sparc/leon3/testsuites/libtests/dl04/dl-load.o
build/sparc/leon3/testsuites/libtests/dl04/dl04-sym.o ->
build/sparc/leon3/testsuites/libtests/dl04.exe
Waf: Leaving directory `C:/test-msys64/home/src/rtems/build/sparc/leon3'
'build_sparc/leon3' finished successfully (2m42.745s)
$ ./waf install
+ install
C:/test-msys64/home/rtems/5/sparc-rtems5/leon3/lib/include/rtems/score/wkspace.h
(from cpukit/include/rtems/score/wkspace.h)
'install_sparc/leon3' finished successfully (4.803s)
It seems the new build system works now on MinGW64.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
