_TOD_Set lock release question
Joel Sherrill
joel at rtems.org
Wed Dec 4 03:04:34 UTC 2019
Hi
_TOD_Set() currently can't fail. With the addition of the TOD hooks, if a
BSP hook returns false, then _TOD_Set will fail. This requires that the lock
acquired by _TOD_Acquire before _TOD_Set is invoked as in rtems_clock_set()
should be released on the failure path. I don't see a _TOD_Release method.
What method needs to be invoked on the hook error path?
bool _TOD_Set(
const struct timespec *tod,
ISR_lock_Context *lock_context
struct bintime tod_as_bintime;
uint64_t tod_as_ticks;
uint32_t cpu_max;
uint32_t cpu_index;
bool retval;
_Assert( _TOD_Is_owner() );
retval = _TOD_Hook_Run( TOD_ACTION_SET_CLOCK, tod );
if ( retval == false ) {
// XXX what to release???
return false;
timespec2bintime( tod, &tod_as_bintime );
_Timecounter_Set_clock( &tod_as_bintime, lock_context );
Thanks
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191203/c99ee51b/attachment.html>
