[PATCH v2 0/3] bsp/xen: support for Xen hypervisor
Jeff Kubascik
jeff.kubascik at dornerworks.com
Wed Dec 4 14:29:30 UTC 2019
This patch set adds a new board support package to enable RTEMS to run as a
guest virtual machine in AArch32 mode on the Xen hypervisor for ARMv8 platforms.
This required two changes to the shared arm code: add a zImage boot header to
start.S and umasking of the generic timer in the ISR.
This BSP was tested using the Virtuosity distro (maintained by Dornerworks)
running on a Xilinx ZCU102 development board.
I would like to implement a simulator for this platform to enable automated
testing with mainline Xen, but it is currently a work-in-progress.
Changes in v2:
- Squashed "bsp/xen: Create empty template BSP for Xen" commit
- Removed xen.inc and instead placed contents into xen_virtual.cfg
- Added "#ifdef ARM_GENERIC_TIMER_UNMASK_AT_TICK" to the workaround in
clock-generic-timer.c
- Removed bsp README, will submit as a separate patch for the rtems-docs repo
- Changed local label to ".Lafter_header" in start.S
Jeff Kubascik (3):
bsps/arm: Add zImage boot header
bsps/arm: Unmask generic timer in interrupt handler
bsp/xen: Create BSP
bsps/arm/shared/clock/clock-generic-timer.c | 3 +
bsps/arm/shared/start/start.S | 11 +++
bsps/arm/xen/config/xen_virtual.cfg | 14 ++++
bsps/arm/xen/console/console.c | 63 +++++++++++++++
bsps/arm/xen/headers.am | 10 +++
bsps/arm/xen/include/bsp.h | 86 +++++++++++++++++++++
bsps/arm/xen/include/bsp/irq.h | 62 +++++++++++++++
bsps/arm/xen/include/tm27.h | 38 +++++++++
bsps/arm/xen/start/bsp_specs | 9 +++
bsps/arm/xen/start/bspstart.c | 60 ++++++++++++++
bsps/arm/xen/start/bspstarthooks.c | 44 +++++++++++
bsps/arm/xen/start/bspstartmmu.c | 73 +++++++++++++++++
bsps/arm/xen/start/linkcmds.in | 62 +++++++++++++++
c/src/lib/libbsp/arm/acinclude.m4 | 2 +
c/src/lib/libbsp/arm/xen/Makefile.am | 48 ++++++++++++
c/src/lib/libbsp/arm/xen/configure.ac | 59 ++++++++++++++
16 files changed, 644 insertions(+)
create mode 100644 bsps/arm/xen/config/xen_virtual.cfg
create mode 100644 bsps/arm/xen/console/console.c
create mode 100644 bsps/arm/xen/headers.am
create mode 100644 bsps/arm/xen/include/bsp.h
create mode 100644 bsps/arm/xen/include/bsp/irq.h
create mode 100644 bsps/arm/xen/include/tm27.h
create mode 100644 bsps/arm/xen/start/bsp_specs
create mode 100644 bsps/arm/xen/start/bspstart.c
create mode 100644 bsps/arm/xen/start/bspstarthooks.c
create mode 100644 bsps/arm/xen/start/bspstartmmu.c
create mode 100644 bsps/arm/xen/start/linkcmds.in
create mode 100644 c/src/lib/libbsp/arm/xen/Makefile.am
create mode 100644 c/src/lib/libbsp/arm/xen/configure.ac
2.17.1
