[PATCH v2 3/3] bsp/xen: Create BSP
Jeff Kubascik jeff.kubascik at dornerworks.com
Wed Dec 4 14:29:33 UTC 2019
Create the Xen BSP for Xen on ARM.
 bsps/arm/xen/config/xen_virtual.cfg   | 14 +++++
 bsps/arm/xen/console/console.c        | 63 ++++++++++++++++++++
 bsps/arm/xen/headers.am               | 10 ++++
 bsps/arm/xen/include/bsp.h            | 86 +++++++++++++++++++++++++++
 bsps/arm/xen/include/bsp/irq.h        | 62 +++++++++++++++++++
 bsps/arm/xen/include/tm27.h           | 38 ++++++++++++
 bsps/arm/xen/start/bsp_specs          |  9 +++
 bsps/arm/xen/start/bspstart.c         | 60 +++++++++++++++++++
 bsps/arm/xen/start/bspstarthooks.c    | 44 ++++++++++++++
 bsps/arm/xen/start/bspstartmmu.c      | 73 +++++++++++++++++++++++
 bsps/arm/xen/start/linkcmds.in        | 62 +++++++++++++++++++
 c/src/lib/libbsp/arm/acinclude.m4     |  2 +
 c/src/lib/libbsp/arm/xen/Makefile.am  | 48 +++++++++++++++
 c/src/lib/libbsp/arm/xen/configure.ac | 59 ++++++++++++++++++
 14 files changed, 630 insertions(+)
 create mode 100644 bsps/arm/xen/config/xen_virtual.cfg
 create mode 100644 bsps/arm/xen/console/console.c
 create mode 100644 bsps/arm/xen/headers.am
 create mode 100644 bsps/arm/xen/include/bsp.h
 create mode 100644 bsps/arm/xen/include/bsp/irq.h
 create mode 100644 bsps/arm/xen/include/tm27.h
 create mode 100644 bsps/arm/xen/start/bsp_specs
 create mode 100644 bsps/arm/xen/start/bspstart.c
 create mode 100644 bsps/arm/xen/start/bspstarthooks.c
 create mode 100644 bsps/arm/xen/start/bspstartmmu.c
 create mode 100644 bsps/arm/xen/start/linkcmds.in
 create mode 100644 c/src/lib/libbsp/arm/xen/Makefile.am
 create mode 100644 c/src/lib/libbsp/arm/xen/configure.ac
diff --git a/bsps/arm/xen/config/xen_virtual.cfg b/bsps/arm/xen/config/xen_virtual.cfg
new file mode 100644
index 0000000000..1b5031c3f0
--- /dev/null
+++ b/bsps/arm/xen/config/xen_virtual.cfg
@@ -0,0 +1,14 @@
+#  Configuration file for the "xen_virtual" target
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = arm
+CPU_CFLAGS = -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
+CFLAGS_OPTIMIZE_V += -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
diff --git a/bsps/arm/xen/console/console.c b/bsps/arm/xen/console/console.c
index 0000000000..786b98f3ba
--- /dev/null
+++ b/bsps/arm/xen/console/console.c
@@ -0,0 +1,63 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 DornerWorks
+ * Written by Jeff Kubascik <jeff.kubascik at dornerworks.com>
+ * are met:
+#include <rtems/bspIo.h>
+#include <bsp.h>
+#include <bsp/arm-pl011.h>
+#include <bsp/console-termios.h>
+#include <bsp/irq-generic.h>
+#include <bspopts.h>
+arm_pl011_context xen_vpl011_context = {
+  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
+  .regs = (volatile pl011 *) BSP_XEN_VPL011_BASE,
+  .irq = GUEST_VPL011_SPI,
+  .initial_baud = 115200
+const console_device console_device_table[] = {
+    .device_file = "/dev/ttyS0",
+    .probe = console_device_probe_default,
+    .handler = &arm_pl011_fns,
+    .context = &xen_vpl011_context.base
+const size_t console_device_count = RTEMS_ARRAY_SIZE(console_device_table);
+static void output_char( char c )
+  arm_pl011_write_polled(&xen_vpl011_context.base, c);
+BSP_output_char_function_type BSP_output_char = output_char;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/bsps/arm/xen/headers.am b/bsps/arm/xen/headers.am
index 0000000000..952fa37670
--- /dev/null
+++ b/bsps/arm/xen/headers.am
@@ -0,0 +1,10 @@
+## This file was generated by "./boostrap -H".
+include_HEADERS =
+include_HEADERS += ../../../../../../bsps/arm/xen/include/bsp.h
+include_HEADERS += include/bspopts.h
+include_HEADERS += ../../../../../../bsps/arm/xen/include/tm27.h
+include_bspdir = $(includedir)/bsp
+include_bsp_HEADERS =
+include_bsp_HEADERS += ../../../../../../bsps/arm/xen/include/bsp/irq.h
diff --git a/bsps/arm/xen/include/bsp.h b/bsps/arm/xen/include/bsp.h
index 0000000000..e5b23a902e
--- /dev/null
+++ b/bsps/arm/xen/include/bsp.h
@@ -0,0 +1,86 @@
+ * @file
+ * @ingroup RTEMSBSPsARMxen
+ * @brief Global BSP definitions.
+ * are met:
+#ifndef LIBBSP_ARM_XEN_BSP_H
+#define LIBBSP_ARM_XEN_BSP_H
+ * @addtogroup RTEMSBSPsARM
+#define BSP_FEATURE_IRQ_EXTENSION
+#ifndef ASM
+#include <bsp/default-initial-extension.h>
+#include <bsp/start.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_ARM_GIC_CPUIF_BASE 0x03002000
+#define BSP_ARM_GIC_CPUIF_LENGTH 0x1000
+#define BSP_ARM_GIC_DIST_BASE 0x03001000
+#define BSP_ARM_GIC_DIST_LENGTH 0x1000
+#define BSP_ARM_A9MPCORE_SCU_BASE 0
+#define BSP_ARM_A9MPCORE_GT_BASE 0
+#define BSP_XEN_VPL011_BASE 0x22000000
+#define BSP_XEN_VPL011_LENGTH 0x1000
+void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
+BSP_START_TEXT_SECTION void bsp_xen_setup_mmu_and_cache(void);
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_ARM_XEN_BSP_H */
diff --git a/bsps/arm/xen/include/bsp/irq.h b/bsps/arm/xen/include/bsp/irq.h
index 0000000000..dc09e52373
--- /dev/null
+++ b/bsps/arm/xen/include/bsp/irq.h
@@ -0,0 +1,62 @@
+ * are met:
+#ifndef LIBBSP_ARM_XEN_IRQ_H
+#define LIBBSP_ARM_XEN_IRQ_H
+#ifndef ASM
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#include <bsp/arm-gic-irq.h>
+#ifdef __cplusplus
+extern "C" {
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX 1023
+/* Xen guest interrupts */
+#define GUEST_TIMER_VIRT_PPI 27
+#define GUEST_TIMER_PHYS_S_PPI 29
+#define GUEST_TIMER_PHYS_NS_PPI 30
+#define GUEST_EVTCHN_PPI 31
+#define GUEST_VPL011_SPI 32
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_ARM_XEN_IRQ_H */
diff --git a/bsps/arm/xen/include/tm27.h b/bsps/arm/xen/include/tm27.h
index 0000000000..2fc4afa4f2
--- /dev/null
+++ b/bsps/arm/xen/include/tm27.h
@@ -0,0 +1,38 @@
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <bsp/arm-gic-tm27.h>
+#endif /* __tm27_h */
diff --git a/bsps/arm/xen/start/bsp_specs b/bsps/arm/xen/start/bsp_specs
index 0000000000..47dd31d46b
--- /dev/null
+++ b/bsps/arm/xen/start/bsp_specs
@@ -0,0 +1,9 @@
+%rename endfile old_endfile
+%rename startfile old_startfile
+*startfile:
+%{!qrtems: %(old_startfile)} \
+%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
+*endfile:
+%{!qrtems: %(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/bsps/arm/xen/start/bspstart.c b/bsps/arm/xen/start/bspstart.c
index 0000000000..6b826fc917
--- /dev/null
+++ b/bsps/arm/xen/start/bspstart.c
@@ -0,0 +1,60 @@
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/linker-symbols.h>
+#include <libcpu/arm-cp15.h>
+void arm_generic_timer_get_config( uint32_t *frequency, uint32_t *irq )
+  *frequency = arm_cp15_get_counter_frequency();
+#ifdef ARM_GENERIC_TIMER_USE_VIRTUAL
+  *irq = GUEST_TIMER_VIRT_PPI;
+#else
+  *irq = GUEST_TIMER_PHYS_NS_PPI;
+#endif
+ *  bsp_start
+ *  This routine does the bulk of the system initialization.
+void bsp_start( void )
+  bsp_interrupt_initialize();
+  rtems_cache_coherent_add_area(
+    bsp_section_nocacheheap_begin,
+    (uintptr_t) bsp_section_nocacheheap_size
diff --git a/bsps/arm/xen/start/bspstarthooks.c b/bsps/arm/xen/start/bspstarthooks.c
index 0000000000..120535c60f
--- /dev/null
+++ b/bsps/arm/xen/start/bspstarthooks.c
@@ -0,0 +1,44 @@
+ * are met:
+#include <bsp.h>
+#include <bsp/arm-a9mpcore-start.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+  /* Do nothing */
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+  arm_a9mpcore_start_set_vector_base();
+  bsp_start_copy_sections();
+  bsp_xen_setup_mmu_and_cache();
+  bsp_start_clear_bss();
diff --git a/bsps/arm/xen/start/bspstartmmu.c b/bsps/arm/xen/start/bspstartmmu.c
index 0000000000..b24af89d41
--- /dev/null
+++ b/bsps/arm/xen/start/bspstartmmu.c
@@ -0,0 +1,73 @@
+ * are met:
+#define ARM_CP15_TEXT_SECTION BSP_START_TEXT_SECTION
+#include <bsp.h>
+#include <bsp/arm-cp15-start.h>
+BSP_START_DATA_SECTION static const arm_cp15_start_section_config
+xen_bsp_mmu_config_table[] = {
+  ARMV7_CP15_START_DEFAULT_SECTIONS,
+    .begin = BSP_ARM_GIC_DIST_BASE,
+    .end = BSP_ARM_GIC_DIST_BASE + BSP_ARM_GIC_DIST_LENGTH,
+    .flags = ARMV7_MMU_DEVICE
+    .begin = BSP_ARM_GIC_CPUIF_BASE,
+    .end = BSP_ARM_GIC_CPUIF_BASE + BSP_ARM_GIC_CPUIF_LENGTH,
+    .begin = BSP_XEN_VPL011_BASE,
+    .end = BSP_XEN_VPL011_BASE + BSP_XEN_VPL011_LENGTH,
+ * Make weak and let the user override.
+BSP_START_TEXT_SECTION void bsp_xen_setup_mmu_and_cache(void) __attribute__ ((weak));
+  uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
+    ARM_CP15_CTRL_TRE | ARM_CP15_CTRL_A,
+    ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
+  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
+    ctrl,
+    (uint32_t *) bsp_translation_table_base,
+    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
+    &xen_bsp_mmu_config_table[0],
+    RTEMS_ARRAY_SIZE(xen_bsp_mmu_config_table)
diff --git a/bsps/arm/xen/start/linkcmds.in b/bsps/arm/xen/start/linkcmds.in
index 0000000000..944687679b
--- /dev/null
+++ b/bsps/arm/xen/start/linkcmds.in
@@ -0,0 +1,62 @@
+ * are met:
+MEMORY {
+   RAM_MMU   : ORIGIN = @GUEST_RAM_BASE@, LENGTH = @GUEST_RAM_MMU_LENGTH@
+   RAM       : ORIGIN = @GUEST_RAM_BASE@ + @GUEST_LOAD_OFFSET@, LENGTH = @GUEST_RAM_LENGTH@ - @GUEST_LOAD_OFFSET@ - @GUEST_RAM_NOCACHE_LENGTH@
+   NOCACHE   : ORIGIN = @GUEST_RAM_BASE@ + @GUEST_RAM_LENGTH@ - @GUEST_RAM_NOCACHE_LENGTH@, LENGTH = @GUEST_RAM_NOCACHE_LENGTH@
+REGION_ALIAS ("REGION_START",          RAM);
+REGION_ALIAS ("REGION_VECTOR",         RAM);
+REGION_ALIAS ("REGION_TEXT",           RAM);
+REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
+REGION_ALIAS ("REGION_RODATA",         RAM);
+REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
+REGION_ALIAS ("REGION_DATA",           RAM);
+REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
+REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+REGION_ALIAS ("REGION_FAST_DATA",      RAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+REGION_ALIAS ("REGION_BSS",            RAM);
+REGION_ALIAS ("REGION_WORK",           RAM);
+REGION_ALIAS ("REGION_STACK",          RAM);
+REGION_ALIAS ("REGION_NOCACHE",        NOCACHE);
+REGION_ALIAS ("REGION_NOCACHE_LOAD",   NOCACHE);
+bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
+bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+bsp_vector_table_in_start_section = 1;
+bsp_translation_table_base = ORIGIN (RAM_MMU);
+bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
+INCLUDE linkcmds.armv4
diff --git a/c/src/lib/libbsp/arm/acinclude.m4 b/c/src/lib/libbsp/arm/acinclude.m4
index 04557a6d69..4d50477eb3 100644
--- a/c/src/lib/libbsp/arm/acinclude.m4
+++ b/c/src/lib/libbsp/arm/acinclude.m4
@@ -40,6 +40,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
     AC_CONFIG_SUBDIRS([stm32f4]);;
   tms570 )
     AC_CONFIG_SUBDIRS([tms570]);;
+  xen )
+    AC_CONFIG_SUBDIRS([xen]);;
   xilinx-zynq )
     AC_CONFIG_SUBDIRS([xilinx-zynq]);;
   xilinx-zynqmp )
diff --git a/c/src/lib/libbsp/arm/xen/Makefile.am b/c/src/lib/libbsp/arm/xen/Makefile.am
index 0000000000..fecb665af4
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xen/Makefile.am
@@ -0,0 +1,48 @@
+ACLOCAL_AMFLAGS = -I ../../../../aclocal
+include $(top_srcdir)/../../../../automake/compile.am
+include $(top_srcdir)/../../bsp.am
+dist_project_lib_DATA = ../../../../../../bsps/arm/xen/start/bsp_specs
+noinst_PROGRAMS =
+start.$(OBJEXT): ../../../../../../bsps/arm/shared/start/start.S
+	$(CPPASCOMPILE) -o $@ -c $<
+project_lib_DATA = start.$(OBJEXT)
+project_lib_DATA += linkcmds
+project_lib_LIBRARIES = librtemsbsp.a
+librtemsbsp_a_SOURCES =
+# startup
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-default.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xen/start/bspstart.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xen/start/bspstarthooks.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xen/start/bspstartmmu.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
+# clock
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-generic-timer.c
+# cache
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
+# irq
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/irq/irq-gic.c
+# console
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xen/console/console.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios-init.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/arm-pl011.c
+# timer
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
+include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
+include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
+include $(srcdir)/../../../../../../bsps/arm/xen/headers.am
diff --git a/c/src/lib/libbsp/arm/xen/configure.ac b/c/src/lib/libbsp/arm/xen/configure.ac
index 0000000000..effd4986bb
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xen/configure.ac
@@ -0,0 +1,59 @@
+## Process this file with autoconf to produce a configure script.
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-arm-xen],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
+RTEMS_TOP(../../../../../..)
+RTEMS_SOURCE_TOP
+RTEMS_BUILD_TOP
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_BSPOPTS_SET([BSP_DATA_CACHE_ENABLED],[*qemu],[])
+RTEMS_BSPOPTS_SET([BSP_DATA_CACHE_ENABLED],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_DATA_CACHE_ENABLED],[enable data cache])
+RTEMS_BSPOPTS_SET([BSP_INSTRUCTION_CACHE_ENABLED],[*qemu],[])
+RTEMS_BSPOPTS_SET([BSP_INSTRUCTION_CACHE_ENABLED],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_INSTRUCTION_CACHE_ENABLED],[enable instruction cache])
+RTEMS_BSPOPTS_SET([ARM_GENERIC_TIMER_USE_VIRTUAL],[*],[1])
+RTEMS_BSPOPTS_HELP([ARM_GENERIC_TIMER_USE_VIRTUAL],[use virtual ARM generic timer])
+RTEMS_BSPOPTS_SET([ARM_GENERIC_TIMER_UNMASK_AT_TICK],[*],[1])
+RTEMS_BSPOPTS_HELP([ARM_GENERIC_TIMER_UNMASK_AT_TICK],[unmask the timer in the tick handler, since Xen will mask the virtual timer before injecting the interrupt to the guest])
+RTEMS_BSPOPTS_SET([BSP_START_ZIMAGE_HEADER],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_START_ZIMAGE_HEADER],[include zImage boot header])
+RTEMS_BSPOPTS_SET([BSP_XEN_RAM_LENGTH],[*],[8M])
+RTEMS_BSPOPTS_HELP([BSP_XEN_RAM_LENGTH],[override a BSP's default RAM length])
+RTEMS_BSPOPTS_SET([BSP_XEN_NOCACHE_LENGTH],[*],[1M])
+RTEMS_BSPOPTS_HELP([BSP_XEN_NOCACHE_LENGTH],[length of nocache RAM region])
+GUEST_RAM_BASE="0x40000000"
+GUEST_LOAD_OFFSET="0x8000"
+GUEST_RAM_MMU_LENGTH="16k"
+AC_DEFUN([XEN_LINKCMD],[
+AC_ARG_VAR([$1],[$2; default $3])dnl
+[$1]=[$]{[$1]:-[$3]}
+XEN_LINKCMD([GUEST_RAM_BASE],[normal RAM region origin],[${GUEST_RAM_BASE}])
+XEN_LINKCMD([GUEST_RAM_LENGTH],[normal RAM region length],[${BSP_XEN_RAM_LENGTH}])
+XEN_LINKCMD([GUEST_LOAD_OFFSET],[entry point of guest],[${GUEST_LOAD_OFFSET}])
+XEN_LINKCMD([GUEST_RAM_MMU_LENGTH],[MMU region length],[${GUEST_RAM_MMU_LENGTH}])
+XEN_LINKCMD([GUEST_RAM_NOCACHE_LENGTH],[length of nocache RAM region],[${BSP_XEN_NOCACHE_LENGTH}])
+RTEMS_BSP_CLEANUP_OPTIONS
+# Explicitly list all Makefiles here
+AC_CONFIG_FILES([
+Makefile
+linkcmds:../../../../../../bsps/arm/xen/start/linkcmds.in])
+AC_OUTPUT
2.17.1
