[PATCH] bsp/xen: Create README
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Wed Dec 4 15:43:20 UTC 2019
Thanks Jeff!
On Wed, 4 Dec 2019 at 14:53, Jeff Kubascik
<jeff.kubascik at dornerworks.com> wrote:
> Add a README for the new xen bsp.
>  user/bsps/arm/xen.rst | 79 +++++++++++++++++++++++++++++++++++++++++++
>  1 file changed, 79 insertions(+)
>  create mode 100644 user/bsps/arm/xen.rst
> diff --git a/user/bsps/arm/xen.rst b/user/bsps/arm/xen.rst
> new file mode 100644
> index 0000000..e499f5d
> --- /dev/null
> +++ b/user/bsps/arm/xen.rst
> @@ -0,0 +1,79 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2019 DornerWorks
> +.. Copyright (C) 2019 Jeff Kubascik <jeff.kubascik at dornerworks.com>
> +xen (Xen on ARM)
> +This BSP enables RTEMS to run as a guest virtual machine in AArch32 mode on the
> +Xen hypervisor for ARMv8 platforms.
> +Drivers:
> +* Clock: ARMv7-AR Generic Timer
> +* Console: Virtual PL011 device
> +* Interrupt: GICv2
> +BSP variants:
> +* xen_virtual: completely virtualized guest with no dependence on underlying
> +  hardware
> +The xen_virtual BSP variant relies on standard Xen features, so it should be
> +able to run on any ARMv8 platform.
> +Xen allows for the passthrough of hardware peripherals to guest virtual
> +machines. BSPs could be added in the future targeting specific hardware
> +platforms and include the appropriate drivers.
Does RTEMS itself get rescheduled by Xen/Dom0? If yes, how might that
affect the realtime requirements?
> +This BSP was tested with Xen running on the Xilinx Zynq UltraScale+ MPSoC using
> +the Virtuosity distribution maintained by DornerWorks.
> +Execution
> +This procedure describes how to run the ticker sample application that should
> +already be built with the BSP.
> +The ``ticker.exe`` file can be found in the BSP build tree at:
> +.. code-block:: none
> +    arm-rtems5/c/xen_virtual/testsuites/samples/ticker.exe
> +The ``ticker.exe`` elf file must be translated to a binary format.
> +    arm-rtems5-objcopy -O binary ticker.exe ticker.bin
> +Then place the ``ticker.bin`` file on the dom0 filesystem.
> +From the dom0 console, create a configuration file ``ticker.cfg`` with the
> +following contents.
> +..code-block:: none
> +    name = "ticker"
> +    kernel = "ticker.bin"
> +    memory = 8
> +    vcpus = 1
> +    gic_version = "v2"
> +    vuart = "sbsa_uart"
> +Create the virtual machine and attach to the virtual vpl011 console.
> +    xl create ticker.cfg && xl console -t vuart ticker
> +To return back to the dom0 console, press both ``Ctrl`` and ``]`` on your
> +keyboard.
> +Additional Information
> +* `Virtuosity distribution <https://dornerworks.com/xen/virtuosity>`_
> 2.17.1
> devel mailing list
> devel at rtems.org
