Doorstop 2.0.post2 release available
Chris Johns
chrisj at rtems.org
Thu Dec 5 00:27:13 UTC 2019
On 4/12/19 5:58 pm, Sebastian Huber wrote:
> On 04/12/2019 04:25, Chris Johns wrote:
>> On 3/12/19 5:01 pm, Sebastian Huber wrote:
>>> On 03/12/2019 00:06, Chris Johns wrote:
>>>>> The first use of Doorstop is done in the new build system. I will update the
>>>>> documentation to mention this Doorstop release. I will use it to generate the
>>>>> fingerprints of the items.
>>>> Do we need to capture Doorstop in our future releases? If so how? We have a
>>>> requirement our release capture all source code so insulate ourselves
>>>> against an
>>>> upstream side not existing or restructuring.
>>> On pypi.org you can download packages:
>>> https://pypi.org/project/doorstop/2.0.post2/#files
>>> Should we add a Git mirror to RTEMS?
>> Does this help? I can capture a specific version somehow I suppose, ie from
>> github.
> If you trust in the long-term availability of external services, you can also do a:
> pip install doorstop==2.0.post2
> Probably together with a virtualenv:
> https://packaging.python.org/guides/installing-using-pip-and-virtual-environments/
I have no real feel for what would work. It would be a guess now and then we
find out later.
>>> For what would we need Doorstop after a release? You need it after changes in
>>> specification files to update the fingerprints (e.g. fix of a typo in a
>>> documentation file). In the worst case you could do this also by hand or just
>>> don't update the fingerprint.
>> This is reasonable, I suppose. What about a user picking up a certified version
>> of RTEMS years later and wanting to make some changes and Doorstop is now
>> version 6 and something things have change? Is the release source captured the
>> source to use a release or is it the source to use and maintain a release?
> Maybe we should just document in the RTEMS Software Engineering manual which
> Doorstop version should be used, hope for the best and rely on pypi.org, and
> make a backup of the Doorstop package of the specified version?
Sure.
Can the required version be a requirement, ie a YAML file? :)
