[PATCH v5] Add new COPYING file
Sebastian Huber
Fri Dec 6 06:16:13 UTC 2019
Ping.
On 19/12/2018 13:37, Sebastian Huber wrote:
> Update #3053.
> v2:
> Add Hesham Almatary:
> https://devel.rtems.org/ticket/3053#comment:6
> v3:
> Add Jiri Gaisler:
> https://devel.rtems.org/ticket/3053#comment:7
> I am not sure about the first contribution year.
> v4:
> Add GCI contributors:
> Abhimanyu Raghuvanshi
> Himanshu Sekhar Nayak
> Jacob Shin
> Marçal Comajoan Cara
> Pritish Jain
> Shashvat Jain
> v5:
> Add GCI contributor:
> Zenon Hans Taneka
> I need names for:
> kaidoho kho237115 at gmail.com
> kuaLeYi kualeyidxa at gmail.com
> COPYING | 47 +++++++++++++++++++++++++++++++++++++++++++++++
> 1 file changed, 47 insertions(+)
> create mode 100644 COPYING
> diff --git a/COPYING b/COPYING
> new file mode 100644
> index 0000000000..2e1339c90e
> --- /dev/null
> +++ b/COPYING
> @@ -0,0 +1,47 @@
> +RTEMS is a collection of software from several sources.
> +Each file may have its own copyright/license that is embedded in the source
> +file. Unless otherwise noted in the body of the source file(s), the following
> +copyright notices will apply to the contents of RTEMS. Copyright lines should
> +be sorted by the first year followed by the copyright holder.
> +(1) BSD-2-Clause
> +Copyright (C) 2018 Abhimanyu Raghuvanshi
> +Copyright (C) 2018 Himanshu Sekhar Nayak
> +Copyright (C) 2018 Jacob Shin
> +Copyright (C) 2018 Marçal Comajoan Cara
> +Copyright (C) 2018 Pritish Jain
> +Copyright (C) 2018 Shashvat Jain
> +Copyright (C) 2015, 2016 Alexander Krutwig
> +Copyright (C) 2013, 2018 Hesham Almatary
> +Copyright (C) 2012, 2014 Ralf Kirchner
> +Copyright (C) 2012, 2018 Christian Mauderer
> +Copyright (C) 2010, 2018 Gedare Bloom
> +Copyright (C) 2008, 2018 Sebastian Huber
> +Copyright (C) 2005, 2018 Thomas Dörfler
> +Copyright (C) 2005, 2018 embedded brains GmbH
> +Copyright (C) 1996, 2018 Chris Johns
> +Copyright (C) 1996, 2016 Jiri Gaisler
> +Copyright (C) 1989, 2018 On-Line Applications Research Corporation (OAR)
> +Redistribution and use in source and binary forms, with or without
> +modification, are permitted provided that the following conditions
> +are met:
> +1. Redistributions of source code must retain the above copyright
> + notice, this list of conditions and the following disclaimer.
> +2. Redistributions in binary form must reproduce the above copyright
> + notice, this list of conditions and the following disclaimer in the
> + documentation and/or other materials provided with the distribution.
> +THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> +LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +POSSIBILITY OF SUCH DAMAGE.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
