Application Configuration Tests?
Joel Sherrill
joel at rtems.org
Fri Dec 6 11:26:57 UTC 2019
On Fri, Dec 6, 2019, 1:48 AM Sebastian Huber <
> Hello,
> we have about 147 documented configuration options (see attached file).
> We probably need a test case for the minimum, default, and maximum
> value. Some defines have boolean values. Lets assume three test cases
> per option. So, about 500 tests. Should we use full test programs which
> run on the target for the tests or should I try to use C preprocess or
> compile only tests? For example we could C preprocess a file and then
> grep for a certain pattern. We could also compile the configuration file
> and use GDB to pretty print the relevant data structures and then
> compare it with a pattern.
If this can be tested compile only, that would be good by me.
There may be some which are not documented but should be. I recall running
across one recently. I don't remember if that got fixed or not.
I think own configuration for many items can be deleted. Driver, init
task/thread, and extension table may be the only ones that make sense
anymore.
--joel
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191206/43674322/attachment.html>
