[PATCH v3] Add TOD Hooks to allow BSP to take action when TOD is set
Tue Dec 10 05:58:03 UTC 2019
On 09/12/2019 16:32, Joel Sherrill wrote:
> Two use cases were envisioned for this.
> 1) a BSP or application which desires to update a real-time clock
>     when the RTEMS TOD is set.
> 2) a paravirtualized BSP can use this to propagate setting the time
>     in an RTEMS application to the hosting environment. This enables
>     the entire set of applications in the virtualized environments
>     to have a single consistent TOD.
Thanks, looks good.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
